11-10-2007, 19:22 | #1 (permalink) |
Junior Member Join Date: Jan 2007
Member: 426437 Status: Offline Thanks Meter: 0 | A2DP (Stereo) Service in Vista First of all - thanks for these great forums, without them, I wouldn't have half the functionality I need. I have Windows Vista, with a Logitech mini-BT receiver that comes with the Logitech diNovo Laser Desktop. I have a Jawbone headset and a Motorola S9 headset (supports AD2P)... I have everything working using WIDCOMM drivers 5.1.0.3600, except AD2P. It pairs, connects, and installs the Motorola S9 as a Bluetooth Stereo device... the only issue is that I do NOT see Stereo Audio as one of the local services installed... In the registry, there are 14 services, whereas, when I go into My Device, I only see 10... one of the missing ones is A2DP (Stereo) What this means is that when I try to find the Stereo playback device in Vista sounds, all I see is "Hands-free Audio" which gives me Mono playback through my S9.... Any ideas? I've tried a number of installs/re-installs and different versions. Can I force a service? |
11-22-2007, 22:16 | #4 (permalink) |
Member: 426437 Status: Offline Thanks Meter: 0 | I found out that the latest version is Version 6.1.0.1501.... Can anyone please please please post this version along with a patch??? I'm dying to get this working with my Logitech BT receiver... |
11-22-2007, 22:33 | #5 (permalink) |
Junior Member Join Date: Mar 2005
Member: 130747 Status: Offline Thanks Meter: 0 | try: ftp://drivers.anycom.com/beta/usb200-250/ know of no patcher but may be able to help you figure out if things work |
11-23-2007, 18:44 | #6 (permalink) | |
Member: 426437 Status: Offline Thanks Meter: 0 | Quote:
BTFlasher-v2-1-224-06.exe I'm not sure what version that is... but I'll try it when I get home. From Anycom's download page, the latest version they have is: v6.0.1.5300 http://service.anycom.com/get.php?usb=vista Can you point me to the exact file that is v6.1.X? I would be so excited to try it, since it has A2DP support! | |
11-23-2007, 18:46 | #7 (permalink) |
Member: 426437 Status: Offline Thanks Meter: 0 | Oh yeah, where are these ANYCOM forums that people refer to? EDIT: http://forum.anycom.com/index.php?topic=1956.0 W00t! A beta version... I hope it works with my dongle... EDIT: Unfortunately, the link was removed today since they'll be posting a FULL link shortly. Exciting! Last edited by slaman; 11-23-2007 at 18:51. |
11-24-2007, 01:36 | #8 (permalink) |
Member: 130747 Status: Offline Thanks Meter: 0 | Sorry for the miss but typically Anycom places the files in the beta directory before approving for straight download from tech support site. Files are usually named : anycom-bluetooth-[dongle]-[OS]-v-[version]-BETA.exe Where: dongle is the anycom model - The latest is usb200-250 OS - xp/vista version - wicomm version number like 6-1-0-1900 In the past anycom has had multiple versions in beta and perhaps is getting a more recent version of widcomm ready for beta use. |
11-24-2007, 10:50 | #10 (permalink) |
Junior Member Join Date: Dec 2003
Member: 46369 Status: Offline Thanks Meter: 0 | The ANYCOM drivers are widcomm based thus any version later then 5.1.0.1100 does not support CSR based dongles. Its safe to also say that for BROADCOM based dongles, 100% functionality can be guaranteed to the latest version of the drivers, given broadcom owns widcomm. Its important to remember that modifying the inf files and successfully loading the driver for your dongle doesn't mean anything about the driver's functionality and whether the driver code actually fully supports the hardware. It just passes the OS enumeration for the generic type of hardware installed (ie appears in DEVICE MANAGER as working ok) EDIT: since broadcom/widcomm introduced their online update option, which is supposedly open to any authentic installation, I find it unlikely that manufacturers will change a lot other then a bit of look and feel in their packages... |
11-24-2007, 11:06 | #11 (permalink) |
Member: 46369 Status: Offline Thanks Meter: 0 | to top up on my previous post, from the broadcom website BTW FAQ: "4) What about other Bluetooth devices? BTW should support any device uses the HCI protocol and conforms to the Bluetooth specification version 1.1. However, you may have to alter some of the configuration files in order to get BTW to recognize the device. Should you require assistance in this area, contact WIDCOMM, Inc. technical support." Most of us nowadays are getting spec 2.0 dongles, be it broadcom or other chip based... |
g thing in vista | flexo786 | LG | 1 | 08-05-2007 23:46 |
Broadcom 5.1.2300/2100 in Vista problem | shimh | Bluetooth-Software | 16 | 11-30-2006 03:41 |
