01-21-2006, 20:03 | #46 (permalink) | |
Major Poster Join Date: Jan 2006 Location: somewhere on the Mediterranean
Member: 223748 Status: Offline Thanks Meter: 3 | Quote:
My adapter is a "Silicon Wave Bluetooth Device" BT1.2 dongle (firmware 1879) Thank you anyway To be continued.... | |
01-21-2006, 20:54 | #47 (permalink) |
Junior Member Join Date: Jul 2005
Member: 161522 Status: Offline Thanks Meter: 0 | HP Bluetooth Can anyone verify that this stack works with HP Bluetooth Headphones? I'll try if no one has yet.... Let me know This stack: Widcomm 5.0.1.802 never worked correctly. Just wondering if this new version would... bmex63 |
01-22-2006, 01:12 | #49 (permalink) | |
Freak Poster Join Date: Oct 2003
Member: 40901 Status: Offline Thanks Meter: 2 | Quote:
01-24-2006, 20:54 | #50 (permalink) | |
Junior Member Join Date: Jan 2006
Member: 223223 Status: Offline Thanks Meter: 0 | Quote:
01-24-2006, 21:02 | #51 (permalink) |
Member: 40901 Status: Offline Thanks Meter: 2 | No thats not right. I installed the 64 bit version on both xp x64 and vista64 and it installed into the program files directory not the program files (x86). Sounds like the setup program decided to install the 32 bit version instead. Can you check the files that are installed and see which one it installed? You are installing it correctly though, using the setup in the root folder. |
01-24-2006, 21:57 | #52 (permalink) | |
01-24-2006, 22:29 | #53 (permalink) | |
[edit] It worked (at least it installed) after cleaning up the registery from the previous version. I now have 100% cpu usage but I recall a fix for that on a different thread... Thanks! | |
01-26-2006, 05:23 | #54 (permalink) |
Member: 225042 Status: Offline Thanks Meter: 0 | where do i download the 143mb version, it seems like the ftp server is always down thanks. for those people who cant download the one from megaupload use hide ip platinum then flashget. before megaupload kept on blocking me saying all phil slots used, then directing me to premium. |
01-26-2006, 06:35 | #55 (permalink) | |
Freak Poster Join Date: Jan 2006
Member: 223498 Status: Offline Thanks Meter: 1 | Quote:
01-27-2006, 11:35 | #57 (permalink) |
Member: 225850 Status: Offline Thanks Meter: 0 | hi all, kinda new here short summary: currently there are two possibilities in order to get the 5.0.1.1200 drivers to work: (1) svcpack/patch from karamelo at http://www.megaupload.com/?d=GBW7GLHW which has to be corrected with following entry, meaning following entry has to be added to the "SvcPack.ini" file: SourceName5=btins.dll DestinationName5=btins.dll DestinationFolder5=2 DestinationSubFolder5= OS5=15 CopyOnlyIfExists5=Y (2) new .dat file from Phantasm4489 at http://www.megaupload.com/?d=D2Y5W1LU now my questions: - is this summary correct? - does it matter where the new entry is inserted? does is have to be all the way at the end or, as i have done, after the similar entries with numbers 1 to 4? - in order for (1) to work, copy "BTNeighborhood.dll", "SvcPack.ini" and "wbtapi.dll" to "C:\windows\system32" dir and copy "BTTray.exe" and "BTStackServer.exe" to the install dir of the bluetooth software overwriting previous versions AFTER the installation. is this correct? - in order for (2) to work, copy new "license.dat" file into setup dir of 5.0.1.1200 software overwriting previous version BEFORE the installation. is this correct? - which is the better way to go? which are the advantages, disadvantages of either solution? thanks a lot for your help! |
01-27-2006, 14:47 | #58 (permalink) | |
Freak Poster Join Date: Jan 2005 Age: 43
Member: 102577 Status: Offline Thanks Meter: 4 | Quote:
Your no.(2) statement is correct. You need to overwrite the licence.dat file before beggining the installation. Your no.(1) statement is slightly wrong.. All you need to do is copy the contents of that file to the SvcPack folder inside the Win32 folder of the installation files. You can of course modify the SvcPack.ini file with the extra entries you mentioned by placing them at the end of the other 4 entries. Then, you may begin installing it. I would use method (1) since i read that with method (2) you might see popups that it is a trial version from time to time.. Method (1) has never caused me problems so i'm all for it. Adi Last edited by adisor19; 01-27-2006 at 15:00. | |
Widcomm 5.0.1.1400 | adisor19 | Bluetooth-Software | 98 | 05-15-2008 15:28 |
Widcomm 5.0.1.802 | adisor19 | Bluetooth-Software | 121 | 05-24-2007 19:52 |
Widcomm 5.0.1.801 | luckyknight | Bluetooth-Software | 120 | 04-07-2007 13:12 |
Widcomm 5.0.1.802 + Vaio Integrated Bluetooth - Success! | ro76 | Bluetooth-Software | 6 | 02-11-2006 22:45 |
SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. | spd303 | Bluetooth-Software | 0 | 11-21-2005 21:12 |
