Federal One Federal One & Prodigy Support Section |
12-08-2006, 13:00 | #1 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 92178 Status: Offline Thanks Meter: 14 | Nokia 1110 RH70 Contact Service Was orig 5.23 now 5.53 have Reflashed couple of times, (reading phone , selecting correct product code and then flashing) is there anything else to be done. Can't find 5.23 to flash with unless somebody has a link Thanks in advance for anyhelp. |
The Following User Says Thank You to davesmobiles For This Useful Post: |
12-08-2006, 13:57 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: nigeria
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | i learnt from a good friend of mine not to ever do a full erase on 1600 before flash. i guess it's because maybe the pm is sning tored in the same location. unfortunately i got the warning a little too late. Anyways heres attached pm that should correct the error. my customer wasn't patient enough for me to try so it aint tested by me yet! upload attached pm and post results dude. goodluck b.r ndagi Last edited by ndagi; 12-08-2006 at 14:15. Reason: forgot to attach file |
The Following User Says Thank You to ndagi For This Useful Post: |
12-08-2006, 14:02 | #3 (permalink) | |
Member: 92178 Status: Offline Thanks Meter: 14 | Quote:
I will try and post results. BR davesmobiles Last edited by davesmobiles; 12-08-2006 at 19:56. | |
12-09-2006, 14:59 | #7 (permalink) | |
Freak Poster Join Date: Nov 2003 Age: 46
Member: 44483 Status: Offline Thanks Meter: 4 | Quote:
In Phone info window, look at the tabs at the bottom and you will see the "Permanent Memory" Tab (PM), select it and click on write, choose ur file and write to the phone. Not sure if it will sort your phone out, but that's how it is done. Kind Regards | |
12-09-2006, 15:52 | #8 (permalink) | |
Its says please enter a range ( with an OK ) but doesn't ask for a file to load. Last edited by davesmobiles; 12-09-2006 at 16:03. | |
Nokia 1110 rh70 contact service solution 100%(INGS*****) | alammov | Nokia Hardware & Hardware Repair | 10 | 02-15-2011 18:06 |
1110 [RH70] contact service after flash!!! | SLIPLOCK | Nokia Digital Core Technology 4 ( DCT-4 ) | 58 | 11-05-2008 19:38 |
nokia 1110 in contact service | nellabe | Nokia Hardware & Hardware Repair | 7 | 09-09-2007 19:48 |
Nokia 1110 i contact service | sms-india | Nokia Hardware & Hardware Repair | 2 | 08-11-2007 06:38 |
nokia 1110 1600 contact service | ayaz ali | Nokia Hardware & Hardware Repair | 8 | 04-05-2007 13:40 |
