Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
02-17-2004, 04:36 | #1 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | ReAL ExPeRtS help needed ... c55 powering off itself i received one c55 with this sympthom : phone working ok ... you play with it ... all ok u put it on charger ... all ok disconnect it from charger .. put it alone ... no touching .. phone lights goes off in fade ... and ... from the speaker i hear short BZZZZ and phone goes off ... so ... what i did : - flashed new SW, full flash etc. - flashed eeprom and SWUP after, repaired imei still the same ... hardware part ... - changed 26Mhz oscillator - changed Dialog IC - canged RAM memory - changed CPU what else should I change ? only one thing left ... Flash RAM ... there is also one strange thing ... when making a call ... i can hear PA working bz-bz-bz ... like when u put phone close to some radio ... but call establishing and recieving work normally .. when left without touching keypad ... lights go off ... and phone after few secs. so ... anybody with some idea ? maybe RF cpu in the middle part of phone is bad ... or ... better idea is that the power management system in phone is bad but ... what controls it ? everything is changed already and still the same .. waiting for ideas b.r. Alexandar. |
02-17-2004, 12:38 | #3 (permalink) |
Moderator Join Date: Sep 2002 Location: Serbia/Hungary Age: 42
Member: 15994 Status: Offline Thanks Meter: 263 | I got one too with same problem... I repaired it with full flashing it to v21 ... there are some differences about hw and sw versions ... after that everything is ok ... and yes i rehoted the flash... |
02-24-2004, 14:24 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | HOLY COW !!! this is real working solution ... tnx a lot B0BA !!! so ... i did a little analysis ... phone starts up ... you play with it ... and it dont check RTC state ... and when you left it alone .... power management do its job ... power off the display and after that RTC state is checked ... and reported as bad ... so the CPU itself swithc it off because of hardware failure .. heh ... little OS .... with interrupts ... cool ... this is really usefull thread tnx again b0bA b.r. Alexandar. |
02-24-2004, 14:37 | #7 (permalink) |
02-25-2004, 14:08 | #10 (permalink) |
Freak Poster Join Date: Jan 2003 Location: SL 550 Age: 48
Member: 20490 Status: Offline Thanks Meter: 3 | It's history man.Look here: http://forum.gsmhosting.com/vbb/show...ght=c55+switch "This is the story, exactly! 1.I flash/eeprom/log/map/load map it to V18(same flash ic hardware=software) and same problem! 2.I change RTC & without testing i reball Dialog IC. Now everything OK at 101%." |
07-05-2004, 15:12 | #11 (permalink) |
Junior Member Join Date: Jun 2004 Age: 45
Member: 70391 Status: Offline Thanks Meter: 0 | Iam having a different problem with C55, by presing key 3 and 4 phone goes off, i have replaced 32MHz crystal still not found ok same problem persists.. any solutions Thanx |
07-05-2004, 17:18 | #12 (permalink) | |
No Life Poster Join Date: May 2004 Location: Bandung-Flasher.com
Member: 65947 Status: Offline Thanks Meter: 135 | Quote:
WBR | |
E65 power off itself ,help please | gsmfriend | Nokia Hardware & Hardware Repair | 4 | 05-23-2009 07:55 |
*** power on with red light and power off itself | george gsm | BF, BG, TH, BHx Series | 1 | 03-27-2006 13:03 |
C55 powers off when leds off | sjakie | Siemens Hardware Repair Area | 0 | 05-01-2003 13:07 |
5510 powers off itself - need help | SVH | Nokia Hardware & Hardware Repair | 8 | 03-12-2003 21:16 |
Neptune Power Off itself | andrew_gsm | Mitsubishi | 1 | 07-28-2002 23:51 |
