how can I kill My BlueTooth!!!!!!!!! best regards for all...I face strange customers need like : kill my bluetooth I dont want it to work... so I tried once in 6600 to erase whole flash and reflash again skipping BT ares but the Phone was jammed when trying to access Gallery and was f+u+c+k+e+d..so I return it to it's original state..so any one know how to kill BT ( HW ) and to be soft solution to make it back working in case the stupid custmer needs?? |
try to downgrade, then upgrade , skip bt flashing hope it work |
@gabila it works man but it seems that you didnot read carefully what I wrote,,I did that and it worked but the phone will be in bad case ...gallery can't be open and many problems so the hardware solution is the most desired one and only killing BT Vcc will be enough |
youre rigt youre right man sorry it was late when i read your post..... an i was tired... and i was searching 4 something else..... my atention was distracted by other things and i understood you need a sw solution.......not hw if you need hw solution is quite simple.... like u said.. cut of the Vcc |
