08-07-2007, 15:14 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 43
Member: 102577 Status: Offline Thanks Meter: 4 | Widcomm 5.1.0.3600 32bit ONLY I have uploaded the latest release of Widcomm 5.1.0.3600 straight from Broadcom. It is a 32bit only release as that's what i have running currently on my computer. According to Anycom, if has some issues with the stereo sound quality so YMMV. It should however fix the problem with the pairing of the Apple keyboard that the previous 3300 release had. http://rapidshare.com/files/47514859...32bit.rar.html Enjoy ! Adi |
08-08-2007, 03:46 | #3 (permalink) | |
Junior Member Join Date: Feb 2005 Age: 47
Member: 119982 Status: Offline Thanks Meter: 0 | Quote:
Not sure if i'm wrong but all the other postings stated that after 5.1.0.1100 CSR chipset were no longer supported so how are you able to get your logitech bluetooth hub to work and even without a license patch? | |
08-08-2007, 10:21 | #4 (permalink) | |
Junior Member Join Date: Oct 2005
Member: 190560 Status: Offline Thanks Meter: 5 | Quote:
08-10-2007, 01:52 | #6 (permalink) | |
picture here : http://djcristi.no-ip.info/upload-ne...tech%20hub.JPG | |
10-29-2007, 20:24 | #10 (permalink) |
Junior Member Join Date: May 2005
Member: 144276 Status: Offline Thanks Meter: 0 | Someone have widcomm 5.0.1.4200? please upload here. I can't it get from update.broadcom.com it say "your bluetooh device security cannot be verified. please make sure that your device is not tampered and try again to upgrade again." if I use widcomm license patcher, it will say "your bluetooh software trial has been expired". plase help, thanks. |
11-10-2007, 22:47 | #11 (permalink) | |
Junior Member Join Date: Nov 2006
Member: 391977 Status: Offline Thanks Meter: 0 | Quote:
11-15-2007, 08:12 | #12 (permalink) |
Junior Member Join Date: Jun 2007
Member: 521912 Status: Offline Thanks Meter: 1 | Widcomm bt 5.1.0.3100 works perfectly on both broadcom and csr chipset, support A2DP too. So far is the best version I have tried w/o any problem http://www-307.ibm.com/pc/support/si...cid=MIGR-61425 |
11-15-2007, 19:18 | #13 (permalink) | |
Junior Member Join Date: Jan 2007
Member: 426437 Status: Offline Thanks Meter: 0 | Quote:
11-16-2007, 12:20 | #14 (permalink) | |
Crazy Poster Join Date: Jan 2005 Age: 53
Member: 112022 Status: Offline Thanks Meter: 125 | Quote:
Can you tell us how do you patched them to work with CSR dongles? | |
11-16-2007, 23:11 | #15 (permalink) |
Member: 521912 Status: Offline Thanks Meter: 1 | Nothing new here. Edit the btwusb.inf file clear [ControlFlags] for all restrictions on dongle versions, add %CSR.DeviceDesc% under both [WIDCOMM.NTx86.5.1] and [WIDCOMM] section. |
REQ: WIDCOMM 5.1.0.3600 64-bit Software | Ascii2 | Bluetooth-Software | 0 | 07-11-2009 23:26 |
Widcomm 5.1.0.3300 32bit only | adisor19 | Bluetooth-Software | 3 | 06-12-2007 22:33 |
Widcomm 5.1.0.1700 | adisor19 | Bluetooth-Software | 81 | 09-25-2006 19:22 |
Widcomm 5.1.0.1700a | adisor19 | Bluetooth-Software | 15 | 07-30-2006 15:47 |
Problem Serial Port in Widcomm 5.1.0.1100 | Nuker5 | Bluetooth-Software | 3 | 07-04-2006 12:45 |
