Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens Hardware Repair Area
Siemens Hardware Repair Area all about Hardware Repairing you can get if here.
View Poll Results: is this way for repairing
good 8 50.00%
usefull 7 43.75%
useless 1 6.25%
Multiple Choice Poll. Voters: 16. You may not vote on this poll
Old 01-08-2005, 20:37   #1 (permalink)
Member: 18966
Thanks Meter: 59
Thumbs up my way for repairing insert card on cf62 after bad cut tp without removing cpu
here is my way for repairing insert card on cf62 after bad cut tp without removing cpu
i don't know if this way is usefull if more then one line are cutting from sim card to cpu
any way i shared it
the idea come from reballing flash or ccont etc ... with solder glue so i put
some from that solder glue where i cut & with a pin i pressed on it i clean the board from that solder than i use the hot air to rehot the solder glue . then i mesure btw pin 6 (sim) and the line (tp) no contact ok
mesure btw all pin's off sim card no contact ok
mesure btw pin 6 and mass no contact ok
then i success my phone see the sim & evry thing is ok
sorry for my bad english
i hope this post can help
Old 01-08-2005, 21:20   #2 (permalink)
evan_silbert's Avatar
Member: 21920
Thanks Meter: 10
This is a good idea Thanks for sharing.
Old 01-10-2005, 05:45   #3 (permalink)
Member: 20500
Thanks Meter: 4
i did that and it works well 100/100
but just use good flux when you do that and without check all this mesurments just try phone
it will tell you the results
to me it is the most savely way to repair it
Old 01-11-2005, 22:44   #4 (permalink)
Member: 18966
Thanks Meter: 59
good news this is another one success
all thoose mesurments coz u don't know what did u cut so for more protection phone
Old 01-13-2005, 19:59   #5 (permalink)
abakwa's Avatar
Member: 69269
Thanks Meter: 175
no need to link cpu and sim pin6
I used a jumper wire to link the cut i made and the bad cut was repaired. Just solder a neat wire on the cut and the fone is ok.
Old 03-06-2005, 12:17   #6 (permalink)
Member: 16830
Thanks Meter: 32
if u cut more than one line between simcard reader and cpu? do u have solution for this?
Old 03-06-2005, 20:08   #7 (permalink)
Member: 18966
Thanks Meter: 59
i think sir u must remove cpu & make jumper
good luck
Old 03-18-2005, 21:33   #8 (permalink)
Crazy Poster
Member: 65962
Thanks Meter: 5
heheh , this is a very stupid solution . Many bad cut phones , that i repair are with 2-3 tracks. This solution cant help :-)) The true is a 2 or 3 jumpers from CPU to SIM Reader. T16 -> simreset ,U15 ->simdata,T13 -> sim clock
.That's all.
B.R. to all testers :-)
p.s. yesterday , i receive 2 phones with this damned solution and waste time to repair this bul****s :-(((
Old 03-18-2005, 22:18   #9 (permalink)
Member: 18966
Thanks Meter: 59
.That's all.
any way thank's for ur reply this is ur opinion & i respect that but sir if u read carrefully all post above no one said this way can repaire more then one
line cut .
read this post if u don't have time
good luck
so any way i am sorry if u wast time so please forgive me
Old 03-18-2005, 22:26   #10 (permalink)
Member: 125528
hey ASMAR COULD U OR ANYONE TELL ME WHEY WHEN I TRY TO DOWNLOAD ANYTHING FROM THIS SITE IT COMES UP AS SOME WIERD WRITTING
Old 03-20-2005, 11:46   #11 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
i will try this application .
bestman
Old 03-21-2005, 16:24   #12 (permalink)
TheBrain's Avatar
Member: 97899
Thanks Meter: 46
I have one CF62t with software version 85 from T-Mobile. Can anyone help me with solution for unlock without TestPoint, because I already have one dead CF62.......is it works with JavaŽ Patcher?!?
Old 03-21-2005, 16:46   #13 (permalink)
Member: 21920
Thanks Meter: 10
http://forum.gsmhosting.com/vbb/show...5&goto=newpost
Old 03-21-2005, 16:55   #14 (permalink)
TheBrain's Avatar
Member: 97899
Thanks Meter: 46
yes.....I saw ...........10x again
Old 04-18-2005, 00:30   #15 (permalink)
Crazy Poster
Member: 65962
Thanks Meter: 5
@asmar
many users trying your solution and shortcut 3 tracks in micro hole , after this solution have dangerous to broke cpu , i have 4 phones that need change cpu after this operation. the users cannot check how many tracks is cut , becouse if any track is short to other and other is right to cpu , tne red probe to ground and black to reader track show in muticet connected in cpu:-)
B.R.
@ all
not payed solutions of this , all that sell this is a cheaters
M55 dead after bad Cut Tp djibrilcoulibal E-Gold Based Phones 2 10-03-2009 03:37
CF62 Bad Cut Repair %100 Without Removing CPU.. LoveLess Siemens Hardware Repair Area 31 04-05-2009 09:59
Solution for MC60 Bad Cut on Testpoint without Removing CPU bojs Siemens Hardware Repair Area 6 05-07-2006 10:06
CF62 insert sim after bad cut classic mobiles Siemens Hardware Repair Area 2 08-21-2005 21:38
Any way To Revive S55 without Removing Cpu SoftSkiner E-Gold Based Phones 14 01-08-2004 23:34
Page generated in 0.26482 seconds with 10 queries
