Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Federal One Federal One & Prodigy Support Section |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2003 Location: @@Afsus_ tunisia-sat@@ Age: 52
Member: 42750 Status: Offline Thanks: 194
| ===NOT normal F1 cannot unlock 1112=== Yes all procedure tested with all versions , even flash give error , only UFS can flash this phone;;;why ...all fia file on flash updated , dct4 plus updatated so solution???? |
| | #6 (permalink) |
| cable :::: Sir , I'm not stupid ... I have 2 cable ok , Easy falsh and other normal how ; this cable work fine with ufs ??? but , I tell you soft have bug's , Remark . this phone was destroyed by freind he falsh with 1600 flash , so I revieve with UFS , because F1 cannot falsh this phone always ID error . And to repair this phone only MT box can fix it , in last update they make new 1112 erase file ; with specail adress 13f0000 =end address 13fffff So I hope you get my point sir. I always runing under the new software and every update to each box . next time don't tell me cable , because it's not profesionel answer for profesionel user . see you |
| | #7 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2001 Location: China GuangDong
Member: 7220 Status: Offline Thanks: 145
| Quote:
Check this LINK for your cable shematics. Also pls check on BSI pin on the phone. Try to pull out the BSI pin slightly out to allow good contact on your connector. Don't remind us that your cable work with UFS3 or so ... cos both box are different. If people insist that this cable work with UFS3 and doesn't work with F1 .. then my answer will be WHY it doesn't work with FPS8 or FPS10 too? IF you need help on measuring the resistor on your connectors, please let me know. I will guide you on using multi-meter. Best Regards Alan Tan | |
| | #8 (permalink) |
| You mean , I need 3 cable for 1112 = one for flash = Read data = For unlock I already unlock more then 6 Nokia 2310 so....??? with my cable Please if you don't undersand the problem don't insert yourself , just for collect start on the forum stay away my sun. |
| | #10 (permalink) | |
| Quote:
If not, pls refer to the link. If yes, please check your C:\Program Files\NSS\Dct4Plus for the patch bin, and C:\Program Files\NSS\Flash for the FIA. If everything is there. Last thing you need to do is to pull out the 1112 battery PIN out slightly. So far, I haven't receive any news on the step from me that you had tried and all I can hear is the same comment you had place again and again. Try it first before you assume it doesn't work. Best Regards Alan Tan | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| W901 three cannot unlock | nasagih | Cruiser Suite | 11 | 04-04-2010 14:49 |
| SonyEricsson P1 cid53 cannot unlock with v101 | louisgsm | SETool2 | 0 | 03-29-2010 12:01 |
| Do not update... Yellowsn0w cannot unlock new fw 2.21 !!! Warning !!! | GSMman187 | iPhone ,iPod & iPad (Apple Inc. Products) | 5 | 01-29-2009 12:54 |
| 6600 Normal Mode In Ufs But Not Normal Mode In Batt | CHAPRAN | Nokia Hardware & Hardware-Repair Area | 2 | 06-13-2007 15:34 |
