Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
03-18-2005, 13:05 | #16 (permalink) | |
Freak Poster Join Date: Aug 2004 Location: f dewana Age: 43
Member: 79056 Status: Offline Thanks Meter: 149 | but u forgot to make ur pictur with solucion Quote:
ReGarD | |
The Following 3 Users Say Thank You to H@idour For This Useful Post: |
03-27-2005, 18:22 | #19 (permalink) |
No Life Poster Join Date: Sep 2004 Location: www.sevgigsm.net Erkan Yasar Age: 61
Member: 81576 Status: Offline Thanks Meter: 2,128 | cx65 speakır ways cx65 speakır wayssssssssssssssssssss |
The Following 3 Users Say Thank You to sevgigsm For This Useful Post: |
04-02-2005, 23:59 | #23 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | SEARCH MANUEL network it find or NEVER found? pls explain Try search network manuel and it jump agaın menu? İf u find and no found network CPU DAMAGED try and post result Last edited by BesTCooL; 04-03-2005 at 00:16. |
04-07-2005, 17:18 | #26 (permalink) | |
Insane Poster Join Date: Dec 2004 Age: 43
Member: 100195 Status: Offline Thanks Meter: 75 | hi Quote:
antenna sivitch | |
04-08-2005, 15:48 | #28 (permalink) |
Freak Poster Join Date: May 2003 Age: 48
Member: 29870 Status: Offline Thanks Meter: 24 | I have problem with SL55 display LED.This phone come with charge problem and i changed chargin transistor and now phone charge normally but no led .Thanks for any help. BR. |
04-09-2005, 10:11 | #29 (permalink) | |
Freak Poster Join Date: Dec 2002 Age: 41
Member: 18791 Status: Offline Sonork: 100.1577421 Thanks Meter: 74 | Quote:
I change it from c35 not work aslo from a2618 not work BR | |
04-16-2005, 20:12 | #30 (permalink) | |
Major Poster Join Date: Apr 2005 Location: Duisburg - Germany Age: 48
Member: 135968 Status: Offline Thanks Meter: 9 | Quote:
..if you have Phase Peak or Phase RMS error above 5 degrees, then it can be successfull, but not realy. If 26 MHz does not work propperly your phone cant sync to the BS. No Network can be found, but low network doesent match. (Check out with Rhode&Schwarz CMU200 or Wavetec GSM-Tester ) But with WinSui or with X-Focus you can change the AFC-Key value for the 26MHz oszillator. I had never low Network becouse the 26MHz oszillator. Try following: Check out different provider-cards (with GSM 900 and such with PCN (GSM1800)) Same problem on both? If not - try RX Path between diplexer and RF-Chip. (you need to Know on witch Network the failure occured, and you need shematics) If yes - try to change the diplexer or the RF IC. If you have booted a complete flashimmage from another phone, it could happend, that you have overwritten the adjusted RF values such as AFC-Key, TX-PWM Key, RX/TX values ect. with wrong values. Every Phone need to be adjusted at production, becouse the hardware has different tolerances. greets | |
The Following User Says Thank You to 424owe For This Useful Post: |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
New All Special Hardware Tool | simtech | Nokia Hardware & Hardware Repair | 29 | 03-08-2010 01:34 |
New All Special Hardware Tool | gopalhot | Nokia Hardware & Hardware Repair | 16 | 07-24-2008 08:20 |
