Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > DIV
Old 11-30-2004, 00:58   #1 (permalink)
Member: 88444
USB DIV key not found error
I am using Windows XP and Div 5.0. I made sure that I run userport.exe.
When I double click on the Div 5.0 exe file, it says "Div Usb key not found". What could be the problem?
Also, When I try to open Div 8.4, it says "Terminator not found". I dropped "NTPORTIO.sys" in c:\windows\system32\drivers directory.
Please help.
Old 12-01-2004, 22:13   #2 (permalink)
Member: 83477
Try this, run userport, press start, then press stop, then run div usb.
Old 12-01-2004, 22:30   #3 (permalink)
bungle_uk's Avatar
Member: 51154
Make sure your Terminator dongle is plugged in securely and the power cable connected to your USB socket
Old 12-02-2004, 04:09   #4 (permalink)
Member: 88444
I made sure that my dongle is connected well and inserted the USB end into the socket. I also cleaned the connecting parts.
Old 12-02-2004, 05:35   #5 (permalink)
bungle_uk's Avatar
Member: 51154
Sounds like either your dongle is dead, or you have a TotalTools dongle instead. DId you buy this recently, or has this problem just occurred ?
Old 12-07-2004, 00:06   #6 (permalink)
Member: 88444
I didn't have any problem with this dongle before. No it is not TotalTools dongle. In fact, I used this dongle one day before I started having this problem.
Old 12-07-2004, 03:55   #7 (permalink)
Joselord's Avatar
Member: 73798
I also have problem with XP.. have terminator using ME with no problem.... now Im using XP and gives me "Privileged Instruction" then press: Do the JOb and nothing happens....
Old 12-07-2004, 05:45   #8 (permalink)
bungle_uk's Avatar
Member: 51154
OK, here's another method then if UserPort does not work), run Div 8.4 first , then run DivLPT 5.0 (keep Div 8.4 running - don't close it). See if that works
Old 12-07-2004, 07:57   #9 (permalink)
huzsolt's Avatar
Member: 75392
Sonork: 100.81199
Didn't you made a bios reset before you start to have troubles with Div?
Try to play with bios paralel settings. I had troubles with Totalmoto, and after a some settings in bios it worked OK. Total Moto olso uses paralel dongle with usb adaptor...
Old 12-08-2004, 20:09   #10 (permalink)
Joselord's Avatar
Member: 73798
I try opening 8.4 then div 5 and doesnt give me Privileged Instruction no more... but know it gives me error 0111
Old 12-10-2004, 15:51   #11 (permalink)
Joselord's Avatar
Member: 73798
Finally...Fix it. I checked that all port setting and bios were ok. Put userport.exe, ntportio in same folder as div5 and userport.sys in Windows/system32/driver. Start userport and give at least 10sec (you can close it but dont press "stop") then open Div5 and everything ok..... If this doesnt work then you have a faulty dongle, and how to make sure, try it in another computer.
Thanks to Bungle
FYI I have Windows XP SP2.
Old 12-10-2004, 16:02   #12 (permalink)
bungle_uk's Avatar
Member: 51154
Glad you got it sorted
WBR
Repairing redbox with key not found or sn error ::.::HITGSM::.:: Redbox 1 10-31-2005 06:27
ERROR! KEY not found! med9306 DELOK DONGLE 9 03-17-2005 17:35
Error 0001, key not found!!!!!!!!!! afloat DELOK DONGLE 2 10-06-2004 20:58
Help!! Delok: Error 0001. Key not found!! david69 DELOK DONGLE 17 09-16-2004 22:59
Delok - ERROR! Key not found! fingusio Philips 5 07-19-2004 21:27
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.39111 seconds with 10 queries
