05-22-2004, 18:17 | #1 (permalink) |
Junior Member Join Date: May 2004 Age: 44
Member: 66438 Status: Offline Thanks Meter: 0 | Panasonic X70 unlock Problem Today i m buy 20log and i m just unlock X70. I m read code and send back the Server then i m receive the file and upload the phone again they show error. COM opened Power on phone Test Mode Entered IMEI: 351---------- Version: 102182100231460 ARUA_A552/03E X70 Unlock data found. Sending Timeout! Exiting... no response from phone F Timeout! Exiting... no response from phone F Timeout! Exiting... no response from phone F Unlock OK Any one gide me waht can i doo i m in troble. And i m use com cable. Best RegaRD kwh |
05-22-2004, 20:19 | #3 (permalink) |
Member: 66438 Status: Offline Thanks Meter: 0 | hi.. Thank You For your Help. I m Restart the computer but the problem is still. COM opened Power on phone Test Mode Entered IMEI: 351---------- Version: 102182100231460 ARUA_A552/03E X70 Unlock data found. Sending Timeout! Exiting... no response from phone F Timeout! Exiting... no response from phone F Timeout! Exiting... no response from phone F Unlock OK Plz anyone solve my problem. i m lose my business. bye |
05-23-2004, 12:32 | #5 (permalink) |
No Life Poster Join Date: Dec 2000 Location: uk
Member: 2899 Status: Offline Thanks Meter: 6 | kwh hi i had the same problem,i found out by try and error that it was my lead!!i was using an extention connected to the lead but when i used the lead by itself it was fine,try obtaining a new lead mine was factory made.i tried changing rts and dtr it was giving error still,i hope that helps. br farry |
05-23-2004, 15:58 | #6 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Hi, Some of Panasonic cables work OK ,but some of them is substituted RX and TX pins. Open the cable and replace RX and TX . This is the right pinout, KEYBORD UP [] 1 2 [] 1 2 3 4 5 6 7 8 9 10 11 12 [] NORMAL RS232 DATA CABLE 3 VOLT INTERFACE FOR CONECTOR US ALCATEL OT320 OR MOTOROLA V66 JUST NEED TO CUT FROM I SIDE 12 GND 11 RX PHONE 10 TX PHONE and need to add extar power to interface . Regards |
05-23-2004, 16:20 | #7 (permalink) |
Member: 66438 Status: Offline Thanks Meter: 0 | @softmobile. Thank you for yuour reply. I have 2 original cable but the problem is still . I have its original connector can i use this connector and made the cable. Because my original cable have no any Extra Powe Lead. bye |
05-24-2004, 10:39 | #9 (permalink) |
Member: 66438 Status: Offline Thanks Meter: 0 | @essojay Hello thanx for reply i m use original cable but the problem is still. can u send me the original pinouts. Because i m use that cable have not external power. bye |
05-27-2004, 17:48 | #10 (permalink) |
Member: 2899 Status: Offline Thanks Meter: 6 | khw hi my cable is factory made,therefore i dont have the pinouts,also it hasnt got external power,so i would suggest to buy a factory made one,cos i had a problem like yours! br farry |
05-27-2004, 22:16 | #11 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | try on other pc change your computer & also check ur Com1 port setting ( Check Speed of com port ) do default Check & Post results |
Panasonic X70 strange problem | payne | Panasonic | 6 | 11-08-2006 15:23 |
Panasonic X70 Unlocking Problems | axilleask | Griffin | 3 | 11-18-2004 11:45 |
Panasonic X70 camera problem after unlock? | DanV | Panasonic | 2 | 06-30-2004 13:34 |
Panasonic X70 unlocking and all Nokia. Networkunlock!!! | Networkunlock | Main Sales Section | 0 | 01-16-2004 13:18 |
Panasonic X70 unlocker | millpc | Wanted Products | 4 | 01-08-2004 19:35 |
