Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member Join Date: Jul 2005 Age: 43
Member: 161131 Status: Offline Thanks: 0
| Widcomm 5.0.1.802 + Vaio Integrated Bluetooth - Success! Hi, I just spent the last 24hrs trying to get the new Widcomm drivers to work with my Vaio S380 with internal BT module (UGX VID/PID 044e/3007). I thought I would post some instructions which are a combination of info on this forum and on the Sony TR World Forum . Essentially as I did it, there are 3 essential steps. STEP 1 Download the Widcomm 5.0.1.802 software with the service pack as described by adisor19. When you have applied the service pack, modify btwusb.inf before installing the software. (this is in the installation pack). See the attachment at the bottom of this post. This is just the same as the original file with 3 extra lines to allow the driver to work with the Sony BT module. Step 2 Follow the instructions in this post: Patch for vaio internal bt to enable working headset profile I followed the instructions for "VAIO-T, S, A with v1.2 Internal Bluetooth Module (PID 3007 only)" I expect that the other instructions for the v1.1 module will also work for those of you who have this. I should mention that my module has the PID 3007 - others may not, but this can be worked around by modifying the btwusb.inf file. Follow these instructions to the point of "Install SONY (Toshiba OEM) stack: " Step 3 At this point I installed my Widcomm 5.0.1.802 with the modified btwusb.inf as I mentioned in Step 1. Reboot and the manually install the driver located in the C:\Program Files\WIDCOMM\Bluetooth Software\bin - select btwusb.inf . Everything now works great, with the excellent Widcomm interface. All my current BT peripherals work a dream, including ActiveSync to my iPaq. I have not tested the headset profile yet - waiting on my SE HBH-602 to arrive. I hope this is useful. I was trawling these forums yesterday looking for a solution, and I just thought I would share my experiences. As I said this works for my vaio S380, but I assume that it will work for other integrated vaio modules. Do this at your own risk, though - I have no computer qualification and accept no responsibility for any consequences that you might experience. Thanks, Ro PS I had to zip the txt file to make it small enough. Last edited by ro76; 01-07-2006 at 17:48. |
| | #2 (permalink) |
| Junior Member Join Date: Sep 2005 Age: 55
Member: 180614 Status: Offline Thanks: 0
| I have been trying for months to get my sony vaio T150 with integrated bluetooth to work with my motorola hs850 bluetooth headset to use skype etc and I had tried every single stack on every site with everyone's instructions to no avail until reading ro76's easy to understand instructions and everything works great including skype, bluetooth mouse etc. Thanks to ro76 for finding out what works on sony vaio with integrated bluetooth. Bravo! |
| | #3 (permalink) | |
| Quote:
I use these type of forums all the time to sort out all my technical/computer problems, based on the experiences of others. It's unusual for me to be able to post a sloution, so I was delighted to contribute. Ro | |
| | #4 (permalink) |
| Junior Member Join Date: Jan 2006
Member: 226318 Status: Offline Thanks: 0
| ----When you have applied the service pack, modify btwusb.inf before installing the software. (this is in the installation pack). See the attachment at the bottom of this post. This is just the same as the original file with 3 extra lines to allow the driver to work with the Sony BT module.----- When you say Apply the service pack, what do you mean by that?? |
| | #5 (permalink) |
| Junior Member ![]() ![]() Join Date: Feb 2005 Age: 38
Member: 112657 Status: Offline Thanks: 0
| I will give you guys some steps to make it install easy. Prepare Step: Download newest version of Widcomm 5.0.1.1200 in this post and patched files. Copy all patched files to svcpack folder and file svcpack.txt attached and rename it to svcpack.ini also file btwusb.rar attached as btwusb.ini extracted. Install Step: Just install and you do not go to safe mode to overwrite some files. You can use immediately upon install finished. Just replace BT driver with driver in Widcomm. |
| | #7 (permalink) |
| Junior Member Join Date: Feb 2006
Member: 229361 Status: Offline Thanks: 0
| It doesn't work for me either ![]() I get message that my License expired or that my BT is not licensed to be used with the software. ( Yes I patched both files as described) Vaio VGN-A600P |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Widcomm 5.0.1.802 | adisor19 | Bluetooth-Software | 121 | 05-24-2007 19:52 |
| Widcomm 5.0.1.802 with Crack | supertack | Bluetooth-Software | 0 | 05-20-2007 22:30 |
| Widcomm 5.0.1.801 | luckyknight | Bluetooth-Software | 120 | 04-07-2007 13:12 |
| Confused with the 5.0.1.802 drivers... | icebreeze | Bluetooth-Software | 0 | 12-12-2005 21:05 |
| SetPoint 2.22 + Widcomm 5.0.1.801 with CSR USB BT and dinovo keybd. | spd303 | Bluetooth-Software | 0 | 11-21-2005 20:12 |
