05-05-2007, 16:29 | #63 (permalink) |
Major Poster Join Date: Jul 2006
Member: 318445 Status: Offline Thanks Meter: 1 | Actually I found it in a post from Aqualung, page 3, but now I realise that the firmware ending 251 is for the 200 class 2 model and my Dell Truemobile 355 is class 2 so it probably makes sense to use that one. I had been thinking I was using the firmware for the 250 which is class 1 and wondered whether that might be the reason why it stops my wireless adapter from working. I tried flashing my device with the original Dell firmware but the flashing fails the device becomes Broadcom Bluetooth Firmware Upgrade Device. After turning the machine off and on it reverts to being the Anycom device. |
05-05-2007, 16:38 | #64 (permalink) |
Junior Member Join Date: May 2007
Member: 501325 Status: Offline Thanks Meter: 0 | I have the following HW/firmware: BCM92045DG-Flash, firmware 2.1.39.77, IOGear GBU221 2.0+EDR (class 2) VID/PID= OA5C/2101 I have just upgraded my drivers to 5.1.0.3100 from anycom's site: http://forum.anycom.com/index.php?topic=1799.0 I previously had 5.0.1.1100 and had very poor stereo (A2DP) support, as it cuts out constantly. These new drivers haven't helped in anyway. I still hve good AVRCP function and skype/IMtalk are fine too. My two_year_old samsung d600 supports A2DP quite well with my headphones and it sounds great (funny how older, "non-smart" phones handle this well). I have tried to update the firmware via the "DFUWizard", but got a message that "The DFU wizard did not detect a matching Bluetooth device for DFU image file you selected...." and asked that i find the appropriate DFU file for the bt device. I think there is some related w/in the first two pages of this thread and am going back to reread, but if anyone has some insight i'd appreciate it. |
05-05-2007, 16:47 | #65 (permalink) | |
Member: 501325 Status: Offline Thanks Meter: 0 | Sorry, you are right. Lexab65's original post has been removed. If you remember: , Quote:
To perform firmware upgrade, place the dfu file in the SvcPack folder, and make sure its ; copied to the Program Files\Bluetooth Software\bin folder using the [Files] section above ; Set the same file name as 'DfuFileName' below. I will try this method, Last edited by greendrake; 05-05-2007 at 17:45. | |
05-05-2007, 22:08 | #66 (permalink) |
Member: 501325 Status: Offline Thanks Meter: 0 | Thank you to all the folks here supplying such good info. I was successful in using the firmware version: 2.1.128.251 provided in post #13 by using the flash update tool: btdfuwizard.exe provided in post #11. I previously had firmware version: 2.1.39.77 My hardware details are as follows: BCM92045DG-Flash, , IOGear GBU221 2.0+EDR (class 2) VID/PID= OA5C/2101 A2DP sounds great now with WMP11, absolutely no sound cutting out. I really can't believe that worked, and I don't know why these OEMs refuse to provide updated firmware/ drivers, except Anycom of course. Does anyone know if it's MS or broadcom causing this issue? How can these OEMs do this? IOGear's techsupport told me the best recommendation they had was to re-start my connections and media player, and that clearly wasn't any solution. I will make a table showing what has been known to work if anyone has interest. Should it be its own thread? Thank you! |
05-11-2007, 00:54 | #67 (permalink) |
Major Poster Join Date: Mar 2004 Age: 46
Member: 56968 Status: Offline Thanks Meter: 4 | New firmware update for Logitech dongles http://forums.logitech.com/logitech/...=3833&nobounce |
05-13-2007, 12:09 | #68 (permalink) | |
Junior Member Join Date: Aug 2004 Age: 52
Member: 79741 Status: Offline Thanks Meter: 0 | Quote:
2.1.245.0? | |
05-13-2007, 15:09 | #69 (permalink) |
Junior Member Join Date: Jun 2004 Age: 56
Member: 70051 Status: Offline Thanks Meter: 0 | Friends, I need to download lastest firmware for my dongle (Anycom USB-250) but I donīt know here. Please, links, URL. My dongle went paired with my devices, but donīt work. (USB-250 + Computer) Didnīt find/found services in my cellular, in my headset, ... -------------------------------------------- I tried to update firmware. Show this message: ================================================== ========= Release Notes - Bluetooth Firmware Upgrade for ANYCOM USB ================================================== ========= ---------------------------------------- Supported Hardware ---------------------------------------- * CC3023 - ANYCOM USB-200 with Bluetooth wireless technology (Class 2) * CC3036 - ANYCOM USB-250 with Bluetooth wireless technology (Class 1) ---------------------------------------- Supported Software ---------------------------------------- * ANYCOM USB-200 / 250 Bluetooth Software v5.1.0.1700 or above * Apple Mac OS-X 10.3.9 or above with latest Bluetooth Software * GNU/Linux with BlueZ Bluetooth Stack --------------------------------------------- Changes in this release --------------------------------------------- * Firmware update from Broadcom v2.1.39.0 to 2.1.128.0 * Improvements for Bluetooth A2DP Profile when used with latest ANYCOM Bluetooth Software * Added Support for Mac OS-X * USB Adapter now supports UHE mode: Bluetooth Mouse and Keyboard can now be used without Bluetooth software installed. * Misc. improvements and bug fixes ------------------------------------------------------------------------------ But, at the end of process (processīs end) show: "No devices found" and other messages, in Brazilian portuguese. ----------------------------------------------------------------------------- When I call Bluetooth configuration, show: Status: This device is working Company: Broadcom Corporation Firmware release: Version 2.1.128.250 Device Adress: 00:16:38:C1:A1:1F HCI Release : Bluetooth HCI 2.0 HCI Revision: 20FA LMP release: Bluetooth LMP 2.0 Secondary Release LMP: 4180 ------------------------------------------------------------- This words I wrote did not matches exactly, but I dont speak english. Thanks |
05-16-2007, 15:51 | #71 (permalink) | |
Junior Member Join Date: May 2007 Location: house Age: 39
Member: 508362 Status: Offline Thanks Meter: 0 | Quote:
i believe we have the same hardware setup... I have successfully edited the dfu file so the BT updater accepts my hardware. however when the process starts updating my dongle, it turns the device off and the update stops tells me to plug my device back in. About half a second later the dongle re-activates and the process starts again. This will keep looping until i cancel at the 'plug your device in' warning. anybody else run into this? | |
05-18-2007, 16:40 | #73 (permalink) | |
Member: 318445 Status: Offline Thanks Meter: 1 | Quote:
05-18-2007, 23:19 | #74 (permalink) | |
Member: 56968 Status: Offline Thanks Meter: 4 | Quote:
same situation, just replace IBM firmware with Dell firmware and try to follow directions. | |
05-19-2007, 20:17 | #75 (permalink) |
Member: 318445 Status: Offline Thanks Meter: 1 | Thanks for the reply. I did read that post but I assumed I would need a Dell version of the Firmware Upgrade device drivers. What happens for me is that after trying to flash with the modified Dell dfu file the device goes into Broadcom Bluetooth Firmware Upgrade device then Windows successfully installs drivers for this device. In post #16 you say update the drivers to IBMs drivers but I found no drivers in the file IBM7kbf02ww.exe only what seems is a version of BtDfuWizard.exe with the IBM firmware inside and no SetupBluetoothFirmware.exe. Anyway I tried again and ran the IBM program and now my device is showing as Thinkpad Bluetooth. Now my WiFi adaptor works at the same time as the Bluetooth but my BT headset won't connect in headset mode. If I had the setupBluetoothFirmware.exe would I be able to use it with the Dell dfu file? Last edited by damole; 05-19-2007 at 21:08. |
Broadcom Chip Bluetooth Firmware Update | Ascii2 | Bluetooth-Hardware | 0 | 07-08-2009 21:14 |
Broadcom 2045 device under DOS | McTrinsic | Bluetooth-Software | 0 | 05-11-2007 22:02 |
Upgrade FW for a Broadcom 2045 ... | susa | Bluetooth-Software | 1 | 10-21-2006 18:02 |
Need Help With Broadcom BT3030 | Shadow1020 | Bluetooth-Software | 0 | 12-13-2005 06:22 |
Broadcom (Widcomm) v4.0.1.2601 | somms | Bluetooth-Software | 2 | 10-26-2005 17:11 |
