LG7050 Unable to connect to phone Please can someone tell me what I am doing wrong. I have LG7050 and orginal cable. When I try to read log with X70 logger it says 'power on' & I press on/off button & nothing happens, just keeps waiting as though phone is not been detected. I have tried 2 different original cables. I have used the logger to unlock X70 before without any problem. Is there any settings I need to changge?. Please I need help urgentley, cutomer waiting for the phone. I have spoken to my supplier, he says there is no setting to change & it should work. Any help will be very much appriciated. Thanks msa |
Why are you using Lg in X70 logger |
i've unlocked 2 or 3 using the logger |
Regards NADS |
Thanks to every one for or your kind help. msa |
@NADS Sorry I cant see where it tells me what vesion it is. All it says is Panasonic x70 log reader. I only got it about 4 weeks ago from Unik Source, they tells me it work fine for them with original cable. Thanks for your time. msa |
@ msa u read logfile then what? do u send log file to somebody or server? |
Yes you read log file ( if you are lucky) then you buy logs for Griffin server (you have to have Griffin box) & then send log file to server for it be calculated. once you recieve the log back you write to phone. Simple?, only if you can read the log from phone to start with. thanks msa |
Please has anbody else managed to unlock Lg7050 with X70 logger? if yes how. I need help. thanks |
