Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 05-05-2007, 14:16   #61 (permalink)
Member: 318445
The Anycom 250 is class 1. Where can I find the .dfiu file for the Anycom 200?
Old 05-05-2007, 14:33   #62 (permalink)
Member: 501325
You can find it in lexab65's original post on page 1 where he lists both .dfu files.
Old 05-05-2007, 16:29   #63 (permalink)
Member: 318445
Actually I found it in a post from Aqualung, page 3, but now I realise that the firmware ending 251 is for the 200 class 2 model and my Dell Truemobile 355 is class 2 so it probably makes sense to use that one. I had been thinking I was using the firmware for the 250 which is class 1 and wondered whether that might be the reason why it stops my wireless adapter from working.
I tried flashing my device with the original Dell firmware but the flashing fails the device becomes Broadcom Bluetooth Firmware Upgrade Device. After turning the machine off and on it reverts to being the Anycom device.
Old 05-05-2007, 16:38   #64 (permalink)
Member: 501325
I have the following HW/firmware:
BCM92045DG-Flash, firmware 2.1.39.77, IOGear GBU221 2.0+EDR (class 2) VID/PID= OA5C/2101
I have just upgraded my drivers to 5.1.0.3100 from anycom's site:
http://forum.anycom.com/index.php?topic=1799.0
I previously had 5.0.1.1100 and had very poor stereo (A2DP) support, as it cuts out constantly. These new drivers haven't helped in anyway. I still hve good AVRCP function and skype/IMtalk are fine too. My two_year_old samsung d600 supports A2DP quite well with my headphones and it sounds great (funny how older, "non-smart" phones handle this well).
I have tried to update the firmware via the "DFUWizard", but got a message that "The DFU wizard did not detect a matching Bluetooth device for DFU image file you selected...." and asked that i find the appropriate DFU file for the bt device. I think there is some related w/in the first two pages of this thread and am going back to reread, but if anyone has some insight i'd appreciate it.
Old 05-05-2007, 16:47   #65 (permalink)
Member: 501325
Sorry, you are right. Lexab65's original post has been removed. If you remember:
File from drivers from ANYCOM named 'BTFlasher.EXE'
after start generate 'BtDfuWizard' in temp directory(%TEMP%).
generation is different in case you choose
USB200 or USB250
for USB200 it will be v0A5C_p2111_BCM2045B1_002.001.128_Tecom_0251.dfu file
for USB-250 - v0A5C_p2111_BCM2045B1_002.001.128_Tecom_0250.dfu
Not sure why this happend, but I found some firmware update instructions in the svcpack.ini file form the 5.1.0.3100 driver install:
To perform firmware upgrade, place the dfu file in the SvcPack folder, and make sure its
; copied to the Program Files\Bluetooth Software\bin folder using the [Files] section above
; Set the same file name as 'DfuFileName' below.
I will try this method,
Old 05-05-2007, 22:08   #66 (permalink)
Member: 501325
Thank you to all the folks here supplying such good info. I was successful in using the firmware version: 2.1.128.251 provided in post #13 by using the flash update tool: btdfuwizard.exe provided in post #11. I previously had firmware version: 2.1.39.77
My hardware details are as follows:
BCM92045DG-Flash, , IOGear GBU221 2.0+EDR (class 2) VID/PID= OA5C/2101
A2DP sounds great now with WMP11, absolutely no sound cutting out. I really can't believe that worked, and I don't know why these OEMs refuse to provide updated firmware/ drivers, except Anycom of course. Does anyone know if it's MS or broadcom causing this issue? How can these OEMs do this? IOGear's techsupport told me the best recommendation they had was to re-start my connections and media player, and that clearly wasn't any solution. I will make a table showing what has been known to work if anyone has interest. Should it be its own thread?
Thank you!
Old 05-11-2007, 00:54   #67 (permalink)
Member: 56968
Thanks Meter: 4
New firmware update for Logitech dongles
http://forums.logitech.com/logitech/...=3833&nobounce
File Type: rar logitech_RR4006_RR5103_B0077_fw_update.rar (303.0 KB, 152 views)
Old 05-13-2007, 12:09   #68 (permalink)
Member: 79741
After flashing with this firmware what's the version number shown in properties?
2.1.245.0?
Old 05-13-2007, 15:09   #69 (permalink)
Member: 70051
Friends,
I need to download lastest firmware for my dongle (Anycom USB-250)
but I donīt know here. Please, links, URL.
My dongle went paired with my devices, but donīt work.
(USB-250 + Computer) Didnīt find/found services in my cellular, in my headset, ...
I tried to update firmware. Show this message:
Release Notes - Bluetooth Firmware Upgrade for ANYCOM USB
Supported Hardware
* CC3023 - ANYCOM USB-200 with Bluetooth wireless technology (Class 2)
* CC3036 - ANYCOM USB-250 with Bluetooth wireless technology (Class 1)
Supported Software
* ANYCOM USB-200 / 250 Bluetooth Software v5.1.0.1700 or above
* Apple Mac OS-X 10.3.9 or above with latest Bluetooth Software
* GNU/Linux with BlueZ Bluetooth Stack
Changes in this release
* Firmware update from Broadcom v2.1.39.0 to 2.1.128.0
* Improvements for Bluetooth A2DP Profile when used with latest
ANYCOM Bluetooth Software
* Added Support for Mac OS-X
* USB Adapter now supports UHE mode:
Bluetooth Mouse and Keyboard can now be used without Bluetooth
software installed.
* Misc. improvements and bug fixes
But, at the end of process (processīs end) show:
"No devices found" and other messages, in Brazilian portuguese.
When I call Bluetooth configuration, show:
Status: This device is working
Company: Broadcom Corporation
Firmware release: Version 2.1.128.250
Device Adress: 00:16:38:C1:A1:1F
HCI Release : Bluetooth HCI 2.0
HCI Revision: 20FA
LMP release: Bluetooth LMP 2.0
Secondary Release LMP: 4180
This words I wrote did not matches exactly,
but I dont speak english.
Thanks
Old 05-15-2007, 18:55   #70 (permalink)
Member: 424295
Hi,
i have a Anycom 200 dongle with firmware 2.3.14.341.
Are there any newer firmware version available for that dongle?
Old 05-16-2007, 15:51   #71 (permalink)
Member: 508362
is this a dongle or an internal component?
i believe we have the same hardware setup...
I have successfully edited the dfu file so the BT updater accepts my hardware. however when the process starts updating my dongle, it turns the device off and the update stops tells me to plug my device back in. About half a second later the dongle re-activates and the process starts again. This will keep looping until i cancel at the 'plug your device in' warning.
anybody else run into this?
Old 05-17-2007, 11:13   #72 (permalink)
Member: 40599
Thanks Meter: 3
2.1.245.0?
Yes it is 2.1.245.0!
Old 05-18-2007, 16:40   #73 (permalink)
Member: 318445
Anybody got ideas how to flash my device back to it's original Dell firmware?
Old 05-18-2007, 23:19   #74 (permalink)
Member: 56968
Thanks Meter: 4
did you carefully read post #16??
same situation, just replace IBM firmware with Dell firmware and try to follow directions.
Old 05-19-2007, 20:17   #75 (permalink)
Member: 318445
Thanks for the reply.
I did read that post but I assumed I would need a Dell version of the Firmware Upgrade device drivers.
What happens for me is that after trying to flash with the modified Dell dfu file the device goes into Broadcom Bluetooth Firmware Upgrade device then Windows successfully installs drivers for this device.
In post #16 you say update the drivers to IBMs drivers but I found no drivers in the file IBM7kbf02ww.exe only what seems is a version of BtDfuWizard.exe with the IBM firmware inside and no SetupBluetoothFirmware.exe.
Anyway I tried again and ran the IBM program and now my device is showing as Thinkpad Bluetooth. Now my WiFi adaptor works at the same time as the Bluetooth but my BT headset won't connect in headset mode.
If I had the setupBluetoothFirmware.exe would I be able to use it with the Dell dfu file?
[IMG] code is Off
Broadcom Chip Bluetooth Firmware Update Ascii2 Bluetooth-Hardware 0 07-08-2009 21:14
Broadcom 2045 device under DOS McTrinsic Bluetooth-Software 0 05-11-2007 22:02
Upgrade FW for a Broadcom 2045 ... susa Bluetooth-Software 1 10-21-2006 18:02
Need Help With Broadcom BT3030 Shadow1020 Bluetooth-Software 0 12-13-2005 06:22
Broadcom (Widcomm) v4.0.1.2601 somms Bluetooth-Software 2 10-26-2005 17:11
Page generated in 0.28495 seconds with 11 queries
