05-22-2004, 05:44 | #1 (permalink) |
No Life Poster Join Date: Sep 1999 Location: Europe Age: 43
Member: 461 Status: Offline Thanks Meter: 2 | 3660 blank screen after rebuild write imei at uem...ok write imei at flash...ok. phone can't power on. i try write erase fia files, not help. if i install new uem ic , i can power on phone without any problem only imei is ?????. I don't have any problems with nokia 3650. May you have solution to help ? |
05-23-2004, 19:59 | #2 (permalink) |
Registered User Join Date: May 2004 Location: Lebanon Age: 44
Member: 65294 Status: Offline Thanks Meter: 11 | bro well even u r writting the wrong asic type...maybe they r mixed and not ur fault or the uems are bad as well try it again with different rpl and u will know if the uems are bad or not ...by the way when u turn the phone on before writting the rpl ...do it stay powered up till u turn it off or do it turn off after 30 seconds ? check this too if it is like this then it is 100% from uem regards |
05-24-2004, 08:31 | #3 (permalink) |
Member: 461 Status: Offline Thanks Meter: 2 | thanks about reply. I tryed with 5 uem ic for 5 different asic 5 rpl files, not helped my uem ic is good, i have tested in many others phones all is ok. Phone after change uem ic work fine, without power off after 30 sec.but if i try write imei i have this problem. I tested with one 3650 , all is fine , imei write ok. , but with 3660 trouble May i need special rpl file for 3660 ? may any have this ? |
05-26-2004, 01:31 | #4 (permalink) |
Member: 65294 Status: Offline Thanks Meter: 11 | well dunno bro i got confused about if it is a hardware problem or a software one try to contact ALMOUDAMER he is good in such tricks and he will solve this for u for sure ...find him in the forum and contact him regards... |
05-26-2004, 12:36 | #7 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Nokia 3660 and Nokia 3650 is not same phone ,and you cant use RPL for 3650 to rebuild 3660. This problem you can solve using Griffin server. If you need to buy some RPL files just contact me on ICQ 97661827. Regards |
05-26-2004, 12:39 | #8 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | My 3660 RPLs will be of no use to you as UEM ID is coded into the RPL. Sorry. Better purchase Online Logger or have someone with Nokia account make rpl for you. |
05-27-2004, 05:04 | #10 (permalink) |
Major Poster Join Date: Feb 2004 Age: 47
Member: 51636 Status: Offline Thanks Meter: 1 | To comfirm with this problem, try manual flash your phone with 3650 firmware. If this firmware work, then 100% is wrong RPL. Because 3650 flash with 3660 firmware will cause phone dead. |
11-11-2004, 07:37 | #12 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: La Paz Age: 53
Member: 17431 Status: Offline Thanks Meter: 22 | Quote:
BR, LogoMan | |
5210 Blank Screen after flash | mobileanalyser | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 09-22-2006 16:49 |
3660 blank screen after rebuild | jonwillow | WD2 & APE (Symbian Phones) | 4 | 05-18-2005 17:14 |
3660 blank screen after rebuild | jonwillow | WD2 & APE (Symbian Phones) | 4 | 10-05-2004 00:49 |
t100 blank screen after flash | Moosani | VLSI, Conexant, Skyworks and Old Models | 1 | 04-11-2003 20:30 |
3610 blank screen after start (hang) | Moosani | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 03-14-2003 05:30 |
