convert fighter flash files to DIV usb flash file HI, I have a lot of fighter flash files which div usb doesn't work with. Is there a program to convert it? Thanks. |
Pls check it again!!! |
Link is up :) When page fully loaded ( you still won't see anything ), save it on local drive, and open it from there. |
That page explain converting from bin to sbn or bis, not for Flp. |
I still cannot find the solution here. |
Why can't i run Bin2sbn in os 98 ??? when running i just see a window popup then disappear tried in XP ox not help ! pls. help me ! thanks alot . |
it's a command line application, not a windows application. You have to run it from a dos box |
ok thanx ! I'll try it again in real dos Box Wbr. ! |
Yes, that is a very sad thing |
because they are not computer scientist. :) |
You do not need to be a computer scientist to use a dos prompt. 4 commands are all you need to know c: (change to the C drive) cd\ (change to the root of the C drive) cd folder (go into a folder) dir (get a folder listing) Then just type the name of the program you want to run. It's not rocket science. |
I 've successfullly run it in windows Xp what I do is putting tool n files to be converted in right folder n start CMD now i can read n write convert everything thanks ! Wbr. |
