Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
View Poll Results: is this way for repairing | |||
good | 8 | 50.00% | |
usefull | 7 | 43.75% | |
useless | 1 | 6.25% | |
Multiple Choice Poll. Voters: 16. You may not vote on this poll |
01-08-2005, 20:37 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: lebanon-tripoli
Member: 18966 Status: Offline Thanks Meter: 59 | my way for repairing insert card on cf62 after bad cut tp without removing cpu i don't know if this way is usefull if more then one line are cutting from sim card to cpu any way i shared it the idea come from reballing flash or ccont etc ... with solder glue so i put some from that solder glue where i cut & with a pin i pressed on it i clean the board from that solder than i use the hot air to rehot the solder glue . then i mesure btw pin 6 (sim) and the line (tp) no contact ok mesure btw all pin's off sim card no contact ok mesure btw pin 6 and mass no contact ok then i success my phone see the sim & evry thing is ok sorry for my bad english i hope this post can help |
01-10-2005, 05:45 | #3 (permalink) |
Major Poster Join Date: Jan 2003 Location: alex of egypt Age: 53
Member: 20500 Status: Offline Thanks Meter: 4 | i did that and it works well 100/100 but just use good flux when you do that and without check all this mesurments just try phone it will tell you the results to me it is the most savely way to repair it |
01-11-2005, 22:44 | #4 (permalink) | |
Member: 18966 Status: Offline Thanks Meter: 59 | Quote:
all thoose mesurments coz u don't know what did u cut so for more protection phone | |
01-13-2005, 19:59 | #5 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | no need to link cpu and sim pin6 I used a jumper wire to link the cut i made and the bad cut was repaired. Just solder a neat wire on the cut and the fone is ok. |
03-06-2005, 20:08 | #7 (permalink) | |
good luck | |
03-18-2005, 21:33 | #8 (permalink) |
Crazy Poster Join Date: May 2004
Member: 65962 Status: Offline Thanks Meter: 5 | heheh , this is a very stupid solution . Many bad cut phones , that i repair are with 2-3 tracks. This solution cant help :-)) The true is a 2 or 3 jumpers from CPU to SIM Reader. T16 -> simreset ,U15 ->simdata,T13 -> sim clock .That's all. B.R. to all testers :-) p.s. yesterday , i receive 2 phones with this damned solution and waste time to repair this bul****s :-((( |
03-18-2005, 22:18 | #9 (permalink) | |
line cut . read this post if u don't have time Quote: Originally Posted by klaos if u cut more than one line between simcard reader and cpu? do u have solution for this? i think sir u must remove cpu & make jumper good luck so any way i am sorry if u wast time so please forgive me | |
03-21-2005, 16:24 | #12 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Inside Your Mind Age: 38
Member: 97899 Status: Offline Thanks Meter: 46 | I have one CF62t with software version 85 from T-Mobile. Can anyone help me with solution for unlock without TestPoint, because I already have one dead CF62.......is it works with JavaŽ Patcher?!? |
04-18-2005, 00:30 | #15 (permalink) |
Member: 65962 Status: Offline Thanks Meter: 5 | @asmar many users trying your solution and shortcut 3 tracks in micro hole , after this solution have dangerous to broke cpu , i have 4 phones that need change cpu after this operation. the users cannot check how many tracks is cut , becouse if any track is short to other and other is right to cpu , tne red probe to ground and black to reader track show in muticet connected in cpu:-) B.R. @ all not payed solutions of this , all that sell this is a cheaters |
M55 dead after bad Cut Tp | djibrilcoulibal | E-Gold Based Phones | 2 | 10-03-2009 03:37 |
CF62 Bad Cut Repair %100 Without Removing CPU.. | LoveLess | Siemens Hardware Repair Area | 31 | 04-05-2009 09:59 |
Solution for MC60 Bad Cut on Testpoint without Removing CPU | bojs | Siemens Hardware Repair Area | 6 | 05-07-2006 10:06 |
CF62 insert sim after bad cut | classic mobiles | Siemens Hardware Repair Area | 2 | 08-21-2005 21:38 |
Any way To Revive S55 without Removing Cpu | SoftSkiner | E-Gold Based Phones | 14 | 01-08-2004 23:34 |
