Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
08-23-2005, 22:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | M55 power on , light for 2 secs and phone off .. ?? i got m55 here , got it to repair. pc dont have a prob to read phone , program set to bootcore patch ( test point ??). when i try to power on the phone , i got 2 secs of light , and phone off again. i tried to read battary map from a working phone and upload to bad phone , no good. i open the phone , its not look like someone cut anything in test point. couldnt find a solution here on with search. any ideas will be great thx |
08-24-2005, 08:27 | #5 (permalink) | |
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
but i just spoke with the phone owner , he said it just happened , phone was already unlocked over a year or so , and it just happen ... anyway gonna flash it and post results thx | |
08-24-2005, 09:39 | #6 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | well , i cant seem to flash the phone with sst . ( cracked) or am i doing something wrong can i convert this flash to use with feria ? or can i use other tool ? |
08-24-2005, 11:30 | #7 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | You said that you have a working phone. Read fullflash from it and write it to the dead one. or check www.siemens-free**** /you need to install anti leech plugin) there is a fubu from me uploaded which is working 100%! |
08-24-2005, 11:57 | #9 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 16927 Status: Offline Thanks Meter: 134 | Try to unlock usally first. If not then first Read Map From Phone then write this map again (few times) if this don't work just write new EEPROM (remember if you write new eeprom alwasy make unlock again). From your description means phone have version under 11 thats means you must not do TP. post results.... br. fingusio |
10-06-2005, 10:36 | #10 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: Bangladesh Age: 41
Member: 117230 Status: Offline Thanks Meter: 15 | Quote:
u may usse freia v18 .with my exprience i know that if u flash sst not working.but freia 100% ok. | |
Compatible Built-In On / Off Power Switch Button for NK 6110/6120 Phone | IPMART | ipmart WebShop | 0 | 12-14-2009 10:30 |
V3 doesn't power on. Lights for 1 seconds before shutting down. | James_S | Smart-Clip | 5 | 09-18-2006 00:08 |
3310 power on then 1-2 sec lost network | hs_ | Nokia Hardware & Hardware Repair | 8 | 10-26-2002 23:15 |
6510 when power on lights only.. can't power off | eureka8888 | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 08-06-2002 23:10 |
922 only on for 2 sec. then goes off | CellM@n | Infineon C16X M51 & ARM7 M52 BASED | 4 | 12-06-2001 12:22 |
