06-22-2005, 19:59 | #1 (permalink) |
Junior Member Join Date: Feb 2005 Age: 47
Member: 120251 Status: Offline Thanks Meter: 0 | HP Bluetooth stereo headset 1# Lifebook with cnet usb adapter bt v1.2 and bluesoleil 1.6 2# Sony Vaio S2XP using built in bt v1.2 and widcomm 4.0.1.1500 Both computers are running XP SP2. On setup 1# everything worked in a matter of seconds. On setup 2# the heaset can pair and when I try to connect it takes a really long time and the connecting.. dialog never dissapears. The sound in the speakers is turned of but no sound in my headset. What am I doing wrong? //Jonas |
06-22-2005, 22:15 | #2 (permalink) |
Member: 120251 Status: Offline Thanks Meter: 0 | Update Both BT devices work with the headset if I use Bluesoleil (but the built in one has the 5mb limit), With widcomm drivers that screen that I have enclosed is shown and nothing more happens |
06-24-2005, 11:11 | #3 (permalink) |
Junior Member Join Date: Jun 2005
Member: 153628 Status: Offline Thanks Meter: 1 | Hi, after I did trail error for many times... it is a matter of software stack! Now my HP BT headphone is working on my NC6000 (internal dongle). Here is the way to go... get the Widcomm 4.0.1.2106 (look in here ). Hope this help Now, I am just waiting HP for its official support on this again (this is just to proof its hardware is work and just need HP's up2date Widcomm driver). |
07-01-2005, 10:53 | #4 (permalink) |
Member: 153628 Status: Offline Thanks Meter: 1 | To make this HP BT headphone work... I flashed my internal NC6000 BT module with HP dfu file that upgrade the dongle to BT 1.2 class. Anyway, try very becarful while you are doing this... plug the ac and close all the program and even better without any on the task bar. Then, install Widcomm 4.0.1.2101 and after that anything is wok! Hope this would be work on TC1000 and TC1100 too as they said to be used the same BT module as NC6000. |
07-02-2005, 02:08 | #5 (permalink) |
Junior Member Join Date: Jul 2005
Member: 157307 Status: Offline Thanks Meter: 0 | So what is the dfu file that you mentioned? I just wanna make sure Im on the right track before I do anything. So you upgrade the internal BT module to 1.2. Then turn off the internal BT, then install the driver and the patches. Restart and that is it? Thanks for your clarification. |
07-02-2005, 22:54 | #6 (permalink) |
Member: 153628 Status: Offline Thanks Meter: 1 | This is original firmware(1393 / 1.2) for HP NC6000 http://forum.gsmhosting.com/vbb/att...tachmentid=7203 This firmware came with BT software support of the HP (possibly V.3B), but it was removed due to it killed off a lot of people dongle??? So, if you want to try... be prepare and careful. Good luck |
WE.COM Bluetooth Stereo Headset - H580 | IPMART | ipmart WebShop | 0 | 06-16-2009 08:50 |
Compatible Samsung SBH650 Bluetooth Stereo Headset | IPMART | ipmart WebShop | 0 | 06-16-2009 08:50 |
Bluedio Bluetooth Stereo Headset - AVF2 | IPMART | ipmart WebShop | 0 | 11-08-2008 07:00 |
Bluedio Bluetooth Stereo Headset - AVF1 | IPMART | ipmart WebShop | 0 | 11-08-2008 07:00 |
D500 Bluetooth Stereo Headset question | onlykor.. | SWIFT Platform | 0 | 08-02-2005 10:17 |
