Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 11-23-2005, 02:21   #1 (permalink)
Member: 102577
Thanks Meter: 4
Widcomm 5.0.1.802
Hello guys and gals, i have a little gift for you all
A little new version of widcomm. I know, i know, it's the smalled point release of a widcomm version yet, but hey, it's higher then the last one :P
Got it from the Logitech Setpoint 2.46c release CD.
Get the 32 bit version here :
http://www.megaupload.com/?d=BJ0NDHW6
and the 64 bit version here :
http://www.megaupload.com/?d=PJM4IL7Y
Phantasm, hope you can patch this one for us
I'll upload the 32bit one as well.
Adi
Old 11-23-2005, 21:18   #2 (permalink)
Member: 173825
no problem, 32 bit version "servicepack" directory is ready now....
http://www.megaupload.com/ru/?d=HKH6KNHJ
Testing please ))
Old 11-25-2005, 17:06   #3 (permalink)
Member: 102513
All Good!
Widcomm 5.0.1.802 32 bit with above service pack works great! Another awesome patch by all you guys!
Old 11-27-2005, 22:57   #4 (permalink)
Member: 40901
Thanks Meter: 2
Try this for the x64 version - http://www.megaupload.com/?d=EBNPPEK0
Let me know how you get on.
Also if you get the "Bluetooth license check failed. Please make sure that the bluetooth device you are using is licensed..." please post the exact message,
there may be a number between the words CHECK and FAILED. I have placed these numbers into the various dll's so that I can see which dll is triggering this.
Old 11-28-2005, 00:11   #5 (permalink)
Member: 190415
Hi, Phantasm. I got it working for like 5 minutes, maybe some minuts more when the tray icon turned red again and the message popped up "license failed bla bla.... No numbers between the words. Damnnnnn, I never had it working this long. I really thought it would stay working.
Old 11-28-2005, 00:31   #6 (permalink)
Member: 40901
Thanks Meter: 2
Can you overwrite this DLL (btChooser.dll) into system32
http://www.megaupload.com/?d=TK9NYZ0J
and see if it comes up with a number in the message then.
Thanks.
Phantasm
Old 11-28-2005, 09:17   #7 (permalink)
Member: 190415
Thanks.
Phantasm
No number, sorry.
Old 11-28-2005, 10:01   #8 (permalink)
Member: 21937
Thanks Meter: 279
Testing please ))
can you please upload it somewhere else ? i keep d/l the files but rar is corrupted ...
thx
Old 11-28-2005, 15:06   #9 (permalink)
Member: 190415
Phantasm this is odd. I tried to do the same what you are doing. opening the dll's up in hex view and adding a number between words in that well known message, so you can know which dll gives the message. I've gone through all of them in the Data1.cab install package and I found only 3 files containing that message.
btchooser.dll
BtWizard.dll
BTNeighborhood.dll
after overwriting the installed ones with these, still the message appears without any number in between the words.
Old 11-28-2005, 18:30   #10 (permalink)
Member: 40901
Thanks Meter: 2
its in bttray.exe as well (in 2 places), but yes I too am now getting that error and cannot figure out where its coming from.
Also when it appears, if i end-task BTTray.exe it disappears, so its definately either coming from bttray.exe or a DLL that is loaded from bttray.exe
oh and its also present in the 32bit version of the files, but ive never seen that error message pop up on any of the 32 bit releases.
Old 11-28-2005, 19:34   #11 (permalink)
Member: 190415
Well, if you need help with testing I'm here.
Old 11-28-2005, 23:31   #12 (permalink)
Member: 173825
thx
Hmmm... I use latest version of RAR, try to upgrade winrar to last version.. if problem not solved, i repack with zip
Old 12-03-2005, 01:02   #13 (permalink)
Member: 126419
Hi, does this drivers work now or not? I mean the problems because of the license...
Maybe this files will help here too?
Widcomm 5.0.1.801
Old 12-03-2005, 01:23   #14 (permalink)
Member: 102577
Thanks Meter: 4
Widcomm 5.0.1.801
Don't use the patch for the OLD version. Use the one mentioned above.
Adi
Old 12-03-2005, 19:26   #15 (permalink)
Member: 202921
works perfectly for me - thank you very much!
Check out the BT Server Spy Lite application - very handy if you need to do any BT programming...
[IMG] code is Off
Widcomm 5.0.1.802 with Crack supertack Bluetooth-Software 0 05-20-2007 23:30
Widcomm 5.0.1.801 luckyknight Bluetooth-Software 120 04-07-2007 14:12
Widcomm 5.0.1.802 + Vaio Integrated Bluetooth - Success! ro76 Bluetooth-Software 6 02-11-2006 22:45
Confused with the 5.0.1.802 drivers... icebreeze Bluetooth-Software 0 12-12-2005 22:05
SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. spd303 Bluetooth-Software 0 11-21-2005 21:12
Page generated in 0.41402 seconds with 9 queries
