10-22-2006, 14:19 | #1 (permalink) |
Junior Member Join Date: Oct 2006
Member: 364701 Status: Offline Thanks Meter: 1 | How to install Widcomm drivers
First things first, if you have some bluetooth drivers already installed, you should find out who the manufacturer of your device is. This is because Widcomm/Broadcom 'broke' compatibility with other manufacturer's devices from version 5.1.0.1100 onwards. If you are not sure, I would recommend downloading 5.1.0.1100 just to be sure (http://forum.gsmhosting.com/vbb/showthread.php?t=294359) Next step is to obviously uninstall your current drivers (if you have any), which can be done from the Add/Remove Programs bit in Control Panel. Also, remove any bluetooth device drivers by using device manager in System (found in Control Panel):
Step 2 (Preventing Windows native Bluetooth Stack) Then, you should remove prevent the Windows native bluetooth working: Make sure that you have enabled viewing of hidden/system files:
Rename both of these to bth.inf.old & bth.pnf.old (in each case, confirm with the pop up box). (Left click to highlight the file and press F2 to edit the filename) Now restart your computer. Step 3 (Getting your USB Bluetooth drivers ready) The next step is to find out if you have the original drivers for your bluetooth adapter. If you do, get them and on the CD, look for a file called 'btwusb.inf' which contains the information required to install your bluetooth adapter later on. If you get that file, copy it into the Win32 & Win64 folders of the Widcomm drivers folder. It should ask you if you want to overwrite, select yes. If you don't have your original bluetooth manufacturer drivers and you can't get them off the internet, then here is what I did: First of all plug in the adapter and let windows discover the device and let windows try to install it, but it will fail. Uncheck the 'Don't ask me next time'.
Make a note of them and then in the Widcomm drivers folder, under win32 folder, open the btwusb.inf for editing (prefereably in notepad). Now we will manually add our device. First things first, in the btwusb.inf file, do a quick search for your VID number (e.g. 13DD) and see if there are already matching entries for your device - make sure that the VID number and PID number are both correct. If so, then you don't need to edit the file. To search (if you are in notepad, press 'CTRL' (key) + 'f' key at the same time and type in your VID number and click on 'Find Next') If you haven't located your device, then proceed: There are three lines to add: -In [ControlFlags] section: -Add a line: ExcludeFromSelect=USB\VID_XXXX&PID_XXXX (change the XXXX with the numbers from your device) -In [WIDCOMM.NTx86.5.1] section: -Add a line: %****.DeviceDesc%=BTWUSB, USB\VID_XXXX&PID_XXXX ; My BT USB Dongle Where the **** is a string or single word in CAPITALS (e.g. your manufacturer's name ITECH) and the XXXX's are the same numbers as before (VID & PID respectively). Finally, in [Strings] section: - Add a line: ****.DeviceDesc="My BT USB Dongle" Where **** must be the same word used in the previous step (again in CAPITALS) and the bit between the quotes can be anything you like - it will be used to display whatever your BT adapter is called in Device Manager. Try to stick with just spaces and letters. Now you can save the file and proceed with installation. Step 4 (Installing the Widcomm drivers) Now you are ready to install the Widcomm drivers, once again, under the folder, double click on setup.exe and the process should begin. Confirm whenever it pops up with the 'Warning, not digitally signed, continue?' box and mid way through when it says no bluetooth adapters found, just click cancel to proceed anyway. Once it has finished, you must restart the computer in safe mode to patch the bluetooth drivers. Step 5 (Patching the Widcomm drivers) Restart your computer and while it's booting up (you can see the black bios screen where it detects your CPU, hard drives, etc), press the F8 key repeatedly, maybe once every half a second, keep doing this and instead of Windows loading up, you will see a list of options. Select the option at the very top 'Safe Mode' and press enter. On entering safe mode, select 'Yes' to continue. Now locate the Widcomm_patcher_v2.exe program and double click on it. you will see three little dots next to 'BTStackServer.exe', click on those three dots and then navigate to (C: )Local Disk > Program Files > WIDCOMM > Bluetooth Software. In there you will see a file 'BTStackServer.exe'. Double click on it and the file should begin patching. (Select ok to continue) Next, another file appears, do the same as above, but this time the file is called BTTray.exe. Again, click ok once it's been patched. The third file to be patched is found in (C: )Local Disk > Windows > System32. It's a .dll file, but it's the same process as the above two steps. The forth step is also in the same location (another .dll file). Once this is done, you may reboot your computer again. Step 6 (Installing your Bluetooth USB drivers) You should notice that you have a 'My Bluetooth Places' Desktop icon as well as a little bluetooth icon in the system tray (that's red). We are nearly there. All we need to do now is to plug in your bluetooth device and Windows should pop up with a 'New hardware found' box. Click on Advanced install and uncheck everything except for 'search this specific folder' (not the exact words), and click on browse. The in the new window, navigate to C: Drive > Program Files > WIDCOMM > Bluetooth Software > bin, then click on OK and it should begin installing your device automatically. Once that is done, you should notice that your bluetooth icon in the system tray has now turned from red to white. You can double click on the icon and it should pop up with a wizard to guide you through the initial bluetooth setup process. Now you can start using pairing and using your bluetooth devices! Some FAQs Q: I can't be arsed to read this whole thing, is there a shorter way? A: Probably, but this is what I did and it works. Q: Where can I get the latest Widcomm drivers from? A: search the forum. (Tip: search for word 'Widcomm' in this bluetooth forum) Q: I don't have/lost my bluetooth drivers, can I still use this guide? A: Yes, check second part of step 3 Q: I've done everything, but bluetooth seems to be flaky and I'm having problems with my bluetooth devices. A: Check who the manufacturer of your bluetooth device is by right clicking on the bluetooth icon in the system tray, select 'Bluetooth Configuration' and then click on the 'Diagnostics' tab. In there, it will tell you the manufacturer of your bluetooth device. If it says 'Cambridge Silicon Radio' (CSR for short), then it's best to stick with the Widcomm drivers versions 5.1.0.1100 or lower. Later versions are known not to work very well with CSR manufactured devices as well as others. Reinstall with another version of the Widcomm drivers. Q: I can't get into safe mode! A: Hit the F8 button a bit quick multiple times as your computer is booting up (right from the very second you push the power on button). The menu should appear. Q: I can only see btwusb, not btwusb.inf? A: Make sure that 'Hide extensions for known file types' is turned off as per step 2 instructions. Q: How do you open .inf files for editing in notepad? A: Right click on the file and select 'Open with...' in the list, scroll down to notepad, left click on it and then set if you want notepad to open .inf files all the time, then select OK. Notepad should open the inf file now. Q: There is a licence patcher (WidcommLicensePatcher), what does it do and how do I use it? A: I don't know how to use it, maybe someone can contribute. However, I know that in effect it's supposed to authorise your USB Bluetooth device to use the Widcomm drivers, as outlined in step 5. You can do either or, you do not need to do both to get things to work. |
The Following User Says Thank You to kai_ For This Useful Post: |
11-06-2006, 00:02 | #3 (permalink) |
Junior Member Join Date: Nov 2005
Member: 200066 Status: Offline Thanks Meter: 0 | Superb post! This guide is the best! I finally succeeded upgrading the aging software of my IBM Thinkpad T42 - IBM Integrated Bluetooth III. Following this guide precisely was the trick. Previously, I have spent many hours with no succes, having to return to the previous Bluetooth II software. This worked out-of-the-box. A great thank goes out to bbsc for making the Widcomm patcher. |
12-23-2006, 10:33 | #4 (permalink) |
Junior Member Join Date: Sep 2006
Member: 353901 Status: Offline Thanks Meter: 0 | Will this work with the Logitech usb hub - mx900? I have tried unsuccessfully to install the mouse since reinstalling my system. i would like to use all of the features of my Logitech usb hub and sync my phone etc. but am confused regarding the process and sequence for insalling the logitch setpoint software for the mouse and the widcomm drivers. Is it possible to upgrade widcomm to 5.0.1.xxx and use the logitech software? Thanks in advance. Pretty clueless esp after reading all of the different posts. |
12-29-2006, 04:14 | #5 (permalink) |
Junior Member Join Date: Dec 2006
Member: 414857 Status: Offline Thanks Meter: 0 | My goal was to use Lego Mindstorms NXT without the dang USB cord. Mission accomplished! Thanks to these instructions I was able to get it working with an eBay cheapo made-in-china BT2.0EDR dongle using Widcomm 5.1.0.1100, and hacked accordingly. But I've got to say this, I wish BT was a better executed protocol in the marketplace. I wish Microsoft would have embraced BT and given it a fighting chance.. Oh, well.. hack away.. now I've got a Palm TX sitting here, and a Motorola e815... lets see what we can do with this stuff next ?! Cheers |
06-29-2007, 17:44 | #7 (permalink) |
Junior Member Join Date: Jun 2007
Member: 521912 Status: Offline Thanks Meter: 1 | ... Logitech usb hub - mx900 Working with all versions 5.0.1.801, 5.0.1.1100 (Widcomm) and 5.0.1.1400 (Anycom) where all functionalities are available. 5.0.1.2500 and 5.0.1.3300 works except Audio Gateway unavailable. If you know how to edit btusb.inf so go for it, otherwise use the inf file from xx.801. It's working. The tricky part is you must have the OLD setpointbt2.2 and replace the Widcomm software with the newer one before continuing of the installation procedure. |
06-30-2007, 14:30 | #8 (permalink) |
Member: 535068 Status: Offline Thanks Meter: 0 | i tried upgrading my Toshiba Satellite A-100 which has CSR internal bluetooth module using Toshiba bluetooth stack..I found out that removing all the default drivers of my bluetooth will turn it off and you can't detect it back when you restart it the since the so could Bluetooth Monitor 3 is required to turn on/off the power on the Bluetooth module...I reinstall this bluetooth monitor and upgrade it's driver to widcomm and works normally..but i have problem using dial-up networking and i can't use nokia internet connection..I cannot add this service??Has someone experienced it??pls |
08-18-2007, 04:35 | #9 (permalink) |
Member: 198304 Status: Offline Thanks Meter: 0 | Small update - this installation method is still valid and for many the best choice since the new widcomm stacks (above 1100) including the latest 3600 remove a wide range of compatibility. Windows Vista users, version 5.1.0.1100 is fully compatible however in order to patch the two system32 files ownership of those files and permissions need to be modified. Do so by invoking following commands in command prompt (cmd run as admin) takeown /f C:\Windows\System32\BTNeigborhood.dll cacls C:\Windows\System32\BTNeighboorhood.dll /G username:F where username is the current windows user name |
10-05-2007, 22:50 | #10 (permalink) |
Junior Member Join Date: Oct 2007
Member: 601275 Status: Offline Thanks Meter: 1 | i have got a problem i did everything like in this tut. but de patcher doesnt write anything but everything is successfull. im useing windows xp 64bit and here is my bth.inf maybe someone find the mistake. my dongle is a bcm92035dgrom. everytime when i try to install the driver with this inf the manager show me that a mistake has been taken while the installation. ; ; Broadcom Bluetooth USB Device Installation Script ; for 64-Bit Windows ; ; Copyright (c) 2000-2006, Broadcom Corp. ; [Version] signature="$WINDOWS NT$" Class=BTW ClassGUID={95C7A0A0-3094-11D7-A202-00508B9D7D5A} Provider=%V_WIDCOMM% CatalogFile=btwusb.cat DriverVer=04/12/2006,5.1.0.1100 [ControlFlags] ExcludeFromSelect=USB\VID_0A5C&PID_2021 ExcludeFromSelect=USB\VID_174B&PID_0003 ExcludeFromSelect=USB\VID_174B&PID_0002 ExcludeFromSelect=USB\VID_413C&PID_8126 ExcludeFromSelect=USB\VID_07B8&PID_B02C ExcludeFromSelect=USB\VID_0A5C&PID_2111 ExcludeFromSelect=USB\VID_0A5C&PID_2102 ExcludeFromSelect=USB\VID_07B8&PID_B02B ExcludeFromSelect=USB\VID_2001&PID_F118 ExcludeFromSelect=USB\VID_2001&PID_F117 ExcludeFromSelect=USB\VID_2001&PID_F116 ExcludeFromSelect=USB\VID_2001&PID_F111 ExcludeFromSelect=USB\VID_047D&PID_105E ExcludeFromSelect=USB\VID_174B&PID_0001 ExcludeFromSelect=USB\VID_3574&PID_21F6 ExcludeFromSelect=USB\VID_3574&PID_21F4 ExcludeFromSelect=USB\VID_13B1&PID_0019 ExcludeFromSelect = USB\VID_044e&PID_3001 ExcludeFromSelect = USB\VID_049F&PID_0027 ExcludeFromSelect = USB\VID_04BF&PID_0309 ExcludeFromSelect = USB\VID_04BF&PID_030A ExcludeFromSelect = USB\VID_04BF&PID_0310 ExcludeFromSelect = USB\VID_0A12&PID_0001 ExcludeFromSelect = USB\VID_0BDB&PID_1002 ExcludeFromSelect = USB\VID_0BDB&PID_1000 ExcludeFromSelect = USB\VID_08EA&PID_ABBA ExcludeFromSelect = USB\VID_0A5C&PID_200A ExcludeFromSelect = USB\VID_0A5C&PID_2009 ExcludeFromSelect = USB\VID_0A5C&PID_2045 ExcludeFromSelect = USB\VID_0A5C&PID_2110 ExcludeFromSelect = USB\VID_0A5C&PID_2100 ExcludeFromSelect = USB\VID_0A5C&PID_2101 ExcludeFromSelect = USB\VID_0C10&PID_0000 ExcludeFromSelect = USB\VID_0B7A&PID_07D0 ExcludeFromSelect = USB\VID_055D&PID_0BB1 ExcludeFromSelect = USB\VID_413C&PID_8000 ExcludeFromSelect = USB\VID_1668&PID_0441 ExcludeFromSelect = USB\VID_0F4D&PID_1000 ExcludeFromSelect = USB\VID_0DB0&PID_1967 ExcludeFromSelect = USB\VID_0DB0&PID_6970 ExcludeFromSelect = USB\VID_0DB0&PID_697A ExcludeFromSelect = USB\VID_0DB0&PID_6855 ExcludeFromSelect = USB\VID_04BF&PID_0319 ExcludeFromSelect = USB\VID_04BF&PID_0317 ExcludeFromSelect = USB\VID_04BF&PID_0318 ExcludeFromSelect = USB\VID_04BF&PID_0320 ExcludeFromSelect = USB\VID_045E&PID_007E ExcludeFromSelect = USB\VID_0400&PID_0807 ExcludeFromSelect = USB\VID_0483&PID_5000 ExcludeFromSelect = USB\VID_0451&PID_1234 ExcludeFromSelect = USB\VID_0451&PID_ffff ExcludeFromSelect = USB\VID_044e&PID_2014 ExcludeFromSelect = USB\VID_0D9A&PID_0001 ExcludeFromSelect = USB\VID_049F&PID_0086 ExcludeFromSelect = USB\VID_046D&PID_C707 ExcludeFromSelect = USB\VID_046D&PID_C708 ExcludeFromSelect = USB\VID_046D&PID_C709 ExcludeFromSelect = USB\VID_046D&PID_C70D ExcludeFromSelect = USB\VID_1668&PID_2441 ExcludeFromSelect = USB\VID_0FD1&PID_0001 ExcludeFromSelect = USB\VID_050D&PID_0083 ExcludeFromSelect = USB\VID_04AD&PID_2501 ExcludeFromSelect = USB\VID_0547&PID_0001 ExcludeFromSelect = USB\VID_0471&PID_0809 ExcludeFromSelect = USB\VID_11D9&PID_2600 ExcludeFromSelect = USB\VID_413C&PID_8501 ExcludeFromSelect = USB\VID_413C&PID_8110 ExcludeFromSelect = USB\VID_05B1&PID_1389 ExcludeFromSelect = USB\VID_03F0&PID_011D ExcludeFromSelect = USB\VID_03F0&PID_0624 ExcludeFromSelect = USB\VID_03F0&PID_171D ExcludeFromSelect = USB\VID_03F0&PID_D104 ExcludeFromSelect = USB\VID_1131&PID_1001 ExcludeFromSelect = USB\VID_1310&PID_0001 ExcludeFromSelect = USB\VID_1310&PID_0002 ExcludeFromSelect = USB\VID_0BF8&PID_1003 ExcludeFromSelect = USB\VID_4851&PID_1103 ExcludeFromSelect = USB\VID_1668&PID_0500 ExcludeFromSelect = USB\VID_0C24&PID_0001 ExcludeFromSelect = USB\VID_04E8&PID_7021 ExcludeFromSelect = USB\VID_148D&PID_2430 ExcludeFromSelect = USB\VID_413C&PID_8103 ExcludeFromSelect = USB\VID_0C24&PID_0002 ExcludeFromSelect = USB\VID_0A5C&PID_201E ExcludeFromSelect = USB\VID_0A5C&PID_2020 ExcludeFromSelect = USB\VID_2001&PID_F111 ExcludeFromSelect = USB\VID_041E&PID_5015 ExcludeFromSelect = USB\VID_047D&PID_105D ExcludeFromSelect = USB\VID_0D62&PID_2026 ExcludeFromSelect = USB\VID_22B8&PID_0850 [SourceDisksNames] 1 = %Source_Description%,,, [SourceDisksFiles] btwusb.sys = 1 frmupgr.sys = 1 btw_ci.dll = 1 [ClassInstall32] AddReg=BTW.NT.AddReg CopyFiles=BTW.NT.CopyFiles [BTW.NT.AddReg] HKR,,,0,%BTWClassName% HKR,,Icon,,100 HKR,,Installer32,,"btw_ci.dll,BTWClassInstaller" [BTW.NT.CopyFiles] btw_ci.dll [Manufacturer] %V_WIDCOMM%=WIDCOMM, NTamd64 [WIDCOMM.NTamd64] %bcm92035dgrom.DeviceDesc%=BTWUSB, USB\VID_0A5C&PID_2021 ; My BT USB Dongle %BARCODA.DeviceDesc%=SUSPENDUSB, USB\VID_174B&PID_0003 %BARCODA.DeviceDesc%=SUSPENDUSB, USB\VID_174B&PID_0002 %DellFangorn.DeviceDesc%=BRSMARTUSB, USB\VID_413C&PID_8126 %ABOCOM.DeviceDesc%=SUSPENDUSB, USB\VID_07B8&PID_B02C %BRCMANYCOMUHE.DeviceDesc%=BRSMARTUSB, USB\VID_0A5C&PID_2111 %BRCMANYCOM.DeviceDesc%=SUSPENDUSB, USB\VID_0A5C&PID_2102 %ABOCOM.DeviceDesc%=SUSPENDUSB, USB\VID_07B8&PID_B02B %FORMOSA4.DeviceDesc%=SUSPENDUSB, USB\VID_2001&PID_F118 %FORMOSA3.DeviceDesc%=SUSPENDUSB, USB\VID_2001&PID_F117 %FORMOSA2.DeviceDesc%=SUSPENDUSB, USB\VID_2001&PID_F116 %FORMOSA1.DeviceDesc%=SUSPENDUSB, USB\VID_2001&PID_F111 %KENSINGTONEDR.DeviceDesc%=BRSMARTUSB, USB\VID_047D&PID_105E %BARCODA.DeviceDesc%=SUSPENDUSB, USB\VID_174B&PID_0001 %SITECOM.DeviceDesc%=SUSPENDUSB, USB\VID_3574&PID_21F6 %SITECOM.DeviceDesc%=SUSPENDUSB, USB\VID_3574&PID_21F4 %LINKSYS.DeviceDesc%=SUSPENDUSB, USB\VID_13B1&PID_0019 %ALPS.DeviceDesc%=BTWUSB, USB\VID_044e&PID_3001 ; ALPS based VID&PID %COMPAQ.DeviceDesc%=BTWUSB, USB\VID_049F&PID_0027 ; COMPAQ CSR based VID&PID %IBM.DeviceDesc%=BTWUSB, USB\VID_04BF&PID_030A ; IBM CSR based VID&PID %TDK.DeviceDesc%=BTWUSB, USB\VID_04BF&PID_0309 ; TDK CSR based VID&PID %IBMBDC.DeviceDesc%=BTWUSB, USB\VID_04BF&PID_0310 ; IBM BDC CSR based VID&PID %TDK.DeviceDesc%=BTWUSB, USB\VID_04BF&PID_0319 ; TDK USB ADAPTER %TDK.DeviceDesc%=BTWUSB, USB\VID_04BF&PID_0320 ; TDK CSR BC2 based VID&PID %IBM.DeviceDesc%=BTWUSB, USB\VID_04BF&PID_0317 ; ULTRAPORT %IBMBDC.DeviceDesc%=BTWUSB, USB\VID_04BF&PID_0318 ; BDC %ERICMN.DeviceDesc%=BTWUSB, USB\VID_0BDB&PID_1000 ; Ericsson Business Mobile Networks BV VID&PID %ERICMP.DeviceDesc%=BTWUSB, USB\VID_0BDB&PID_1002 ; Ericsson Multipoint VID&PID %CSR.DeviceDesc%=BTWUSB, USB\VID_0A12&PID_0001 ; CSR VID&PID %bcm92035dgrom.DeviceDesc%=BTWUSB, USB\VID_0A5C&PID_2021 ; My BT USB Dongle %ERICSSONUSB.DeviceDesc%=BTWUSB, USB\VID_08EA&PID_ABBA ; Ericsson VID&PID %BROADCOM.DeviceDesc%=SUSPENDUSB, USB\VID_0A5C&PID_200A ; Broadcom VID&PID %BROADCOM.DeviceDesc%=BRSMARTUSB, USB\VID_0A5C&PID_2009 ; Broadcom VID&PID Smart dongle %BROADIBM.DeviceDesc%=SUSPENDUSB, USB\VID_0A5C&PID_201E ; Broadcom-IBM VID&PID Smart dongle %BROADCOM.DeviceDesc%=BRSMARTUSB, USB\VID_0A5C&PID_2020 ; Broadcom VID&PID Unified UHE %BROADCOM.DeviceDesc%=BRSMARTUSB, USB\VID_0A5C&PID_2045 ; Broadcom 2045 VID&PID %BROADIBMEDR.DeviceDesc%=SUSPENDUSB, USB\VID_0A5C&PID_2110 ; Broadcom IBM VID&PID %BRCM2045UHE.DeviceDesc%=BRSMARTUSB, USB\VID_0A5C&PID_2100 ; Broadcom 2045 VID&PID, UHE %BRCM2045.DeviceDesc%=SUSPENDUSB, USB\VID_0A5C&PID_2101 ; Broadcom 2045 VID&PID, non UHE %SAMSUNG.DeviceDesc%=BTWUSB, USB\VID_055D&PID_0BB1 ; SAMSUNG BC02 external %SIWAVE.DeviceDesc%=BTWUSB, USB\VID_0C10&PID_0000 ; Silicon Wave VID&PID %SIWAVE.DeviceDesc%=BTWUSB, USB\VID_05B1&PID_1389 ; Silicon Wave VID&PID %ZEEVO.DeviceDesc%=BTWUSB, USB\VID_0B7A&PID_07D0 ; Zeevo VID&PID %DELL.DeviceDesc%=SUSPENDUSB, USB\VID_413C&PID_8000 ; Dell BC02 VID&PID %IBMBM.DeviceDesc%=BTWUSB, USB\VID_1668&PID_0441 ; IBM integrated BT Modem VID&PID %IBMBM3.DeviceDesc%=SUSPENDUSB, USB\VID_1668&PID_2441 ; IBM Integrated Bluetooth III VID&PID %MICROTUNE.DeviceDesc%=BTWUSB, USB\VID_0F4D&PID_1000 ; Microtune USB Bluetooth Device VID&PID %MSI.DeviceDesc%=BTWUSB, USB\VID_0DB0&PID_1967 ; MSI USB Device VID&PID %MSI.DeviceDesc%=BTWUSB, USB\VID_0DB0&PID_6970 ; MSI USB Device VID&PID %MSI.DeviceDesc%=BTWUSB, USB\VID_0DB0&PID_697A ; MSI USB Device VID&PID %MSI.DeviceDesc%=BTWUSB, USB\VID_0DB0&PID_6855 ; MSI USB Device VID&PID %MSFT.DeviceDesc%=BTWUSB, USB\VID_045E&PID_007E ; Microsoft %NSCEVAL.DeviceDesc%=BTWUSB, USB\VID_0400&PID_0807 ; National Semi Bluetooth board %STM.DeviceDesc%=WDSMARTUSB, USB\VID_0483&PID_5000 ; STM VID&PID %TI.DeviceDesc%=WDSMARTUSB, USB\VID_0451&PID_1234 ; TI VID&PID %TI.DeviceDesc%=BTWUSB, USB\VID_0451&PID_ffff ; TI VID&PID %SONY.DeviceDesc%=BTWUSB, USB\VID_044e&PID_2014 ; SONY VID&PID %FORMOSA.DeviceDesc%=BTWUSB, USB\VID_0D9A&PID_0001 ; FORMOSA VID&PID %FORMOSA.DeviceDesc%=BTWUSB, USB\VID_4851&PID_1103 ; FORMOSA VID&PID %BLUETHUMB.DeviceDesc%=SUSP1USB, USB\VID_049F&PID_0086 ; BLUETHUMB USB Device VID&PID %LOGITECH.DeviceDesc%=BTWUSB, USB\VID_046D&PID_C707 ; LOGITECH VID&PID %LOGITECH.DeviceDesc%=BTWUSB, USB\VID_046D&PID_C708 ; LOGITECH VID&PID %LOGITECH.DeviceDesc%=BTWUSB, USB\VID_046D&PID_C709 ; LOGITECH VID&PID %LOGITECH.DeviceDesc%=BTWUSB, USB\VID_046D&PID_C70D ; LOGITECH VID&PID %GIANT.DeviceDesc%=BTWUSB, USB\VID_0FD1&PID_0001 ; Giant VID&PID %BELKIN.DeviceDesc%=SUSPENDUSB, USB\VID_050D&PID_0083 %PANASONIC.DeviceDesc%=BTWUSB, USB\VID_04AD&PID_2501 ; Panasoic VId&PID %ICSI.DeviceDesc%=BTWUSB, USB\VID_0547&PID_0001 ; ICSI USB Device VID&PID %PHILIPS.DeviceDesc%=BTWUSB, USB\VID_0471&PID_0809 ; Philips BluePearl VID&PID %ITRONIX.DeviceDesc%=BTWUSB, USB\VID_11D9&PID_2600 ; Itronix Bluetooth Device VId&PID %DELLELWOOD.DeviceDesc%=BRSMARTUSB, USB\VID_413C&PID_8501 ; Dell Elwood VId&PID %BROADCOMHP.DeviceDesc%=SUSP1USB, USB\VID_03F0&PID_011D ; BROADCOM VId&PID for Hp %BROADCOM2045HP.DeviceDesc%=SUSP1USB, USB\VID_03F0&PID_171D ; BROADCOM VId&PID for Hp %BRCMHPPRINT.DeviceDesc%=SUSPENDUSB, USB\VID_03F0&PID_D104 ; BROADCOM VId&PID for Hp %BCHPTransceiver.DeviceDesc%=BRSMARTUSB, USB\VID_03F0&PID_0624 ; BROADCOM VId&PID for Hp %ISSC.DeviceDesc%=BTWUSB, USB\VID_1131&PID_1001 ; ISSC USB Device Vid&PID %AIR2U.DeviceDesc%=BTWUSB, USB\VID_1310&PID_0001 ; Air2U Device Vid&Pid %AIR2UBRCM.DeviceDesc%=SUSPENDUSB, USB\VID_1310&PID_0002 ; Air2U(BCM) Device Vid&Pid %FCS.DeviceDesc%=BTWUSB, USB\VID_0BF8&PID_1003 ; Fujitsu Siemens Vid&Pid %ACTIONTEC.DeviceDesc%=BTWUSB, USB\VID_1668&PID_0500 ; Actiontec USB Bluetooth Device BTM200 %TAIYOYUDEN.DeviceDesc%=BTWUSB, USB\VID_0C24&PID_0001 ; TAIYO YUDEN USB Device VID&PID %TAIYOYUDEN2.DeviceDesc%=BTWUSB, USB\VID_0C24&PID_0002 ; TAIYO YUDEN USB Device VID&PID %SAMSUNGTY.DeviceDesc%=BTWUSB, USB\VID_04E8&PID_7021 ; Samsung TY USB Device VID&PID %MICROLINK.DeviceDesc%=BTWUSB, USB\VID_148D&PID_2430 ; MICROLINK USB Device VID&PID %DELLU2.DeviceDesc%=SUSPENDUSB, USB\VID_413C&PID_8103 ; DELL\CSR's U2 module VID&PID %DELLPHISH.DeviceDesc%=SUSPENDUSB, USB\VID_413C&PID_8110 ; DELL PHISH module VID&PID %TECOM.DeviceDesc%=SUSPENDUSB, USB\VID_041E&PID_5015 ; TECOM USB PID&VID %KENSINGTON.DeviceDesc%=BRSMARTUSB, USB\VID_047D&PID_105D ; Kensington USB PID&VID %TECOM.DeviceDesc%=BRSMARTUSB, USB\VID_0D62&PID_2026 ; TECOM Darfon USB PID&VID %BRCMMOTO.DeviceDesc%=SUSPENDUSB, USB\VID_22B8&PID_0850 ; ; Special sections for the Broadcom dongle and others ; with both selective suspend & remote wakeup disabled ; [BROADUSB.hw.reg] HKR,,"RemoteWakeupDisabled",0x10001,1 HKR,,"IdleSuspendEnabled",0x10001,0 [BROADUSB.NTamd64.hw] AddReg=BROADUSB.hw.reg [BROADUSB.NTamd64] AddReg=BTWUSB.reg CopyFiles=BTWUSB.CopyFiles.NT, BTWUSB.inf.CopyFiles [BROADUSB.NTamd64.Services] Addservice = BTWUSB, 0x00000002, BTWUSB.AddService ; ; Special sections for Widcomm Smart Dongle ; [WDSMARTUSB.hw.reg] HKR,,"SmartDongleType",0x10001,1 HKR,,"IdleSuspendEnabled",0x10001,1 [WDSMARTUSB.NTamd64.hw] AddReg=WDSMARTUSB.hw.reg [WDSMARTUSB.NTamd64] AddReg=BTWUSB.reg CopyFiles=BTWUSB.CopyFiles.NT, BTWUSB.inf.CopyFiles [WDSMARTUSB.NTamd64.Services] Addservice = BTWUSB, 0x00000002, BTWUSB.AddService ; ; Special sections for Broadcom Smart Dongle ; [BRSMARTUSB.hw.reg] HKR,,"SmartDongleType",0x10001,2 HKR,,"RemoteWakeupDisabled",0x10001,0 HKR,,"IdleSuspendEnabled",0x10001,1 [BRSMARTUSB.NTamd64.hw] AddReg=BRSMARTUSB.hw.reg [BRSMARTUSB.NTamd64] AddReg=BTWUSB.reg CopyFiles=BTWUSB.CopyFiles.NT, BTWUSB.inf.CopyFiles [BRSMARTUSB.NTamd64.Services] Addservice = BTWUSB, 0x00000002, BTWUSB.AddService ; ; Special sections for the Dell and other ; "selectively suspendable" dongles ; [SUSPENDUSB.hw.reg] HKR,,"RemoteWakeupDisabled",0x10001,0 HKR,,"IdleSuspendEnabled",0x10001,1 [SUSPENDUSB.NTamd64.hw] AddReg=SUSPENDUSB.hw.reg [SUSPENDUSB.NTamd64] AddReg=BTWUSB.reg CopyFiles=BTWUSB.CopyFiles.NT, BTWUSB.inf.CopyFiles [SUSPENDUSB.NTamd64.Services] Addservice = BTWUSB, 0x00000002, BTWUSB.AddService ; ; Special sections for "selectively suspendable" ; dongles not supporting remote wakeup when the ; whole machine is suspended ; [SUSP1USB.hw.reg] HKR,,"RemoteWakeupInSuspendDisabled",0x10001,1 HKR,,"IdleSuspendEnabled",0x10001,1 [SUSP1USB.NTamd64.hw] AddReg=SUSP1USB.hw.reg [SUSP1USB.NTamd64] AddReg=BTWUSB.reg CopyFiles=BTWUSB.CopyFiles.NT, BTWUSB.inf.CopyFiles [SUSP1USB.NTamd64.Services] Addservice = BTWUSB, 0x00000002, BTWUSB.AddService ; ; Standard sections ; [BTWUSB.hw.reg] HKR,,"IdleSuspendEnabled",0x10001,0 [BTWUSB.NTamd64.hw] AddReg=BTWUSB.hw.reg [BTWUSB.NTamd64] AddReg=BTWUSB.reg CopyFiles=BTWUSB.CopyFiles.NT, BTWUSB.inf.CopyFiles [BTWUSB.NTamd64.Services] Addservice = BTWUSB, 0x00000002, BTWUSB.AddService [BTWUSB.AddService] DisplayName = %BTWUSB.SvcDesc% ServiceType = 1 ; SERVICE_KERNEL_DRIVER StartType = 3 ; SERVICE_DEMAND_START ErrorControl = 1 ; SERVICE_ERROR_NORMAL ServiceBinary = %10%\System32\Drivers\btwusb.sys LoadOrderGroup = Base [BTWUSB.reg] HKR,,DevLoader,,"*ntkern" HKR,,NTMPDriver,,btwusb.sys [BTWUSB.CopyFiles.NT] btwusb.sys [BTWUSB.inf.CopyFiles] ;btwusb.inf [DestinationDirs] DefaultDestDir =11 BTWUSB.CopyFiles.NT =12 BTWUSB.inf.CopyFiles =10,INF BTW.NT.CopyFiles =11 [strings] bcm92035dgrom.DeviceDesc="My BT USB Dongle" DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="Bluetooth Devices" Source_Description="WIDCOMM Installation Media" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.0404] ; Chinese Traditional DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="ツナェ゙クヒクm" Source_Description="WIDCOMM ヲwクヒエCナ" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.0406] ; Danish DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="Bluetooth-enheder" Source_Description="WIDCOMM-installationsmedie" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.0407] ; German DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="Bluetooth-Ger舩e" Source_Description="WIDCOMM-Installationsmedien" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.040a] ; Spanish DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="Dispositivos Bluetooth" Source_Description="Medios de instalacin de WIDCOMM" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.040b] ; Finnish DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="Bluetooth-laitteet" Source_Description="WIDCOMM-asennuslevy" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.040c] ; French DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="P駻iph駻iques Bluetooth" Source_Description="Support d'installation WIDCOMM" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.0410] ; Italian DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="Periferiche Bluetooth" Source_Description="Supporto di installazione WIDCOMM" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.0411] ; Japanese DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="Bluetooth デバイス" Source_Description="WIDCOMM インストール メディア" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.0412] ; Korean DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="Bluetooth タ蠧。" Source_Description="WIDCOMM シウト。 ケフオセ" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.0413] ; Dutch DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="Bluetooth-apparaten" Source_Description="WIDCOMM-installatiemedia" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.0416] ; Brazilian Portuguese DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="Dispositivos Bluetooth" Source_Description="Mdia de instala鈬o WIDCOMM" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.041d] ; Swedish DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="Bluetooth-enheter" Source_Description="WIDCOMM-installationsskiva" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc="Belkin Bluetooth 2.0 USB Adapter" TECOM.DeviceDesc="TECOM Bluetooth Device" KENSINGTON.DeviceDesc="Kensington Bluetooth Device" BRCMMOTO.DeviceDesc="Motorola USB Bluetooth Device" [Strings.0415] ; Polish DellFangorn.DeviceDesc="Dell Wireless 355 Module with Bluetooth 2.0 + EDR Technology" BRCMANYCOMUHE.DeviceDesc="ANYCOM Blue USB-UHE 200/250" BRCMANYCOM.DeviceDesc="ANYCOM Blue USB-200/250" ABOCOM.DeviceDesc="BCM92045DG-Flash" FORMOSA4.DeviceDesc="Formosa 4" FORMOSA3.DeviceDesc="Formosa 3" FORMOSA2.DeviceDesc="Formosa 2" FORMOSA1.DeviceDesc="Formosa 1" KENSINGTONEDR.DeviceDesc="Kensington Bluetooth EDR Dongle" BARCODA.DeviceDesc="Bluetooth COM One Device" SITECOM.DeviceDesc="Sitecom USB Bluetooth Dongle" LINKSYS.DeviceDesc="Linksys Bluetooth USB Adapter" V_WIDCOMM="Broadcom" BTWClassName="Urzケdzenia Bluetooth" Source_Description="No從ik instalacyjny WIDCOMM" ERICSSONUSB.DeviceDesc= "Ericsson USB Bluetooth Device" CSR.DeviceDesc= "CSR USB Bluetooth Device" BROADCOM.DeviceDesc= "Broadcom USB Bluetooth Device" BTWUSB.SvcDesc= "WIDCOMM USB Bluetooth Driver" ERICMN.DeviceDesc= " Ericsson BV USB Bluetooth Device" ERICMP.DeviceDesc= "Ericsson USB Bluetooth Device 1.2" IBM.DeviceDesc= " Bluetooth Ultraport Module from IBM" TDK.DeviceDesc= "TDK Bluetooth USB Adaptor" IBMBDC.DeviceDesc= "IBM Integrated Bluetooth" COMPAQ.DeviceDesc= "Bluetooth Multiport Module by Compaq" ALPS.DeviceDesc= "Alps Bluetooth Device" ZEEVO.DeviceDesc= "Zeevo Bluetooth Device" SIWAVE.DeviceDesc= "Silicon Wave Bluetooth Device" SAMSUNG.DeviceDesc="Samsung Bluetooth Device" DELL.DeviceDesc="Dell TrueMobile Bluetooth Module" DELLU2.DeviceDesc="Dell Wireless 350 Bluetooth Internal Card" IBMBM.DeviceDesc="IBM Integrated Bluetooth II" IBMBM3.DeviceDesc="IBM Integrated Bluetooth III" MICROTUNE.DeviceDesc="Microtune USB Bluetooth Device" MSI.DeviceDesc="MSI USB Bluetooth Device" MSFT.DeviceDesc="Microsoft Bluetooth Device" NSCEVAL.DeviceDesc="National Semiconductor Bluetooth Board" STM.DeviceDesc="STMicroeletronics USB Bluetooth Device" TI.DeviceDesc="TI Mistral Bluetooth Device" SONY.DeviceDesc="Sony Bluetooth Device" FORMOSA.DeviceDesc="Formosa Bluetooth Device" LOGITECH.DeviceDesc="Bluetooth wireless hub" BLUETHUMB.DeviceDesc="Bluetooth by hp" GIANT.DeviceDesc="GIANT Bluetooth Device" BELKIN.DeviceDesc="Belkin Bluetooth Device" PANASONIC.DeviceDesc="Panasonic Bluetooth Device" ICSI.DeviceDesc="ICSI Bluetooth USB Device" PHILIPS.DeviceDesc="Philips BluePearl Bluetooth USB Device" ITRONIX.DeviceDesc="Itronix Bluetooth Device" DELLELWOOD.DeviceDesc="Dell Bluetooth USB adapter" BROADCOMHP.DeviceDesc="HP integrated module with Bluetooth wireless technology" BROADCOM2045HP.DeviceDesc="HP Integrated Module with Bluetooth 2.0 Wireless Technology" BRCMHPPRINT.DeviceDesc="HP Bluetooth Wireless Print and PC Adapter" BRCM2045UHE.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB-UHE Device" BRCM2045.DeviceDesc="Broadcom 2045 Bluetooth 2.0 USB Device" ISSC.DeviceDesc="ISSC USB Bluetooth Device" AIR2UBRCM.DeviceDesc="Broadcom ROM dongle" AIR2U.DeviceDesc="Air2U Bluetooth Device" FCS.DeviceDesc="Fujitsu Siemens USB Device" ACTIONTEC.DeviceDesc="Actiontec USB Bluetooth Device BTM200" SAMSUNGTY.DeviceDesc="Samsung Bluetooth Device" TAIYOYUDEN.DeviceDesc="Taiyo Yuden Bluetooth Device" TAIYOYUDEN2.DeviceDesc="Taiyo Yuden Bluetooth Device2" MICROLINK.DeviceDesc="Microlink-Foxlink Bluetooth Device" BCHPTransceiver.DeviceDesc="HP USB BT Transceiver [1.2]" BROADIBM.DeviceDesc="ThinkPad Integrated Bluetooth IV" BROADIBMEDR.DeviceDesc="ThinkPad Bluetooth with Enhanced Data Rate" DELLPHISH.DeviceDesc="Dell Wireless 3xx Bluetooth Internal Card" BELKIN.DeviceDesc=" |
10-06-2007, 13:22 | #11 (permalink) |
Junior Member Join Date: Oct 2007
Member: 601275 Status: Offline Thanks Meter: 1 | i have found the mistake i havent wrote it in big letters. but now i have got the problem that i cant connect to any device. everytime there is a window in that is the message that the licence isnt for my system. |
11-11-2007, 03:07 | #14 (permalink) |
Junior Member Join Date: Nov 2007
Member: 628106 Status: Offline Thanks Meter: 0 | Yes someone please upload the pack, help us out?! I have Vista ultimate x64 and my original CD drivers doesnt work. They arent 64bit + can't update because btwinitialupdate.exe says my device isnt supported.. |
How to install the drivers for PadFinder? | GSMtricks | PadFinder box | 12 | 11-26-2010 10:52 |
how to install usb driver for ufs tornado | gsmdz | UFS2 + UFS3-Tornadoflasher | 4 | 10-14-2010 16:04 |
how to installed a2 drivers | ruvanw1979 | Cruiser Suite | 1 | 12-16-2008 10:21 |
How to install the driver for Multi-box | GSMtricks | Multi-Box | 8 | 11-02-2005 10:54 |
Please...How to install Sonicsbox driver on Windows Xp Sp2? | wildtiger | Sonics Box | 3 | 07-27-2005 06:28 |
