Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Hardware
Old 03-19-2009, 12:33   #1 (permalink)
Member: 995682
Widcomm bluetooth driver and device not recognized after SP2 and SP3 - Solution
After many years of attempts I finally got it right. I own an Acer Ferrari 3000 since 2005. It ships with XP home edition - pre SP2. It comes with a built in Bluetooth device (not a pluggable USB) and uses a Widcomm driver. As soon as SP2 was installed (auto-update) the bluetooth device was not identified by windows and the blue led indicator stopped blinking. The device was not recognized by windows and did not appear in the hardware or driver manager.
I followed many threads - only a few were aiding me but none helped. The problem, to summarize, is that SP2 provides windows with a list of generic bluetooth drivers. The original Widcomm driver is not signed or authorized or recognized as official (whatever...) by Windows and Microsoft. SP2 installs system information files in the %WINDIR%\inf (typically C:\Windows\inf) directory, which are then compiled into binary (.PNF) files which tell windows which drivers to load. Widcomm is not one of them.
Once SP2 installed the bth.inf and related bthXXX.inf files under this folder, and the system was rebooted, this information (I am guessing here) is loaded to the registry and is virtually impossible to revert without tampering with the OS functioning properly. (Don't try it, take my word for it, unless you'd like to spend days of recovering and re-installations). My solution is to reinstall SP2, but prior to re-booting, rename all the bthXXX.inf files to bth.inf.old.
  1. If you have service pack 2 installed already - uninstall it!
  2. Make sure your Bluetooth device and driver work properly before SP2 installation. No use of blaming SP2 if your Bluetooth devices do not work without it.
  3. Re-install SP2 (you can do this with Windows update)
  4. Very important!!! When the installation completes, before reboot, goto C:\Windows\inf and rename each bthXXX.inf file (such as bth.inf, bthpan.inf, bthprint.inf and etc...) to bth.inf.old, bthpan.inf.old, bthprint.inf.old and etc... In short, change the extension. If you already have any bthXXX.PNF files, rename them too in the same manner.
  5. Reboot only after step 4.
Note: Service Pack 3 installation, will also place these .inf files under %WINDIR%\inf. You need to do the same thing. Rename the bthXXX.inf files after the installation but before rebooting.
Good luck!!!
The Following 5 Users Say Thank You to tnsilver For This Useful Post:
Old 04-06-2009, 16:52   #2 (permalink)
hima010's Avatar
Member: 820946
Sonork: ...........
gooooooooooooooooooooooood
The Following User Says Thank You to hima010 For This Useful Post:
[IMG] code is Off
My spiderman box after update Usb device not recognized islam01 SpiderMan 78 12-17-2011 14:04
U600 of usb device not recognized after flash ? kiubo NSPRO 3 03-08-2009 13:50
V3 dead and device not recognized even with TP!!! tsarkh Motorola Hardware Repair Section 1 05-29-2007 11:07
Belkin F8T001uk v2 Widcomm Bluetooth USB Adapter Dongle Not Recognised as usb device rmtrmt Bluetooth-Hardware 1 10-13-2004 17:58
Page generated in 0.23148 seconds with 11 queries
