BlueSoleil 3.2 for Vista Released You can find it here: http://www.bluesoleil.com/download/i...soleil_voip_en |
Thanks, but have anyone with no 5MB limitations or cracked? |
have any one its crack or patch????????? |
I've heard that if you take the .exe from the download and over write the .exe of your current installed verson then you'll get around the 5mb problem. |
its not fully worked by ur exchanged system with .exe |
i have a problem, what did the 5MB limit mean? max file it can transfer? total data transfer per session? total data transfer per evaluation? |
just tried, seems per session. not a big trouble... |
please the crack thanks! |
At last i solve that problem for a long while. install BT 3.2.2.6 then replace with BT 2.1.3.0 exe (cracked exe)file. then go to tools , assign all ports for ur phone and see what happaning. I solved by this.:D:D:D |
Why do not you want to make crack for 3.2? I know, crack for 1,6.2 is probably working, but I should be pleased for the 3.2 version crack with all bug fix from previous versions...among others from 1.6.2 |
No offense, but replacing the exe from previous versions isn't really a crack. You're probably running the older edition with the new menus or something like that... |
The only crack unfortunatley is 1.6.2 and some people say that this is the crack for 3.00 and 3.2 I and many people say that it does not work. In v3.00 when I open the transfer dialogue and send file it says: access denied. So replacing the file is not a crack We are waiting for the professionals to crack this program please make a crack Thank you very much |
Any news about crack? |
waiting for the crack!! |
