10-05-2009, 05:17 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Taiwan, China Age: 53
Member: 177301 Status: Offline Thanks Meter: 47 | Toshiba Bluetooth Stack Version 7.00.05 I think it would get more attention by having its own thread. http://www.aziocorp.com/support/down...TD603-132.html This is the version 7.00.05, x86 & x64 are in the same file. I have tested and it works perfectly with my Dell Bluetooth module 350 & 360 (both are CSR chips), no crack required. |
The Following 2 Users Say Thank You to Tseng For This Useful Post: |
10-06-2009, 23:37 | #3 (permalink) |
Junior Member Join Date: Jun 2006
Member: 295219 Status: Offline Thanks Meter: 0 | Last week I put the version 6.40.02 on windows 7 and it worked great for a couple of days and then for no reason the drivers disappeared. So I just tried these and am getting the 'evaluation has expired' message and they don't work. Toshiba say it's the type of adapter used. The drivers are meant to work for one month only for developer testing on "non-supported" hardware or some crap. So anyone know of a crack for this version please? |
11-08-2009, 00:50 | #7 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1156029 Status: Offline Thanks Meter: 4 | Does it work with truemobile 355? Tried it on one machine and it complains that usb is not connected. Modified the inf file then tried manually install driver with "have disk". Win 7 complained that it was not a correct driver for windows. Should this driver be a straight forward install on truemobile 355? |
Toshiba Bluetooth Stack Version 7.10.04 is now available | SLB | Bluetooth-Software | 19 | 11-04-2010 22:34 |
Now Available: Toshiba Bluetooth Stack Version 6.40.00 | armond | Bluetooth-Software | 21 | 02-02-2010 16:35 |
Toshiba Bluetooth Stack Version 7.00.16 | Tseng | Bluetooth-Software | 1 | 12-18-2009 04:18 |
Toshiba Bluetooth Stack Version 7.00.10 | Tseng | Bluetooth-Software | 8 | 11-21-2009 03:45 |
upgrade my Toshiba Bluetooth Stack to Widcomm BT Stack | jefbuan | Bluetooth-Software | 6 | 06-28-2007 16:29 |
