Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens Hardware Repair Area
Siemens Hardware Repair Area all about Hardware Repairing you can get if here.
Old 09-17-2010, 19:19   #661 (permalink)
Member: 173206
Thanks Meter: 44
Originally Posted by kstgr View Post
Hi. I have a Siemens M65.
The problems started when it randomly powered off. I checked the battery and the battery connectors on the pcb and found them ok.
Some time later it powered on and powered off after a few seconds.
Later, it didn't power on unless I applied some pressure with my hands.
Now when I press the power on key it just beeps but nothing happens.
Can you help me please?
Rehot ic infineon
regards
Old 09-17-2010, 19:59   #662 (permalink)
Member: 1390666
Thank you for your help!
Could you tell me how I can do it?
Old 11-04-2010, 08:03   #663 (permalink)
Member: 1268620
Sonork: bincy
Thanks Meter: 6
Dear brother;
I have one complaint u6, the complaint is ear piece is not working. Please give me solution.
Thanking you;
The Following User Says Thank You to bincythomas For This Useful Post:
Old 01-31-2011, 20:25   #664 (permalink)
muhammad khalid's Avatar
Member: 313337
Sonork: 100.1582697
Thanks Meter: 106
s65 white screen me too
Old 04-16-2011, 20:39   #665 (permalink)
Member: 1557478
Hi, I urgently need SIEMENS SOFTWARE compatible with UFSHWK box
Thank you for your quick reply
Old 06-12-2011, 11:23   #666 (permalink)
Moderator
sayed tarik's Avatar
Member: 1566464
Sonork: 100.1611207
Thanks Meter: 929
nice post sir............
Old 06-26-2011, 12:16   #667 (permalink)
Member: 1137245
Sonork: 123456
Thanks Meter: 2
thanks for all<<<<<<<<,,
Old 10-30-2011, 08:44   #668 (permalink)
Member: 1186634
Thanks Meter: 11
hi to all,
i received siemens s1 is display not working
Old 10-30-2011, 08:45   #669 (permalink)
Member: 1186634
Thanks Meter: 11
thank you boss for good shaiing
Old 01-14-2012, 05:47   #670 (permalink)
Member: 1525220
Thanks Meter: 5
china mobile yxtel x88 betery low shat down help me sir
Old 04-08-2012, 10:58   #671 (permalink)
Member: 599682
Siems bq SXG 75
Siemens benq SXG 75 INVALID BATTERY
when power on show invalid battery and no keys function .no water damage i have change many battery and clean pcb several time but no change pls help for any solution . Thanks
Old 04-10-2012, 07:39   #672 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
...you need to use only EBA-750 battery. Using other types of the Siemens battery -> GIVE THIS ERROR!
dagos
Old 08-04-2012, 14:40   #673 (permalink)
Member: 1793258
Thanks Meter: 3
Originally Posted by sevgigsm View Post
http://www.lumeamobila.ro/placi.php
a50 charge problem
picture repair download
good sir thank you..................................sir
Old 08-22-2013, 15:27   #674 (permalink)
Member: 2003015
Thanks Meter: 3
thanks 4 u'r replay bro
Old 06-19-2014, 06:35   #675 (permalink)
Member: 480803
I got a problem with my A60 form time to time. It can't log into the the network, the signal bar on the left of the screen flashes (it has 3 full lines), it says "Limited service" -can't send text or call or receive calls. Its not the Sim , battery or the carrier (tested all those in other phone and they work fine). What could be the fault here?
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
New All Special Hardware Tool simtech Nokia Hardware & Hardware Repair 29 03-08-2010 01:34
New All Special Hardware Tool gopalhot Nokia Hardware & Hardware Repair 16 07-24-2008 08:20
Page generated in 0.19919 seconds with 10 queries
