01-15-2006, 12:31 | #16 (permalink) |
Junior Member Join Date: Jan 2006
Member: 220888 Status: Offline Thanks Meter: 0 | Anyone knows what speed can i achieve in a BT network (2 laptops BT-enabled) ? I saw a commercial that 2x BT v1.2 approx 45KBits/s and 2xBT v2 EDR 135Kbits/s . I hope they are very wrong ! Anyway , MANY MANY thanks for the drivers&patch. (Damn Epox , comes with Toshiba drivers) |
01-15-2006, 18:51 | #19 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 43
Member: 102577 Status: Offline Thanks Meter: 4 | First of all, a BIG thank you for the patch ! I noticed that the svcpack.ini file already contained an entry for the btins.dll file. In the provided patch, this entry has been omitted and therefor, it might cause a problem with some BT services. I have added the entry for it as follows : SourceName5=btins.dll DestinationName5=btins.dll DestinationFolder5=2 DestinationSubFolder5= OS5=15 CopyOnlyIfExists1=Y I would suggest you guys should update the patch with this included entry. After installing it, it works perfectly Adi |
01-15-2006, 20:38 | #21 (permalink) | |
Junior Member Join Date: Jan 2004 Age: 45
Member: 50296 Status: Offline Thanks Meter: 0 | Quote:
01-16-2006, 08:29 | #24 (permalink) |
Junior Member Join Date: May 2005 Age: 46
Member: 148664 Status: Offline Thanks Meter: 0 | 64 Bit version? Hi all, Pardon me for being a beggar, but I'd really like to see the 64-bit versions of these patched too. I'm more than happy to help, and am able to do hex editing if I can be told what registers to edit. Thanks in advance! |
01-16-2006, 17:10 | #25 (permalink) |
Member: 50296 Status: Offline Thanks Meter: 0 | @ShugyoSystems If you know how to hex edit just compare the previous version (5.0.1.801 for instance) patch with it's original files and apply the same changes to the files in this version.. |
01-16-2006, 20:38 | #26 (permalink) |
Member: 220888 Status: Offline Thanks Meter: 0 | I'm struggeling for 2 days and nothing ! ICS . That is my problem. I bought 2 USB BT dongles & set-up a connection between 2 PCs PC1 : -Ethernet card : DHCP through cable modem -Bluetooth dongle : IP : 192.168.0.1 Subnet mask 255.255.255.0 no DNS , no DEFAULT GATEWAY . PC2 : -Bluetooth dongle : IP 192.168.0.2 Subnet mask : 255.255.255.0 Default gateway: 192.168.0.1 DNS : 192.168.0.1 (tried again with DNS received by PC1 from cable modem ,still no result) I want both PCs to have access through my cable modem , which has a public ip . Ping form PC1 to PC2 goes well Ping from PC2 to PC1 goes well PC1 HAS internet connection PC2 doesn't WHY ? WHAT DO I MISS ? (I have shared the PC1's internet connection as described in ICS help ) I tried changing drivers , toshiba / widcomm . No effect. By the way i've performed some speed tests : PC1 to PC2 , BT connected : on Toshiba drivers 66.95 KBYTES/s (one 150mil bytes - file) on Widcomm drivers(5.0.1.1200) : 69-73 KBYTES/s (1x 4MB file ) |
01-17-2006, 04:30 | #28 (permalink) | |
Member: 102577 Status: Offline Thanks Meter: 4 | Quote:
If i understand correctly, you're trying to share your internet connection to more then 1 extra computer by using the Windows connection sharing. I'm not sure that's a good idea.. if you really want to use bluetooth tech for your networking needs (why? when WiFI is way faster and cheap too), then you should get a bluetooth access point. I think Belkin makes one. It will save you the hassle of Windows conenction sharing and i heard it works pretty well. Again, i would recommend you use WiFi instead of Bluetooth.. Adi | |
01-18-2006, 05:32 | #29 (permalink) |
Member: 222206 Status: Offline Thanks Meter: 1 | License Error Thanks for the latest version however we need a patch for the license. I get the License.Dat error (2) when I try to install this version. I am currently running the 4.0.1.2101 without any problems. TIA Bill |
01-18-2006, 13:42 | #30 (permalink) | |
Adi | |
Widcomm 5.0.1.1400 | adisor19 | Bluetooth-Software | 98 | 05-15-2008 15:28 |
Widcomm 5.0.1.802 | adisor19 | Bluetooth-Software | 121 | 05-24-2007 19:52 |
Widcomm 5.0.1.801 | luckyknight | Bluetooth-Software | 120 | 04-07-2007 13:12 |
Widcomm 5.0.1.802 + Vaio Integrated Bluetooth - Success! | ro76 | Bluetooth-Software | 6 | 02-11-2006 22:45 |
SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. | spd303 | Bluetooth-Software | 0 | 11-21-2005 21:12 |
