Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Federal One
Federal One Federal One & Prodigy Support Section
Old 01-19-2007, 06:44   #1 (permalink)
Member: 137474
Sonork: 100.109924
Can't write RPL to 7373 cabel is ok this is software problem pleasse fix this !! !!
Hallo I can't write rpl to phone 7373 cabel is with resistor 7,5k on bsi and phone is in local mode all info cen be readed but only uploading NPC is error 1 time I upload NPC but cant rebuild and this is for sure problem with software plessse fix this !! !! Simlock data write to phone OK !! !!
This is log
00000000 0.00000000 [3296] pdg4fbus: DCT4_ReadPhoneInfoFbusA entry
00000001 0.01242862 [3296] pdg4fbus: index = 01
00000002 0.08810020 [3296] pdg4fbus: DCT4_ReadPhoneInfoFbusA ok
00000003 0.23178290 [3296] pdg4fbus: Get_PhoneModeFbus entry
00000004 0.23195757 [3296] pdg4fbus: index = 01
00000005 0.30094990 [3296] pdg4fbus: Get_PhoneModeFbus->mode is: LOCAL
00000006 0.30103230 [3296] pdg4fbus: Get_PhoneModeFbus ok.
00000007 9.12525272 [3296] pdg4fbus: BB5_ReadServerVersion->entry
00000008 9.18967819 [3296] pdg4fbus: BB5_ReadServerVersion->ok
00000009 9.19553566 [3296] pdg4fbus: ReadSLTablebb5->entry
00000010 9.28833103 [3296] pdg4fbus: ReadSLTablebb5->ok
00000011 21.52644157 [3296] CDct4Fls->BB5UploadNPC entry
00000012 21.52649307 [3296] CDct4Fls->SetDefaultTimesUSB entry
00000013 21.52654648 [3296] CDct4Fls->DelayData:
00000014 21.52658463 [3296] 0A 05 96 00 00 00
00000015 21.53440285 [3296] CDct4Fls->Switching to fast speed clock
00000016 21.54025078 [3296] CDct4Fls->SetBB5FlashMode entry
00000017 22.34986877 [3296] SetBB5FlashMode->BB5 Boot data:
00000018 22.34991264 [3296] 00 00
00000019 22.34996223 [3296] CDct4Fls->SetDefaultTimesUSB entry
00000020 22.35000038 [3296] CDct4Fls->DelayData:
00000021 22.35004044 [3296] 0A 05 96 00 00 00
00000022 22.35764503 [3296] CDct4Fls->Switching to fast speed clock
00000023 22.36350060 [3296] CDct4Fls->SetBB5FlashMode entry
00000024 23.17409325 [3296] SetBB5FlashMode->BB5 Boot data:
00000025 23.17424393 [3296] 00 00
PLEASSE HELP ME FAST I MUST REPAIR THIS PHONE TODAY !! !! !!
Old 01-19-2007, 09:24   #2 (permalink)
Freestyler2000's Avatar
Member: 2868
Hi,
If you see the reply on booting -
this means the phone has not gone into flash mode to rebuild the certificate.
Please check again cable connections for BSI and MBUS. Obviously, the RX and TX are fine.
Best regards
Daniel
Old 01-19-2007, 09:48   #3 (permalink)
Member: 137474
Sonork: 100.109924
I check and this cabel work well with mtbox and with other box I have 2 cabel 1 for JAF 1 for Unibox dongle and this problem is on this 2 cabel after change resistor to 7,5 k phone run in local mode but can't write rpl. Can you give me right schemat to check all pinout and resistor to this 7373 ?? ??Becouse if I don't use 7,5 k ressistor phone can't run in local mode but now can't write certificate and this is to wrong. I need help . I wait if someone can help me . bye
Old 01-19-2007, 14:37   #4 (permalink)
Member: 137474
Sonork: 100.109924
I write this rpl that I have from your ressaler I must do cabel that I can change ressistor in time that rpl is upload to phone and all write ok but now after this phone turn off after accept turn phone without sim massage and on lcd before turn off is contact service write and after this phone turn off before write rpl phone work but IMEI was 12345600654321 and phone was locked to all network how fix this ?? ?? ??
Old 01-19-2007, 15:33   #5 (permalink)
Member: 7220
Hi, please try to test on flashing other BB5 phone first and let me know the result.
Best Regard
Alan Tan
Old 01-19-2007, 15:50   #6 (permalink)
Member: 137474
Sonork: 100.109924
I fix with F1 5500, 6680, E50 2 pcs and this mean that all with box and cable is ok only problem is with 7373. I wait for help. bye
Old 01-19-2007, 15:55   #7 (permalink)
Member: 7220
Ok, please try on putting 6.8k resistor on this phone connectors and let me know the result pls. Thanks
Best Regards
Alan Tan
Old 01-19-2007, 22:00   #8 (permalink)
Member: 137474
Sonork: 100.109924
I try this resistor too result is the same like with 7,1k ressistor. bye
Old 01-20-2007, 01:57   #9 (permalink)
Member: 7220
Hi,
OK, I will try to get one phone here and check on it. Will try to troubleshoot and see what's the problem with it as soon as possible.
Best Regards
Alan Tan
Old 01-21-2007, 16:46   #10 (permalink)
Member: 7220
Hi,
Please try on 10k resistor now. And post the result.
Best Regard
Alan Tan
Old 01-21-2007, 22:04   #11 (permalink)
Member: 137474
Sonork: 100.109924
OK tommorow I will try and give know. bye
Old 01-26-2007, 12:00   #12 (permalink)
Member: 137474
Sonork: 100.109924
I write rpl correct but phone still dead and I have this info :
Nokia Have a problem with RPL for phone model 7373 (PM-209)!
He return wrong CMLA data and phone stay death.
You have rpl from nokia too ????
If yes I want refund my log becouse for now I can't fix my phone with this rpl or give me new working ok. bye
Old 01-26-2007, 13:12   #13 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Sonork: 100.1577222
Read this hope u Understand what i am Trying to Say
http:///vbb/showthread.php?t=370012
Old 01-26-2007, 13:19   #14 (permalink)
Member: 137474
Sonork: 100.109924
What you try to say ?? I use F1 and mtbox to fix this phone and for now nothing all time work with orginal rpl from nokia and all team give me bad rpl to this phone and now I want give back my money !! !! !! And I wait for answet how to do this becoude mtbox will give me back but prodigy team nothing say me !! !! And I wait for answer. bye
Old 01-26-2007, 14:36   #15 (permalink)
Member: 2868
Hi, I will get this phone soon and will sort the problem
Daniel
Can't unlock this sagem 220x can you fix this ? wgmmmx FuriouS TeaM Products 1 05-05-2008 23:04
N77 EMEA firmware is wrong on support !! !! pleasse fix this !! wgmmmx HWK 0 07-12-2007 06:34
Federal One Box can't write rpl to 1112 LogoMan Federal One 15 12-01-2006 10:35
D900 with 3.01 can't format FFS pleasse fix this wgmmmx UST Pro II 6 10-26-2006 14:55
Page generated in 0.46260 seconds with 12 queries
