Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 05-22-2007, 08:50   #76 (permalink)
Member: 56968
Thanks Meter: 4
Originally Posted by damole View Post
Thanks for the reply.
I did read that post but I assumed I would need a Dell version of the Firmware Upgrade device drivers....
Hi damole
try this one firmware from Dell.
File Type: rar v413C_p8126_BCM2045B1_002.001.216_DellEntwood_0296.rar (147.2 KB, 120 views)
Old 05-22-2007, 11:11   #77 (permalink)
Member: 56968
Thanks Meter: 4
New FW Update for USB-200 & 250 to v2.1.224.350/353 is now available.
http://forum.anycom.com/index.php?topic=1853.0
ftp://drivers.anycom.com/beta/usb200...-1-224-350.exe
ftp://drivers.anycom.com/beta/usb200...-1-224-353.exe
Old 05-23-2007, 19:59   #78 (permalink)
Member: 318445
Originally Posted by lexab65 View Post
Hi damole
hey lexab65.
This worked great. The first time I tried to update using this firmware I got the Broadcom Bluetooth Firmware Upgrade Device again. I let it install the drivers for this and then repeated the same process and this time the firmware updated. Now I have my Dell Truemobile back with newer firmware and so far everything working.
Big thanks for this. BTW where did you get it from?
cheers
damole
Old 05-24-2007, 10:44   #79 (permalink)
Member: 56968
Thanks Meter: 4
Hi damole
Firmware comes with dell 355 drivers for Vista
http://support.us.dell.com/support/d...&fileid=188664
Old 05-25-2007, 18:31   #80 (permalink)
Member: 318445
I also updated my Acer's firmware with the latest from Anycom so thanks for that also.
Old 05-25-2007, 23:25   #81 (permalink)
Member: 424572
Lexab65 thanks for the news, awesome,
However I have updated my firmware to the new one and also the vista anycom beta drivers and i'm getting the problem of error [-349] can't use older drivers over newer ones?
Anyone help?
Thanks
Ade.
Old 05-31-2007, 14:27   #82 (permalink)
Member: 354732
Great post. got it to work on my msi bluetooth. thanks guys
Old 06-02-2007, 13:14   #83 (permalink)
Member: 515917
I'm running Vista Ultimate 64 bit on an Acer 5113WLMi, I have tried updating the firmware, but the process starts & immediately stops bluetooth I switch bluetooth off then on again & device drivers are automatically installed & the error message goes but the process just hangs. Anyone know a way around it? Also, in vista how can I see my current firmware version. The device is recognised as Broadcom Bluetooth 2.0+EDR USB dongle with trace filter with the latest broadcom drivers.
Old 06-05-2007, 11:01   #84 (permalink)
Member: 56968
Thanks Meter: 4
Hi Beelzebub
for 64 bit OS you can use latest ANYCOM firmware upgrade
It's include 64 bit version of flasher(SetupBluetoothFirmware64.exe)
just run it and look at %TEMP% dir for directory named "BtDfuWizard"
it's too heavy to post it here with rar because of 64 bit file versions was also included.
Just remove rar from the end of each files
also you need modify firmware for your dongle PID/VID
7z did magic compression work
Old 06-17-2007, 22:51   #85 (permalink)
Surej's Avatar
Member: 12296
Thanks Meter: 9
Hi,
Can some one make me a dfu file for my advent class 2+edr usb dongle ..? It currently uses toshiba stack..the vid/pid are VID_0A12&PID_0001
Thanks
Surej
Old 06-24-2007, 13:02   #86 (permalink)
Member: 22680
I need dfu for VID 0A5C, PID 2101 Class 1 dongle. Jusy don't know how to calculate the checksum correctly for this dfu.
Old 07-03-2007, 23:56   #87 (permalink)
Member: 157219
I have a BCM2045A internal laptop module (common piece available in multiple laptops). This one had very ancient firmware 2.1.16 (With Widcomm 5.1.0.1100 and had problems with detecting HID devices) so I decided to give it a shot and try anycom/IBM procedure. Original VID 0A5C and PID 2045.
When I tried to update with Anycom unmodified firmware, it accepted v0A5C_p2111_BCM2045B1_002.001.128_Anycom_0250.dfu and updated my devbice without asking any questions (I expected it to fail and leave me with firmware-mode device). Device works fine, but Widcomm reported HW adress 00:00:00:00:00:00. Later on I decided to continue with upgrade and modified IBM dfu to match new PID (of "anycom" device) of 2110 and finally I have 2.1.211.299 firmware and everything seems to be fine apart from device adress, that now is shown as FF:FF:FF:FF:FF:FF.
Is possible to revert/correct/repair the hardware address?
Old 07-14-2007, 18:37   #88 (permalink)
Member: 545730
How to fix checksum?
Old 07-22-2007, 00:08   #89 (permalink)
Member: 177301
Thanks Meter: 47
Thumbs up Thanks a lot!
Try this one
it's firmware from original dell drivers.
Hi lexab65,
Thanks for the updated firmware of Dell BT module 355.
Now I am using the new firmware happily.
Just in case anyone wants to know the version numbers changed:
Old: 2.1.130.218
New: 2.1.216.296
Old 07-22-2007, 06:08   #90 (permalink)
Member: 551415
Acer Extensa 3102 WXMi: firmware updated for pulsar 590E headset
hi all,
thanks a lot for this thread!
I bought a pulsar 590E bluetooth headset but it sounded really bad on my Acer Extensa 3102 WXMi Laptop under WinXP SP2. I went through the following steps and sound quality improved a lot!
- downloaded BTFlasher-v2-1-224-01.exe linked on page 6
- did firmware update with v0A5C_p2111_BCM2045B1_002.001.128_Tecom_0251.dfu from first page.
(there might be newer ones, but I was unpatient and did not want to read through the whole thread, maybe I missed something...)
- installed anycom driver anycom-bluetooth-usb200-250-windows-v5-1-0-3300-BETA.exe linked on page 6
microphone was identified immediately as hands-free-unit AND stereo audio. the appear both connected at the same time in my bluetooth environment.
I choose the device within any given application (winamp goes stereo audio, skype goes hands-free-unit and so on)
The stereo audio mode has AWESOME sound quality, even through a wall into the next room but no microphone.
The hands-free-unit mode supports microphone but is of rather poor quality, maybe this can be improved, I did not try much yet.
are there any suggestions how to tweak the quality of this hands-free-unit mode?
[IMG] code is Off
Broadcom Chip Bluetooth Firmware Update Ascii2 Bluetooth-Hardware 0 07-08-2009 21:14
Broadcom 2045 device under DOS McTrinsic Bluetooth-Software 0 05-11-2007 22:02
Upgrade FW for a Broadcom 2045 ... susa Bluetooth-Software 1 10-21-2006 18:02
Need Help With Broadcom BT3030 Shadow1020 Bluetooth-Software 0 12-13-2005 05:22
Broadcom (Widcomm) v4.0.1.2601 somms Bluetooth-Software 2 10-26-2005 17:11
Page generated in 0.55548 seconds with 9 queries
