10-11-2005, 20:36 | #20 (permalink) |
Junior Member Join Date: Aug 2005 Age: 44
Member: 171430 Status: Offline Thanks Meter: 0 | Onto the USB Key with that file... The second last thing to get working on my laptop in x64 was bluetooth, and it was the last thing for my desktop(which actually has a logitech dinovo on it, so this should install fine there). Now if only I could get the ipw2200 to work in x64 mode on my laptop I'd never have to use 32 bit directly again. |
10-14-2005, 10:02 | #22 (permalink) |
Junior Member Join Date: Oct 2005
Member: 190061 Status: Offline Thanks Meter: 0 | Hi Guys, this is my first post here. Before posting I read many things in this forum, but didn't find any solution. But I guess I'm not the only one who has a Logitech Wireless HUB which came with MX900 (Pid 046D Vid C703). My dongle is recognized as a "USB Composite device". I added the missing lines in the btwusb.inf file, because for well known reasons Widcomm decided to support only new dongles. After this, anyway, PC is not able to recognize it as a Bluetooth dongle, but it keep staying as a "USB composite device". So I tried forcing the installation of the drivers, selecting the btwusb.inf file. The driver installs correctly, but Windows X64 is not able to initialize the dongle, and simply the hub switches off I read about the problem of HID mode, thinking it can be a problem related to the fact my dongle is not in HIC mode...I tried to use the utility HID2HCI from Epox without success (it seems it has no effect). So my questions to gurus is: has the dongle a problem with new drivers because it has an old firmware? Or simply it is really a problem about HID mode? By the way....the same problem I get with Microsoft stack: if I force the installation of bluetooth driver, the dongle switches off, and the peripheral can't be initialized... Please help me |
10-14-2005, 19:19 | #23 (permalink) |
Junior Member Join Date: Aug 2005 Age: 48
Member: 167721 Status: Offline Thanks Meter: 0 | patch file for WIDCOMM 5.0.1.801 You can download the patch from http://www.megaupload.com/?d=D3PNIH7P Afterwards, extract the files to the "svcpack" directory, and install as normal. In this way, there's no need to boot into safe mode and replace files. Enjoy. Last edited by storm99; 10-14-2005 at 19:33. |
10-14-2005, 19:45 | #24 (permalink) |
Junior Member Join Date: Jul 2005 Age: 48
Member: 164259 Status: Offline Thanks Meter: 0 | I did what you said with the Widcomm (5.0.1.801 x32) drivers and after I extract the rar file into the svcpack directory (overwritting the svcpack.ini) and then running the setup.exe it starts the install then pops up "Bluetooth Software license not found. [2]". Am I doing something wrong? Any help would be greatly appreciated!! BTW I am using it on an Inspiron 9300 with the Dell BT 350 internal card. |
10-14-2005, 20:02 | #25 (permalink) | |
Member: 167721 Status: Offline Thanks Meter: 0 | Quote:
10-15-2005, 02:23 | #28 (permalink) |
Junior Member Join Date: Jan 2005 Age: 45
Member: 108636 Status: Offline Thanks Meter: 0 | WiKDMoNKY, I'm guessing that the VID/PID for the Dell BT350 module isn't in the btwusb.inf file (it wasn't in version 4). It will need to be added by hand. See my post in this thread: http://forum.gsmhosting.com/vbb/show...9&page=1&pp=15 Martian |
10-15-2005, 13:13 | #29 (permalink) | |
Member: 190845 Status: Offline Thanks Meter: 0 | Quote:
I tried to install it on WinXP x64 but I get several error messages after installation. If I start the BTTray.exe it reports, that "btosif.dll" was not found. Also the BTStackServer.exe needs the "btins.dll", which it can't find, too. Not getting recognized, both files are lieing in the c:\windows\system32 dir. What's wrong there? bye MG | |
10-15-2005, 14:00 | #30 (permalink) | |
Junior Member Join Date: Aug 2005 Location: Russia Age: 49
Member: 173825 Status: Offline Thanks Meter: 0 | Quote:
Widcomm 5.0.1.1200 | Caribou | Bluetooth-Software | 102 | 09-06-2008 13:36 |
Widcomm 5.0.1.802 | adisor19 | Bluetooth-Software | 121 | 05-24-2007 19:52 |
Changing Passcode in Widcomm 5.0.1.801 | Outclassed | Bluetooth-Software | 1 | 02-12-2007 00:14 |
Need guide to install 5.0.1.801 On Toshiba Qosmio | Magice | Bluetooth-Software | 5 | 06-20-2006 07:06 |
SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. | spd303 | Bluetooth-Software | 0 | 11-21-2005 21:12 |
