Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 04-29-2008, 09:50   #1 (permalink)
Member: 532005
problems with dell bluetooth 355 module..
I have a M1330 with vista on it and the widcomm bluetooth drivers (I have also tried the newest anycom drivers). Problem is this, i have a bt microsoft wireless presenter 8000 mouse and bluetooth motorola BT820 headphones. Individually both work perfectly, but if i try to use them both at the same time the headphones skip quite often. I have read that you can have something crazy like 78 bluetooth devices connected so i am wondering why 2 are giving me problems? is there anyway to tweak the bluetooth module to work with this stuff or anything at all i can do to make both of these work well at the same time?
Old 05-01-2008, 02:53   #2 (permalink)
Member: 177301
Lightbulb Bandwidth is not sufficient
The Bluetooth 2.0 bandwidth is not sufficient to sustain A2DP + almost any other bluetooth devices. My suggestion is either give up using other BT devices while listening to the music, or get a earphone phone that only tranmits mono channel.
PS. I am using my BT355 with Logitech MX5000 keyboard/mice combo. That pretty much eats up the bandwidth of the module.
Old 05-01-2008, 11:03   #3 (permalink)
Member: 532005
thats strange because my anycom usb adapter can do it, its just the dell module that cant...
Old 05-06-2008, 04:33   #4 (permalink)
Member: 170891
check the Audio tab in your bluetooth devices window.
if dell has installed both stereo audio and telephony device for your motorola headset, just remove telephony device and then connect to headset.
this worked for me as I also was getting skips on my SE HBH-DS970 headset
[IMG] code is Off
2760 problem with radio, bluetooth, handsfree dime Nokia Hardware & Hardware-Repair Area 0 11-19-2009 22:25
Problem with the bluetooth headphone wxwxw Bluetooth-Software 0 02-13-2006 05:03
I have problem with my bluetooth elektrotek Bluetooth-Software 0 01-08-2005 22:22
problem with S700i bluetooth any brotoher help me thnk you Bondho Khondkar Sony Ericsson 0 11-22-2004 12:35
Problem with 6310 Bluetooth kamachko Nokia Digital Core Technology 4 ( DCT-4 ) 1 03-16-2003 22:03
Page generated in 0.22221 seconds with 11 queries
