12-04-2005, 09:25 | #17 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
but i do get the licens error ... maybe im doing something wrong ? | |
12-04-2005, 12:39 | #18 (permalink) | |
Junior Member Join Date: Aug 2005 Location: Russia Age: 49
Member: 173825 Status: Offline Thanks Meter: 0 | Quote:
If I make full uninstall old WIDCOMM , reboot , and install new drivers, no license problems founded .... I checked on two different computers - home desktop with MSI dongle and Dell D610 with internal BT - no problems... | |
12-04-2005, 19:22 | #19 (permalink) | |
Freak Poster Join Date: Sep 2003
Member: 39443 Status: Offline Thanks Meter: 2 | Quote:
Don't you need this modification? I think you need it... The problem is that the values in the x64 file seems to be different than in x32 and I didn't find a system behind it. How did you find the position for the replacement you already did? | |
12-04-2005, 20:45 | #20 (permalink) | |
Junior Member Join Date: Jul 2005
Member: 163632 Status: Offline Thanks Meter: 0 | First Remove existing BT Stack Quote:
Even a re-install of the Dell Supplied Widcomm 3x (seems to lose some functions after a while) will be problematic if not first removed. Control Panel; Add/Remove does it all for Widcomm. But MS Stack has to be done through Device Manager and then rename Bth.inf & Bth.pnf to keep it gone. Is the "License Warning" just for the 64bit or both? | |
12-04-2005, 21:31 | #21 (permalink) |
Junior Member Join Date: Dec 2005
Member: 205559 Status: Offline Thanks Meter: 0 | Thank you!! It works perfectly on my ISSC USB Bluetooth dongle. I didn't do it right the first time, and so I got the "license.dat not found" message. Then remove dongle, uninstall all residues from the crappy Bluetooth driver (read, Bluesoleli), unpack the patch to the svcpack folder, install widcomm, attach dongle, reboot and it works! IMO. Widcomm stack are well better than the IVT bluesolei. With IVT bluesoleli, the ISSC dongle will become unusable(ie. unknown device detected) when computer resumes from standby. With Widcomm driver, the ISSC dongle will stays detected as always. Many thanks. Last edited by m3ipaq; 12-04-2005 at 21:46. |
12-04-2005, 23:33 | #22 (permalink) |
Member: 205574 Status: Offline Thanks Meter: 0 | i cant seem to get this to work for mine mx set from logitech. i think ive done everything correctly. uninstalled bluetooth drivers. uninstalled setpoint. patched the files in safe mode. add the line in btwusb.inf but nothing gives. still blue with red. I think my problem is that when windows find it its installed as a composite usb device. ive read some where that the dongle must be in HCI but in some update from logitech there was een firmware update that turned the device into HID. ive tried to get it to work with HID2HCI but again no go some one with a MX desktop that did get it to work? please be so kind to tell me. |
12-05-2005, 18:10 | #23 (permalink) | |
Freak Poster Join Date: Jan 2005 Age: 43
Member: 102577 Status: Offline Thanks Meter: 4 | Quote:
I know that when you install the setpoing 2.46c software it automatically installs some sort of addon that switches the dongle from it's composiste device state into a pure Bletooth dongle.. i don't have the CD anymore or i would have let you know what it was. It is definetly a separate program from the Widcomm software... you should check on your setpoint cd to see if you can find something. The program should be independent of what ever version of Widcomm you have installed. Adi | |
12-06-2005, 16:54 | #24 (permalink) |
Member: 173122 Status: Offline Thanks Meter: 0 | mouse works, headphones not so much I installed the 32-bit version with service pack on my Dell with TrueMobile 350. I got the bt mouse working great. However, when I try to discover my hp bt headphones, the device gets found, but when the "bluetooth service selection" dialogue box comes up, I get no services to select! (See attached picture). Can anyone help to explain this behavior and solve this problem? Thanks much. |
12-07-2005, 13:37 | #26 (permalink) |
Junior Member Join Date: Dec 2005 Location: China
Member: 205939 Status: Offline Thanks Meter: 0 | Hi, I got this driver works fine in my system, however I can not get connection to HT820, can anybody help? (Win2K+SP4) I checked with WinXP+SP2, HT820 is perfact working under "high performace" mode. |
12-08-2005, 02:45 | #27 (permalink) |
Member: 206489 Status: Offline Thanks Meter: 0 | HI Phantasm4489, I have installed Widcomm 5.0.1.802 for my CSR Bluetooth Dongle, I get the error the license file error [6] and if I try to associate my old license file it says error [-32], can you please help me out, heartfelt thanks in advance.. |
12-08-2005, 03:43 | #28 (permalink) | |
Adi | |
12-08-2005, 14:54 | #29 (permalink) | |
Member: 206489 Status: Offline Thanks Meter: 0 | License file error.. Quote:
Thanks for the input I did read the posts and guess what I formatted and installed XP SP2 just to set up the new version of Widcomm (so there is no old version to uninstall !!) after setup I get the license file is not valid and it shows this: [6] error (Phantasm4489 was asking for the error number in previous posts) and if I try to associate the old license file it shows: [-32] error, please guys help me out... | |
12-08-2005, 15:19 | #30 (permalink) | |
Adi | |
Widcomm 5.0.1.802 with Crack | supertack | Bluetooth-Software | 0 | 05-20-2007 22:30 |
Widcomm 5.0.1.801 | luckyknight | Bluetooth-Software | 120 | 04-07-2007 13:12 |
Widcomm 5.0.1.802 + Vaio Integrated Bluetooth - Success! | ro76 | Bluetooth-Software | 6 | 02-11-2006 22:45 |
Confused with the 5.0.1.802 drivers... | icebreeze | Bluetooth-Software | 0 | 12-12-2005 22:05 |
SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. | spd303 | Bluetooth-Software | 0 | 11-21-2005 21:12 |
