Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 06-23-2005, 22:16   #1 (permalink)
Member: 39443
Widcomm 4.0.1.2101
New Software version 2101 on http://www.ccandc.com.tw/support.htm
Just created the patch....
To install follow my instructions EXACTLY, this is the fastest way:
-Unplug the Bluetooth device
-Install Widcomm, don't make a reboot
-Kill the processes BTTray.exe and BTSTAC~1.EXE in the Task manager
-Rename the 4 files to replace to .original
-Copy the patched files to the location
-Reboot
Or an other method described Patching the Widcomm stack at install time without safe mode can be done
Seems to be the first version supporting High Quality Audio (at least the device is installed by default)
File Type: rar Windows_System32_4.0.1.2101.Patched.rar (370.7 KB, 15304 views)
File Type: rar Programs_Bluetooth_4.0.1.2101.Patched.rar (464.5 KB, 12221 views)
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookTwitterStumble this Post!
The Following 2 Users Say Thank You to billyx For This Useful Post:
Old 06-24-2005, 11:07   #2 (permalink)
Member: 153628
Thank again Billyx, this version is working very well. Now I can get my HP BT headphone working! But to use it with 2 HID devices is really painful as they claimed A2DP need hugh bandwidth. But it is better than noting
The Following User Says Thank You to satein For This Useful Post:
Old 06-24-2005, 19:16   #3 (permalink)
Member: 152670
This is really, really great. I finally got my HP Stereoheadphones working. A2DP now works like a charm.
Thank you Thank you Thank you
Old 06-24-2005, 19:36   #4 (permalink)
Member: 31842
Hi =)
Could someone post an alternate link to the software - or perhaps post the software to the forum? The original site is dead slow
cheers
jazzman
Old 06-24-2005, 22:04   #5 (permalink)
Member: 155281
Bleutooth not stable...
I have the following problem after installing 4.01.2101 (also with the previous versions).
I have a Mycom Bluetooth Dongle (CSR chip): USB\VID_0A12&PID_0001\6&7172438&0&3
OS: Windows XP SP2 (bth.inf and bth.pnf both renamed, so Windows BT stack can't load..!)
After successfully installing/patching etc. the bluetooth connecting only works for about 30 seconds and then i get the error "bleutooth device not recognized" (or something similar, it appears in Dutch so i have to translate as good i can).
I have been experimenting for 3 nights now (as i said installing the 3 latest versions of Widcomm) but all gave the same result.
Also i discovered when the BT-connection is "up" that when i try to discover other devices the connection goes down within seconds.
A year ago, when i bought the dongle and had Win XP SP1 and Widcomm 1.3 installed, it was all rock stable. So i guess it has something to do with SP2.
Maybe someone recognizes this problem and can give me some advice or even better, a solution.
Old 06-24-2005, 22:14   #6 (permalink)
Member: 139296
When I try to install the widcomm 4.0.1.2101 software I always get a message Bluetooth Software license file not fount [2]. I tried to change the SVCPACK.INI too but no luck I didn't have any troubled with 4.0.1.700
Someone got a solution ?
thanks in advance
Old 06-24-2005, 22:20   #7 (permalink)
Member: 120251
Had the sane problem. I solved it by uninstalling previous version and removed the bluetooth device
Old 06-25-2005, 07:11   #8 (permalink)
Member: 139296
Thank's I didn't expect it would work like that with such message. This version is working well even A2DP with an BT-USB (unluckily Jerky with BT-CF Card).
I will try some more later and post if necessary
Old 06-25-2005, 07:43   #9 (permalink)
Member: 3279
link is not working
Old 06-25-2005, 08:16   #10 (permalink)
Member: 137994
link is not working
It is, it's just awfully slow. Try several times or try copying this in DAP (you'll need it
http://www.ccandc.com.tw/Driver/BTW%...%20release.exe
Old 06-25-2005, 10:38   #11 (permalink)
Member: 146454
Thanks for nice update
Old 06-25-2005, 12:03   #12 (permalink)
Member: 155875
thankfully OKOKOKOKOKOKOKOKOKOKOKOKOKO
Old 06-25-2005, 17:46   #13 (permalink)
Member: 155281
Problem solved now, bought other BT dongle.
Thanks for the help
Old 06-25-2005, 20:48   #14 (permalink)
Member: 103043
Hello there guys,
does any1 know if this release will enable A2DP over a fairly common CSR BT internal module ver. 1.1 (VID=0A12 & PID=0001)?
Thanks for the link,
Matt
Old 06-26-2005, 11:29   #15 (permalink)
Member: 108451
Originally Posted by Gionames
Hello there guys,
Matt
Hi, according to the supplied BTWUSB.INF your BT module with VID=0A12 & PID=0001 seams not to be (directly) supported. The same goes for me.
I have compiled an Excel file from the BTWUSB.INF for 4.0.1.2101 and 1.4.3.4 (my previous version) showing what's supported.
You could try add your BT module to the BTWUSB.INF and see if it helps. (Look at the example I have attached). But it was of no help to me (VID=1668 & PID=2441 on an IBM Thinkpad X40 with a CSR BT internal module III, Firmware rev. = 546, HCI = ver 1.1 rev 0222). I did not get the A2DP.
Someone else might have more knowledge if it is possible with some more changes.
[IMG] code is Off
Widcomm 4.0.1.900 Phantasm4489 Bluetooth-Software 222 01-30-2007 22:15
Which ones better? Widcomm 4.0.1.2101 or IVT BlueSoleil 1.6.2.1 crellion Bluetooth-Software 5 10-03-2005 23:22
Widcomm 4.0.1.2101 problem ][No_WaY Bluetooth-Software 4 08-20-2005 14:50
widcomm 4.0.1.2101 with older drivers ? MUSANI Bluetooth-Software 0 08-05-2005 02:09
Widcomm 4.0.1.1500 billyx Bluetooth-Software 16 06-30-2005 23:42
Powered by Searchlight © 2010 Axivo Inc.
- GSM Hosting Ltd. - 1999-2010
Page generated in 0.11378 seconds with 7 queries
