Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 07-16-2008, 07:18   #1 (permalink)
Member: 411385
Unhappy Bluetoot BCM 2035b
hi people.. i got a new bluetooth USB device and it doesn seem to detect any devices when i run the scan neighbour hood... my phones also don seem to detect any device... i managed to identify that it is a BROADCOM device and the software used is WIDCOMM Bluetooth software 5.0.1.801 can any 1 help me fix the problem... please thank u in advance...
Old 07-29-2008, 20:38   #2 (permalink)
Member: 145139
Hello,
I have attached a picture with the same device, which was also defective on delivery. I tested it with different Widcomm versions and also with BlueSoleil.
There was never a BT device detected (tested with headset and mobile phone).
Hope this helps.
DocNetwork
P.S. Will upload file later. Upload doesn't work.
Old 08-02-2008, 11:19   #3 (permalink)
Member: 828130
I have a bRoadcom 2045 USB Bluetooth device. I get the device in the Device Manager OK, but there is no Icon in the System Try. I have tried to disable the Firewall without any difference. When I started to install the driver (I got the Trust Installer (v 5.6) from the CD which came with the device) and cklicked on "Install driver", I didn't get the screen "WIDCOMM Bluetooth Software 6.0.1.4900" as I should get according to the Install Papers.
I allways get the information "No Bluetooth device found". How should I fix this problem?
Old 08-13-2008, 16:41   #4 (permalink)
Member: 200440
I have the same problem with my dongle but only in the last few weeks while I was fiddling around with different operating systems. It's a Belkin F8T009 which is also a BCM2035 chipset. The only way I can get it to work is by using Widcomm 6.0 in Vista.
If I search for any devices using WIDCOMM under XP (it came with version 3.0 but I also tried 5.1.0.4200 from Broadcom's website) it appears to scan for about 10 seconds, no devices are detected and the following messages appear in the status bar:
"Your local Bluetooth device has stopped" ... followed by the Windows USB disconnect sound
"Your local Bluetooth device is now up" ... followed by the Windows USB connected sound
I tried using the Microsoft Bluetooth stack in Vista x64 (didn't try it in XP) - it scanned for about one minute and said no devices were found. At the same time, the following message appeared in the system event log:
Level: Warning
Date and Time: 31/07/2008 22:49:20
Source: BTHUSB
Event ID: 3
Task: None
Category: A command sent to the adapter has timed out. The adapter did not respond.
I also noticed in the properties that Vista detects the dongle as a Bluetooth 2.0 device rather than 1.2, it's certainly 1.2.
I wonder if Widcomm 6.0 screwed up the firmware somehow?
[IMG] code is Off
k800i bluetoot shahzadthe1 Cruiser Suite 0 06-28-2009 17:31
j700 bluetoot problem hik QUALCOMM Models (3G) 0 02-11-2009 15:04
Flash kE 970 Bluetoot id fany12ro ULT PRO 1 12-12-2007 05:29
What is in Phoenix Bluetoot Flasher ? catik Nokia Digital Core Technology 4 ( DCT-4 ) 0 12-29-2005 02:01
Page generated in 0.21614 seconds with 11 queries
