05-23-2004, 18:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | i can't make .ask file i choose calculate flash and UEM imei,i write manualy the IMEI but always i get the mesage: "read ok UEM imei:00000000000000" and after 2sec "operation failed" i had same problems with ather models also. |
05-24-2004, 00:04 | #3 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: Bosnia and Herzegovina Age: 50
Member: 6464 Status: Offline Thanks Meter: 6 | Quote:
Regards Shiljo | |
05-24-2004, 12:34 | #5 (permalink) | |
05-24-2004, 12:35 | #6 (permalink) | |
You are paying RPL calculation every time when you change UEM??? | |
05-24-2004, 22:07 | #8 (permalink) | |
How long you are using griffinbox? You can go to griffin official forum and there you will find links for RPL files! Also,in griffin support area you have "GriffinFlasherVersion2_03.pdf" file with instructions how to use IMEI repair function! I hope that all this will help you Regards Shiljo | |
05-25-2004, 01:28 | #9 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: Earth Age: 49
Member: 10387 Status: Offline Thanks Meter: 3 | Quote:
if need rpl file ,i can send to you | |
05-25-2004, 15:44 | #10 (permalink) |
Member: 26279 Status: Offline Thanks Meter: 274 | until now i was using the original method (i send ask to nokia) for imei rebuild. i can't write rpl to the phone i get all time error:"write imei to uem failed" |
05-25-2004, 15:59 | #11 (permalink) | |
2. If you are using griffin,did you made modification with 180ohm resistor? Phone must have Vcc 5V for UEM writing!!! | |
05-25-2004, 17:07 | #12 (permalink) |
Member: 26279 Status: Offline Thanks Meter: 274 | i'm using griffin box,i know that voltage must be excactly 5.1 volts(ressistor allready included) and still i can't do any repair imei/esn function (i allready tested on 3 models) |
05-25-2004, 17:46 | #13 (permalink) | |
Are your UEMs new/good/empty ? I made IMEI rebuild many times on different models without big problems...if your box,cables,connections and UEMs are OK,all must work without problems! | |
05-27-2004, 12:48 | #14 (permalink) |
Member: 26279 Status: Offline Thanks Meter: 274 | finaly the problem was on griffin box.with test VBATT i get 5.1 volts but when the cable was connecting to the phone voltage for imei rebuild was 0 volts. with other griffin box i rebuild imei succesfull. 10x all of you for the help |
05-27-2004, 13:03 | #15 (permalink) | |
Regards | |
Problem make ask file with 6630 | sarbi | MT-BOX | 1 | 11-04-2007 22:14 |
My MT-Box is dead and send back for replacement. How to make ask files? | doctormike | MT-BOX | 0 | 05-29-2007 13:47 |
How To Make Ask File With Using Griffin Log | υИқИΘШИ® | Griffin | 3 | 02-14-2007 16:32 |
Cant make ask file | C-Mobile | MT-BOX | 5 | 02-08-2007 14:34 |
How To Make Ask File And Write Rpl With Using Ufs Box | υИқИΘШИ® | HWK | 3 | 01-28-2007 11:54 |
