12-13-2005, 20:53 | #46 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Lima, Peru.Lat/Lon:, 12.0° S 7
Member: 184182 Status: Offline Sonork: 100.1622565 Thanks Meter: 97 | |
12-13-2005, 21:14 | #47 (permalink) |
Junior Member Join Date: Dec 2005
Member: 206538 Status: Offline Thanks Meter: 0 | I managed to fix my problem. I just uninstalled the 5.0 drivers and installed the 1.4.2.10 drivers instead. Mouse works fine after restart. I still have to test with my A900 though, so we'll see how that works out. |
12-13-2005, 22:15 | #48 (permalink) | |
Junior Member Join Date: Jul 2005
Member: 161522 Status: Offline Thanks Meter: 0 | Find a fix? Quote:
Did you or anyone else find a fix to the HP Bluetooth Headphone problem? I own a HP DV1000 Laptop. It finds the Bluetooth Headphones and Microsoft Intellimouse. However, only the Intellimouse will connect. The headphones will "pair," but will not connect. Under "My Bluetooth Places" they show up as " a headset rather than an Audio Gateway <-- Is this correct? Anyone have any suggestions? Any help would be greatly appreciated, Thanks | |
12-14-2005, 18:58 | #50 (permalink) |
Member: 161522 Status: Offline Thanks Meter: 0 | Help updating my firmware My comptuer is an HP DV1000 with Integrated BT. I was wondering if anyone has tried upgrading the firmware from 1.1 to 1.2. If so, were you successful and how did you do it? Sorry, I know that's a newbie question. I have read some previous posts and tried re-flashing using the CSR DFU wizard but that was a no go. I tried the DFU update wizard in the bin directory of my Widcomm folder....and that didn't work. It sounds like someone has done it on here. Any insight would be greatly appreciated. I was wondering if this was the reason that my HP BT headphones no longer work with the latest software 5.0.1.802. Possibility???? Thanks in advance for everyone's help |
12-17-2005, 14:35 | #51 (permalink) |
Member: 206538 Status: Offline Thanks Meter: 0 | Okay, guess I can't go back and edit my original post, so I'll post it here. The files have been removed from my server as I said they would be. Hope everyone who needed them got them. Nice to see they've been posted elsewhere and linked in this thread. |
12-18-2005, 15:43 | #52 (permalink) |
Junior Member Join Date: Jan 2005
Member: 102830 Status: Offline Thanks Meter: 0 | Nokia PCSUITE contact sync issues hi, with the widcomm driver 5.0.802 Nokia PC Suite synchroises only 4 contacts out of 160 plus contacts in my phone. PC Suite can see rest of the files fine - like messages, images etc. So I suspect some setting issues for contact update. Has anyone seen this before? Any pointers to solve this problem? I have already uninstalled the PC sutie and done the registry cleaning before reinstalling the sw and the issue persists. Any thoughts on the issue is appreciated... kr/- |
12-18-2005, 23:26 | #54 (permalink) | |
Member: 210267 Status: Offline Thanks Meter: 0 | Quote:
12-19-2005, 12:23 | #55 (permalink) |
Junior Member Join Date: Oct 2005
Member: 190061 Status: Offline Thanks Meter: 0 | erxes please, can you attach here this LBTWiz.exe . Unfortunately I cannot find it in the Setpoint 2.47. I have the same problem with a MX900 mouse and I'm not able to switch it in HCI mode under X64. If you cannot post the file, can you please tell me the exact link of the file you downloaded, as the link above doen't work. Thank you very much. Best regards |
12-19-2005, 12:50 | #56 (permalink) | |
Member: 102830 Status: Offline Thanks Meter: 0 | Nokia PCSUITE contact sync issues Quote:
Tks. kr/- | |
12-20-2005, 01:40 | #57 (permalink) | |
or probably better for x64 http://www.logitech.com/index.cfm/do...ontentid=10757 or you can try http://www.planetamd64.com/index.php?download=594 (need to registister for downloads) contains Setpoint 2.44c with widcomm5 for x64 and is supposed to be working - at least that's what they say in planetamd64 | |
12-22-2005, 05:07 | #59 (permalink) | |
Member: 163632 Status: Offline Thanks Meter: 0 | Quote:
Line above is a link to that post. | |
12-22-2005, 17:39 | #60 (permalink) |
Member: 109863 Status: Offline Thanks Meter: 0 | Very Strange. I have a Sony Vaio VGN-T350 that works perfectly with my i-phono headphones with version 4, but does not work with version 5. It sees it, and gives me the option to connect to stereo headphones, but disconnects immediately. The non-hifi works though. So, I am using version 4 for now. Anyone else have this problem? |
Widcomm 5.0.1.802 with Crack | supertack | Bluetooth-Software | 0 | 05-20-2007 22:30 |
Widcomm 5.0.1.801 | luckyknight | Bluetooth-Software | 120 | 04-07-2007 13:12 |
Widcomm 5.0.1.802 + Vaio Integrated Bluetooth - Success! | ro76 | Bluetooth-Software | 6 | 02-11-2006 22:45 |
Confused with the 5.0.1.802 drivers... | icebreeze | Bluetooth-Software | 0 | 12-12-2005 22:05 |
SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. | spd303 | Bluetooth-Software | 0 | 11-21-2005 21:12 |
