05-30-2007, 16:34 | #1 (permalink) |
Junior Member Join Date: Jan 2006
Member: 222206 Status: Offline Thanks Meter: 1 | 5.1.0.1100 and Vista Here's my problem: 32bit, only have HotSync. It connects with Network Access however won' t connect to internet. On Avantgo I get Error: 5470 Cannot find server or there was a DNS error. On WebPro, I get the infamous DNS lookup timed out. Please check coverage and try again [comm.8]. Worked fine until a few days ago. Unistalled and reinstalled the PALM OS with HotSync. Tried different versions of Widcomm. Checked my 2Wire router config. Checked the ICS on my LAN connection. I did notice that the comm ports installed are 4 and 10. not 4 and 5 as most people report. I did try changing the port in the Hot Sync from 4 to 10 but that only made my Hot Sync not work. I went to x64 and loaded PALM OS with HotSync and Widcomm 5.0.1.2500. Set everything up the same and it works just fine except there are no drivers to HotSync the Palm to x64 on the USB port. no biggy since my Bluetooth works fine here. The comm ports installed here are the 4 and 5 most people report. Any suggestions out there?? Would rather run the 32 bit since I have lesser problems with other software than on the 64 bit version. That's the reason for the question. TIA Bill |
Widcomm.Bluetooth.Software.Drivers.5.1.0.1100 | illusion. | Bluetooth-Software | 148 | 03-19-2012 11:50 |
REQ: WIDCOMM Bluetooth Software Between 5.1.0.4200 and 5.5.0.7400 | Ascii2 | Bluetooth-Software | 0 | 06-28-2009 03:20 |
5.1.0.1100 and Vista | OKAUSSIE | Bluetooth-Software | 0 | 05-30-2007 16:33 |
Plantronics Pulsar 590A and Widcomm 5.1.0.1100 | damole | Bluetooth-Software | 4 | 10-19-2006 12:35 |
