Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #34 (permalink) |
| Junior Member Join Date: Oct 2005
Member: 191082 Status: Offline Thanks: 0
| widcomm 5.0.1.801 problem hello my bluetooth dongle worked fine with widcomm previous releases but when i installed the widcomm 5.0.1.801 after doing the patch procedure i restarted the pc i get the following error BTTray.exe -ENTRY POINT NOT FOUND THE PROCEDURE ENTRY POINT ?BTAUTHORIZEREQUESTCALLBACK@CWBTAPI@@QAE?AW4WBTRC@ @QAE00JJJ@Z COULD NOT BE LOCATED IN THE DYNAMIC LINK LIBRARY wbtapi.dll Plzzzzz Helpppp!!!!! |
| | #37 (permalink) |
| Junior Member Join Date: Oct 2005 Age: 31
Member: 187692 Status: Offline Thanks: 0
| I tried the patched files but I've got one problem. When I go to the "My Bluetooth Places" and click "View devices in rage" I get the error "No local bluetooth device was detected". The strange thing is that if I use the option "Add a Bluetooth Device" from the context menu of the WIDCOMM systemtray icon, it finds my mobile phone with no problems and I can use the Nokia PC Suite software. I would like to be able to use the WIDCOMM software itself as well though since the Nokia software is quite ****ty (to put it lightly). What can be the problem here? |
| | #38 (permalink) | |
| Quote:
| | #41 (permalink) | |
| Quote:
| | #42 (permalink) | |
Member: 193808 Status: Offline Thanks: 0
| Quote:
Any thoughts anyone? | |
| | #43 (permalink) |
Member: 194811 Status: Offline Thanks: 0
| I am having trouble getting my logitech dinovo usb base station recognized. I have installed the software and patch according to the above instructions. The software seems to install fine and I get no message about registering. From my research I assume my problem has to do with the btwusb.inf file not having my VID/PIC. Here is a link to http://www.planetamd64.com/lofiversi...hp/t12641.html a discussion about the 64 bit version and my base station. Also, the aforementioned instuctions in this thread say copy all the files from the patch rar to the svchost directory in the main files directory before installing (which I would assume overwrite them all in the original folder). The only file that is in that directory is the SVCPack.ini the other files from the patch are just copied. I think I just need something small to get this going. Hopefully, I am not being too confusing. If you have anymore questions, please post. Thanks in advance, crazyninja |
| | #44 (permalink) | |
Member: 195126 Status: Offline Thanks: 0
| Quote:
Thank you so much for your post. I was able to get the Dell 350 on my 9200 to work with this version. The only thing is, I can't seem to find a place to disable the driver when I don't need it. I can disable it through the Advanced Configuration -> Hardware tab. But my BT light is still on. Any ideas? | |
| | #45 (permalink) | |
Member: 195194 Status: Offline Thanks: 0
| Quote:
i got the same problem | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Widcomm 5.0.1.1200 | Caribou | Bluetooth-Software | 102 | 09-06-2008 13:36 |
| Widcomm 5.0.1.802 | adisor19 | Bluetooth-Software | 121 | 05-24-2007 19:52 |
| Changing Passcode in Widcomm 5.0.1.801 | Outclassed | Bluetooth-Software | 1 | 02-11-2007 23:14 |
| Need guide to install 5.0.1.801 On Toshiba Qosmio | Magice | Bluetooth-Software | 5 | 06-20-2006 07:06 |
| SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. | spd303 | Bluetooth-Software | 0 | 11-21-2005 20:12 |
