06-27-2005, 07:16 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 44
Member: 104373 Status: Offline Thanks Meter: 0 | Problems After Install It says "Windows cannot find any Bluetooth devices. Make sure that your Bluetooth radio is attached to your computer and is turned on, and that your Bluetooth device is turned on. Follow the setup instructions that came with the device, and then click Search Again." I have tried reinstalling the SE software but that doesn't change anything. Also my dialup networking no longer works with my SE P910a or my SE T637. Both phone can connect and pair just fine, however when I try to connect DUN I get "error 633: The modem [or other connecting device] is already in use or not configured properly." When I try to connect to either phone the phones do show bluetooth connections happeneing, but then the error comes. These features are far more important to me than have a working headset. Has anyone else had this problem or have any suggestions to solve it? And ideas are greatly appreciated. Thanks, Darek |
06-27-2005, 17:34 | #4 (permalink) |
Junior Member Join Date: Jun 2005
Member: 153628 Status: Offline Thanks Meter: 1 | Have you tried uninstall the SonyEricsson software and reinstall it? I think to reinstall, the software should find the communication BT port itself which should be more better. |
06-30-2005, 20:53 | #6 (permalink) |
Freak Poster Join Date: Sep 2003
Member: 39443 Status: Offline Thanks Meter: 2 | My SE-Software is working over bluetooth with widcomm however i don't choose a Com Port with the type bluetooth in the SE-Software, I connect a Com-Port using Widcomm and select this Port is SE-Software. |
problem after installing v21 and v22 | arwanis | SagMaster Team OLD Products | 1 | 11-22-2006 13:26 |
Problem after installing 9.13a | ssb | Cruiser Suite | 6 | 02-20-2006 09:11 |
SE or Interceptor Problem after Installation ... | Myco1GSM | Cruiser Suite | 2 | 12-10-2004 04:12 |
3310 problems after instaling Blue leds!! | Me@n | Nokia Hardware & Hardware Repair | 7 | 12-18-2001 23:48 |
