02-19-2005, 08:50 | #1 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Ukraine, Simferopol Age: 53
Member: 7993 Status: Offline Thanks Meter: 40 | c62 client does not works properly on 70% of phones I got a problem - cannot connect phone to c62 client. Only with few phones all going ok, otherwise: Pressed "Check cable" button: Connect the correct phone!!! Power on the phone! Sending loader... Loader sent. Prepare for loader2... Loader 2 OK. Test1 in progress... Test1 OK. Test2 in progress... Test2 OK. Finished. After this pressed "boot" button: Power on the phone! Sending loader... Loader sent. Start problem:0003 HOW TO SOLVE THIS? |
02-19-2005, 09:13 | #2 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: Bosnia and Herzegovina Age: 50
Member: 6464 Status: Offline Thanks Meter: 6 | Quote:
There is not server problem for sure... Regards Shiljo | |
02-19-2005, 11:02 | #4 (permalink) |
Member: 7993 Status: Offline Thanks Meter: 40 | So I tried 3 totally different cables (MAX207, MAX232 and china made cable) on 2 different PCs - got the same bullsh@t. I don't think that it is my cable problem. Just forget to say - tried on 4 phones Last edited by uu1dx; 02-19-2005 at 11:16. |
02-19-2005, 11:46 | #5 (permalink) | |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Quote:
If your cable dont have power suply, this problem is normal. BR | |
02-19-2005, 15:11 | #6 (permalink) |
Member: 7993 Status: Offline Thanks Meter: 40 | Buddy, do you really think I am idiot? 2 of them is externally powered. Also tried to change resistor value from 0.5 up to 10 kiloohms - no luck. |
02-21-2005, 09:31 | #7 (permalink) |
Member: 7993 Status: Offline Thanks Meter: 40 | Tried 2 more cables and 4 more phones... I think there is a bug in software. Tests is OK but satrt problem 0003 when booting. :-( Badly need to do something to make the SW working. |
02-21-2005, 10:41 | #9 (permalink) | |
Mabe you are use old version of software? Latest version is 1.017 BR | |
02-21-2005, 11:47 | #10 (permalink) |
Member: 7993 Status: Offline Thanks Meter: 40 | @Legija: I see how perfectly it does work :-) 2 PCs, 5 different boxes, 8 phones, Win98 and WinXP - cannot boot any of that phones, even a brand new working one. Griffin C62 unlocker works well, flashing with flash programmer works well, only this SW is perfectly unable to connect phone... @SoftMobile: yes, using 1.017 and also tried 1.013 - no luck |
02-21-2005, 12:09 | #12 (permalink) | |
Do not use old versions, because is not work with v28. In the zip file which you are download have also user manuals or just folow Legija instructions. BR | |
02-23-2005, 10:53 | #13 (permalink) |
Freak Poster Join Date: Jun 2001 Location: BULGARIA
Member: 4931 Status: Offline Thanks Meter: 1 | I have this problem too. I use V1017 . Cable work perfectly with FlashProgramer. Test with C62 v18,20,26 . Test in two different PC in 98' and XP : Power on the phone! Sending loader... Loader sent. Start problem:0003 |
04-25-2005, 15:46 | #14 (permalink) |
Junior Member Join Date: Feb 2004
Member: 54901 Status: Offline Thanks Meter: 0 | i have same problem too. i have ext pow, i have already have made few of them but now it doesn't work. same error. I have tried to flash it but i get error 0002 88. i have also spent 4 logs on that phone so far... any solution? regards, zeljko |
e65 keypad ic does not work properly | amardeepsahi | Nokia Hardware & Hardware Repair | 16 | 09-21-2011 14:41 |
mt box could not work even on one single phone. | Miangee911 | MT-BOX | 1 | 03-28-2009 16:48 |
J400 unlocking does not work. Hangs on "Security" | James_S | UST Pro II | 1 | 06-14-2008 16:11 |
U6 after unlock keypad does not work properly | trentini | Smart-Clip | 2 | 11-21-2006 04:07 |
Crazzy unlocker v. 6 does not work properly | MG77 | NEC | 1 | 07-25-2005 09:02 |
