Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 01-03-2008, 17:51   #1 (permalink)
Member: 286304
Vista will not sleep when bluetooth is on
Hi everybody!
Help me, please, to find a solution. My laptop will not go to sleep mode if the bluetooth built-in device is on. It is Broadcom 2045. The screen turns off but fans and lights remain on. Once I turn the bluetooth off the problem goes away.
I have tried latest Anycomm, Widcomm drivers. The original Vista driver may work but the functionality of the bluetooth is limited to nothing I'd say and thus pointless. Googling did not help either.
Thank you.
Old 01-03-2008, 20:56   #2 (permalink)
Member: 462224
Sonork: 100.1586374
that is normal, if bluetooth is activated the system will not goes on sleep mode totally.
Old 01-04-2008, 13:01   #3 (permalink)
Member: 286304
I am convinced to disagree. Sleep mode is a low power state. Working fan is no way a low power state. Besides, the system won't restore. I have to long press power button which forces complete shut down, then mistake is logged - Unexpected shutdown.
Else, I tried to run the "fix" from MS because logically "the system fails to restore from sleep" but it said my system wouldn't need it.
Old 01-04-2008, 20:00   #4 (permalink)
Member: 462224
Sonork: 100.1586374
so, you have to change almentation parameters in configuration panel.
Old 01-04-2008, 21:26   #5 (permalink)
Member: 286304
I experimented with many parameters in power options with no luck. The only solution which works for me so far is to turn off the bluetooth first and then activate the sleep function. By no means it is the solution to the problem. It must sleep regardless of the devices either on or off.
[IMG] code is Off
MX-KEY Kaspersky board will not open when no (((GEZEGEN))) MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-09-2010 01:53
iPhone 2G home button working for DFU activation but does not work when phone is ON. pakstar iPhone ,iPod & iPad (Apple Inc. Products) 1 08-12-2009 18:27
MSSBOX VICTOR not sleep 4.30 is out mily2 MSS Box II 28 12-23-2006 22:29
K608 switches off when bluetooth is on MBR Sony Ericsson 0 05-29-2006 18:20
2600 not charging when phone is off but charging when phone is on codec_romania Nokia Digital Core Technology 4 ( DCT-4 ) 8 08-11-2005 09:31
Page generated in 0.44704 seconds with 11 queries
