09-26-2003, 21:44 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: 9 JA
Member: 30405 Status: Offline Thanks Meter: 3 | Problem in flashing 7650 with griffin! can some one give me a solution and procedure to solve this problem. ThanXXXXXX |
09-27-2003, 10:02 | #3 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Bangladesh
Member: 37349 Status: Offline Sonork: 100.1613413 Thanks Meter: 362 | Solution [i hop it can help u] Post #2 of 2 Box is not activated or not original ---------------------- Try to update your box and reactive it. @Chinex14 Never ever do it.Because if your griffin clone then when you want to update or reactivate then your griffins clone program ic's may be damage forever.For your information i am a sufferer like that.So dont do it.Or if your box original than you can do it. proxy_gsm |
09-27-2003, 22:27 | #4 (permalink) |
Member: 30405 Status: Offline Thanks Meter: 3 | Problem in flashing 7650 with griffin!! when i on the box and run the software it shows box id :Efba and nothing more....and note: ive used it to unlock 7210,3510i and some other phones, but when i try to flash a fone with it shows erropr message : er 33333. i ve sent my activation file to [email protected] but they ve not replied me for two weeks now what do i do now????? |
09-27-2003, 23:10 | #5 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Croatia Age: 45
Member: 4185 Status: Offline Thanks Meter: 3 | Download install program griffin 2_02(install program) and install it.After that extract older griffin like 1984 and older to GRIFFIN folder and use it.(that works good without activation.) Your error is because griffin is not properly installed. I tell u to use older griffin software because if your box is fake it will be killed with new software.Use old version of grffin. |
10-03-2003, 00:38 | #7 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Re: Problem in flashing 7650 with griffin! Quote:
But for the full memory problem , you have to "format user area" before flashing ! Sometimes your user interface memory isn't really full so you just could fix it by flashing. Like on 3650 But in the most of cases , the full memory alert is a message which appears when you've reached the 4 Mo of memory with your own datas! -Outbox -Inbox -Calls register -Apps -Names -Pictures Max_B PS. I don't know if the "format user area" function is available on Griffin ? | |
10-03-2003, 01:13 | #9 (permalink) | |
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Quote:
For using this function you have to change your operating mode on local ! But sometimes the problem of switching off makes impossible changing in local mode. For resolving this trouble , you need to flash by downgrade (3.12 or 3.16) ; Once the procedure will be finished the 7650 should remain powered on with nokia start up logo . So you can try to put it first in TEST mode, and then secondly on LOCAL for being about to format user data. Now you can reflash it in 4.46 or 5.06 , for enhance the software ... But your job is finnished and your "Full Memory" Problem is cleared . GOOD LUCK ! Max_B | |
10-03-2003, 07:02 | #11 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | Error 2222222 and Error 33333333 are from bad FIA file structure.... download latest FIA files from griffin support site and install them then you will not get these errors.... WBR Syed |
10-04-2003, 02:36 | #12 (permalink) | |
But coud he resolve his problem by installing another phoenix flash update ? Max_B | |
Problem in flashing K310i with HWK 2.07 | PASSIONATE_BOYS | Sony Ericsson | 0 | 04-08-2008 13:02 |
Error[FFFF9000] when flashing 7650 with griffin | Ikky20022000 | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 08-11-2004 23:30 |
How to unlock 7650 with griffin | Fasterbaby | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 03-13-2003 09:56 |
can i flash 7650 with griffin | johnson094 | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 11-25-2002 19:31 |
