Federal One Federal One & Prodigy Support Section |
02-08-2005, 16:16 | #2 (permalink) |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | which model u have did ? The Known Bugs is for some model CP extracting maybe failed, but not 'ALWAYS'. I think this is because Different HW/Board version with flash files, but not sure with that. Regrads, Alim |
02-08-2005, 17:24 | #4 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Boston
Member: 21920 Status: Offline Thanks Meter: 10 | I had a fight with one of those (7250) once. Took about 10-15 tries with Griffin and Prodigy before I could make CP extract. I once heard this has to do with language/PPM change. Try to flash MCU/PPM only first then reflash. Sometimes with Prodigy, it reports that CP extract failed but when you look in the phone, the OLD CP is still there. Check that- most likely there are few if any changes in the new version (its CP) and the customer will be happy his ringtones and wallpapers are still there (this happened to me several times, mostly with 6230)... |
02-08-2005, 23:20 | #5 (permalink) | |
Freak Poster Join Date: Nov 2003
Member: 43976 Status: Offline Thanks Meter: 4 | Quote:
Try with ACP-12x charger. I had a 7250 with the same problem solved by using an ACP-12A charger power to the box. Regards JFK | |
02-09-2005, 13:26 | #6 (permalink) |
No Life Poster Join Date: Jul 2001 Location: London, UK
Member: 5324 Status: Offline Thanks Meter: 7 | hi also you can try this, power up the phone, and delete all the user data from the galleries, then try to full flash with CP,,,,, i am not sure but i think if sometimes the memory is near to full there can be a problem erasing and extracting it... just an idea... maybe i am totally wrong, but it worked for me on 3 6230;s br |
02-13-2005, 04:12 | #8 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 84
Member: 53556 Status: Offline Thanks Meter: 1 | prodigy has never been a problem to me its a very good tool and meets the standard. powering it is of an importance use a good and well regulated power supply and see the difference. just try it. |
Why can't we just make a tool to change imei on dct-4 phones? | concom | Nokia Digital Core Technology 4 ( DCT-4 ) | 30 | 01-12-2009 17:39 |
6235 extract cp error | Ransyaruddin | Nokia CDMA | 3 | 11-19-2008 08:10 |
Why can't i get SETool UFS Cracked to activate | Crazy_ratata | UFS2 + UFS3-Tornadoflasher | 1 | 06-07-2006 18:08 |
How to extract language pack from phone P910i | bart3 | Cruiser Suite | 1 | 03-12-2005 23:34 |
Why hasnt Prodigy got option to change IMEI on DCT3 phones!! | MC Harami | Federal One | 7 | 02-14-2005 07:16 |
