Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > DIV
Old 06-19-2004, 22:52   #1 (permalink)
koksi's Avatar
Member: 19575
2x t630 4locks closed
anybody know a solution for this modell
it is an RC4003 SW
i tryed Divusb 4.0
otp imei, 4locks closing repair ... with as t630 and t610?
Div writing all ok, but nothing ok
Old 06-19-2004, 23:26   #2 (permalink)
shaaker's Avatar
Member: 23695
Sonork: 100.64383
Try again with 3.1 select rebuild SPlock area using OTP imei
Old 06-20-2004, 00:07   #3 (permalink)
koksi's Avatar
Member: 19575
not working also tested as t610
Old 06-20-2004, 00:21   #4 (permalink)
Member: 31028
try with div 8.4
try to unlock, unlock using otp imei, and yes try to repair 4locks closed, but unlock should be enough... i tested once on div 8.4 chosen as t610 and it did repair
regards
Old 06-20-2004, 01:27   #5 (permalink)
HONGXING's Avatar
Member: 33079
Choose "Read all codes" and T610 using DIV 8.4 :-)
Old 06-20-2004, 16:58   #6 (permalink)
koksi's Avatar
Member: 19575
i had repair to t630 with terminator dongel
but the problem is that i have no one here
hmm this is bad
Old 06-20-2004, 17:07   #7 (permalink)
Member: 45682
hi
i think only fighter repair and unlock it 100 %
br
Old 06-21-2004, 02:27   #8 (permalink)
HONGXING's Avatar
Member: 33079
hmm this is bad
Try my solution. I already opened 4 locks with this.
Just select T610 and choose "Read all codes" several times.
Old 06-24-2004, 19:26   #9 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
New T630 Phones have another Boot type
Its easy to unlock Them
You have to Full Flash it if you find the Full Flashes,,, then its good
New T630 phones ,, that are very New !!! (Test Point method) as i heard !!! these have Different Boot
Old 07-09-2004, 21:36   #10 (permalink)
Member: 71738
just reset gdfs i try and tested it my self works perfect
Old 07-11-2004, 21:28   #11 (permalink)
SJS
SJS's Avatar
Member: 14684
I have the same problem! The only solution thats work for me is flash with t630r4c003 emea 1 imei patched. i flash with this and phone will work, but no german language. If i flash with other flash file (german), the phone show 4 locks closed and can not repair.
I try with all solutions but nothing. Is a patched flashfile available with german language?
Regards!!
2x T630 charging but battery always empty piracik Sony Ericsson 1 09-28-2007 15:11
nokia 3310 4.45 4lock closed+contactservice+imei changed please help sidharthaharish Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 14 02-04-2007 04:29
2x t630 charge problem Destructor Sony Ericsson Hardware Repair Area 1 09-25-2004 22:29
T630- 4locks... Steph DIV 4 05-12-2004 19:12
3310 Sometime 4lockes closed ARC Nokia Hardware & Hardware-Repair Area 9 03-25-2002 07:28
Page generated in 0.40470 seconds with 11 queries
