Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
09-16-2002, 23:36 | #1 (permalink) |
Freak Poster Join Date: Nov 2001
Member: 7159 Status: Offline Thanks Meter: 1 | siemens c35 no network - please help 1)reflash phone - without success 2)write new eeprom - without success 3) replace antenn switcher - without success 4) replace 4 box after switcher - - without success 5) replace big chip under second shield - - without success still no network.... anybody can help ? thanks ! Andrey |
09-25-2002, 17:05 | #2 (permalink) |
Insane Poster Join Date: Mar 2002 Age: 44
Member: 10127 Status: Offline Thanks Meter: 1 | I have 2 C35 with the same problem. They fall to ground and after that the PCB was bent a little. By the first test the phone had found network but looses it permanently or shows ! before provider name. On the flickering lights I could see that the PA works. Antenna is OK. After 3 or 5 tests the phone has absolutely no network (always searching for network) but none found. I rehottet the phone with hot-air but no result, still no network. I think PCB is broken. Is there any default connection that brokes when phone falls to ground? Both phones worked fine before. Anyone has the samo problem? Any solution for this? |
nokia 6270 no network please help me work in airtel but no work aircel | prakash40 | Nokia Hardware & Hardware Repair | 0 | 02-04-2010 06:24 |
Siemens C35 No Network | 13061972 | x1x to x45/x50 | 4 | 07-10-2002 05:38 |
8210 no network...please help | sidharthaharish | Nokia Hardware & Hardware Repair | 2 | 03-16-2002 06:44 |
Siemens C35 No Network | Williamcwy | Siemens Hardware Repair Area | 1 | 02-18-2002 08:59 |
Siemens C35 no Network | jivkobg | x1x to x45/x50 | 5 | 10-17-2001 10:50 |
