11-03-2004, 22:56 | #1 (permalink) |
Registered User Join Date: Sep 2002
Member: 15866 Status: Offline Thanks Meter: 192 | x70 unlocking problem phone becomes in test mode , error in transmitiing and at the end unlock ok but the phone still lock whats the problem is the my 2 credit has been lost and the problem still please it can be unlock or not or other problem is this and my logs waist |
11-04-2004, 07:23 | #3 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Next to the small lake, hunting crocodiles:-) Age: 51
Member: 50713 Status: Offline Thanks Meter: 0 | Did you read multiple logs in to one file? I've had this problem before and solved it by editing the unlock file. If this is your scenario I can help you. |
11-04-2004, 08:45 | #4 (permalink) |
No Life Poster Join Date: Feb 2003 Location: India Age: 39
Member: 20691 Status: Offline Thanks Meter: 20 | Yes Friend i have same Problem with X70 unlocking .... Log file readed successfully and also calculated prefectly with griffin server ... Problem is not able to write the unlock file to phone and have lost 2 credits. Please check this : Renamed existing logs file: C:\GTSv1.22\pX70mxn79.lx7 to C:\GTSv1.22\4188C0A2pX70mxn79.lx7 Griffin box found, SN: E******* COM opened Power on phone Test Mode Entered IMEI: 35341100035**** Version: 040682511313220 ARUA_A552/05A X70 Unlock data found. Sending Timeout! Exiting... no response from phone F F F Unlock OK COM opened Power on phone Test Mode Entered IMEI: 35341100035**** Version: 040682511313220 ARUA_A552/05A X70 Unlock data found. Sending Timeout! Exiting... no response from phone F F F Unlock OK But my phone is still not Unlocked ???????? Griffin Team ... Help us ! Now a days problems and problems with Griffin Server... Not able to unlock Sony-Eric phones, as well as problem with this X70 logs, and Griffin Team keeps on releasing new C62 clients and new models support, but the fact is they need to fix the existing problem with their server and then release the new updates... Regards, Tanvir ! www.tanuelectronics.com |
11-04-2004, 17:01 | #10 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | Can you tell me why ?. I could read the X70 log phones go into test mode and all is well, but when I try to write phone does not go into test mode (this is on my IBM laptop). I had to use my desktop to write the X70 log and unlock the phone. This is inconvinient for me, because I basically operate out of my car ( I go to the customers home ). can this be solved ?. |
11-04-2004, 18:41 | #12 (permalink) |
No Life Poster Join Date: Feb 2004 Location: PaKiStAn Age: 44
Member: 51639 Status: Offline Thanks Meter: 76 | oh Crap !!! now i need another PC to upload unlock log to phone, do you think its our PC vandor problem ? i am using Intel P4 2.4ghz (800mhz BUS) , please tell me what is wrong in my PC and why i can't upload the file to phone ?????? C:\X70LOGGER\pX70mxn79.lx7 Griffin box found, SN: F******* COM opened Power on phone Test Mode Entered IMEI: 35144310035**** Version: 04068******* ARUA_A552/05A X70 Unlock data found. Sending Timeout! Exiting... no response from phone F F F Unlock OK |
11-04-2004, 23:58 | #14 (permalink) |
Product Manager Join Date: Mar 2002 Location: On the Edge
Member: 10347 Status: Offline Thanks Meter: 14 | 1) Ensure that you box is fully activated and working with Griffin 2.0861. 2) Ensure that the latest logreader is used version 1.06 to make the log first. 3) Ensure you have the latest online client GT Access 1.22 4) Ensure you have a minimum of 2 credits remaining on your account. 5) Ensure your logfile is correct and is not carrying multiple logs (always delete old to make sure), this way no complaints...I sent 1 log and 10 credits used etc.... simple mistake we can all make. 6) When the log is calculated then write back to phone using latest logreader again 1.06 7) If you get error e/4 etc when sending your log to server using GT Access 1.22 then it is either a corrupt log or non-supported version. The new versions have hardware changes not only software so are not supported at present. This will not result in credits being used. Hope this all helps to solve the problems with X70. Regards NADS |
11-08-2004, 19:35 | #15 (permalink) |
Registered User Join Date: Nov 2001 Location: close to your mind Age: 53
Member: 7457 Status: Offline Thanks Meter: 21 | Mr. Nads, Can we use the cable which is given with furiousdonle.???? for griffin. if so.. I tried to made logs it's failed deduct the x70. |
X70 unlock problem | yas_cell | Griffin | 0 | 11-30-2004 12:02 |
Panasonic X70 Unlocking Problems | axilleask | Griffin | 3 | 11-18-2004 11:45 |
x70 unlock problem | dimon | Griffin | 2 | 10-21-2004 22:12 |
x70 unlock problem | e_mobile | Griffin | 9 | 09-25-2004 03:42 |
Panasonic X70 unlock Problem | kwh | Griffin | 11 | 06-01-2004 23:27 |
