Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
05-22-2003, 19:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Ukraine. Lviv Age: 43
Member: 19633 Status: Offline Thanks Meter: 13 | Siemens S25 charge problem I resive S25. It charge feu second and stop. I chek battery and charger they is Ok. Did any have thys prob and knou hove to solve it? Thenks. |
05-23-2003, 10:50 | #5 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Hong Kong
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | Well I remember there is an old proggy for the battery calibration from siemens ( not for cms35) like all25 , if you still can't fix that by battery parameter adjustment, then it should be CPU problem, as siemens infinion CPU integrate the charger managing system with it. |
05-25-2003, 23:24 | #6 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Beograd,Serbia Age: 54
Member: 3101 Status: Offline Thanks Meter: 6 | When you open the phone near flat cable which comes in non-display-keyboard part you have a little white fuse-check that fuse ,if it is not in short circuit -put a wire instead.It is the common problem for S25 |
05-27-2003, 09:50 | #7 (permalink) |
Member: 19633 Status: Offline Thanks Meter: 13 | 2 Ssatan Stiupit idea. 2 Bert bat walue is Ok... 2 NBG Fuz cheked, its Ok. But problem same Is any whu have service manual for S25? Pleas sent it to me. I can`t finde it on net Thenks 2 all. |
Siemens A70 charging problems | Martey Stephen | Siemens Hardware Repair Area | 0 | 11-30-2006 11:20 |
Siemens CF62 charging problem | opo | Siemens Hardware Repair Area | 6 | 07-31-2006 15:08 |
siemens a52 charging problem | vio | Siemens Hardware Repair Area | 2 | 08-15-2004 01:48 |
siemens SL45 charging problem | manijak | Siemens Hardware Repair Area | 3 | 06-20-2003 02:01 |
Siemens S25 charge fault. | Pandemonio100 | Siemens Hardware Repair Area | 2 | 06-11-2001 08:53 |
