Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
08-24-2006, 22:08 | #1 (permalink) |
Major Poster Join Date: Apr 2005 Location: Duisburg - Germany Age: 48
Member: 135968 Status: Offline Thanks Meter: 9 | Tip for keypad problems... If you are able to use a diode tester you can test every connection to the Gold like keypads. Connect the digital multimeter with + to GND and - to the keypad (of couse the mobile MUST be out of every voltage!!) If the connection to the Gold is OK you will get ca. 2,5V on the digits. If you change the direction you must get a "-OF" in the display. If you get "-OF" with both directions, the connection to the Gold is not OK, and you might to rehot the Gold or sth else. Note: If there is a cold ball @Gold always more than one Key is not working! If ther is a cold ball, then a complete row or a line on the Keypad-matrix will not work! If only one or two Keys are not working , you should spend no time on reheating the Gold. greets from rainy Duisburg Last edited by 424owe; 08-24-2006 at 22:18. |
08-28-2006, 13:03 | #2 (permalink) |
Freak Poster Join Date: Dec 2002 Location: ****land full of cheater Age: 48
Member: 18948 Status: Offline Thanks Meter: 53 | Sometime Rehot Not help. Reballing is the only solution. But Cant find New PMB's (in your Word "GOLD") stencil to reballing in Market. So be carefult for not to Screwed Up the Phone. |
6700c keypad problem | luyanda | Nokia Hardware & Hardware Repair | 20 | 04-09-2014 10:16 |
some tips for 3310 no network | flashman | Nokia Hardware & Hardware Repair | 18 | 01-10-2010 07:38 |
Manners Made Easy for the Family: 365 Timeless Etiquette Tips for Every Occasion | IPMART | ipmart WebShop | 0 | 10-13-2009 14:00 |
Tip for repairing cut CPU lines | Scaramouche | Nokia Hardware & Hardware Repair | 3 | 12-19-2002 09:35 |
Do you know trick and tips for SGH-Q100 | aLeN27 | Trident/AGERE Platform | 0 | 04-19-2002 06:37 |
