SL55 when Dor is open phone worked IF closed powered off after 20 sec solution SL55 when Dor is open phone worked IF closed powered off after 20 sec solution : open phone and desconnect flat and reconnect it again enjoy |
try to unlock the phone. good luck |
What is this flat. Please can you be more clear? thanks |
thx chris02 to explain right i mean flex cable |
try to change 26 mhz osc if flex is good |
After unlock it with the TEST POINT .. u have this problem .???? if yes just clean because u have contact in 2 point try to clean IT ReGards .. SuDDa 1mē:D |
I had this problem twice. Each time it was dead upper board. |
