05-30-2006, 11:22 | #35 (permalink) |
Junior Member Join Date: Oct 2003
Member: 42973 Status: Offline Thanks Meter: 0 | 2800 confirmed working with the logitec headset using A2DP profile. YOU MUST use the Wizard to find the headphones .. I could not get it working properly just buy pairing and connecting in the bluetooth neighbourhood. |
05-30-2006, 12:29 | #36 (permalink) | |
Junior Member Join Date: May 2006
Member: 272201 Status: Offline Thanks Meter: 0 | Quote:
Edit: Nope, won't do the trick. No A2DP working. Last edited by roma0803; 05-30-2006 at 17:06. | |
06-06-2006, 23:26 | #38 (permalink) |
Junior Member Join Date: Jan 2005 Age: 55
Member: 106354 Status: Offline Thanks Meter: 0 | My Working Configuration First of all, i want to thank all you people that help here Now, i'm using and working with: - Widcomm 5.1.0.1100 with License Patch - Kensington Bluetooth EDR USB Dongle (BT2.0) - Motorola HS820 Headset with gtalk - SonyEricsson T610 Phone with FMA - Kensington PilotMouse Mini Bluetooth - HP iPaq rx3715 No problems till now |
06-08-2006, 17:59 | #39 (permalink) |
Junior Member Join Date: Jun 2006
Member: 290525 Status: Offline Thanks Meter: 0 | new widcomm 5.1 drivers Hiya all, does anyone have an alternative download link for the Widcomm 5.1 drivers? I've tried the first set at the top of this post but when BTTray starts, I get an error: Entry Point Not Found The procedure entry point error ?SetOnSyncDeleteEventCallback..... could not be located in the the dynamic link library wbtapi.dll. anyone else get this error? help! ciao phil |
06-09-2006, 16:26 | #41 (permalink) |
Junior Member Join Date: Apr 2006 Location: India
Member: 258668 Status: Offline Thanks Meter: 0 | Bluetooth woes Hi friends, this is my first post here, unfortunately it starts with a problem i've downloaded & installed the 5.1.0.1100 version & followed instructions to the best of my abilities but apparently my abilities seem to be limited i'm using a Broadcom dongle, XP SP2, the problem faced is - once the software is installed & driver updated to CSR, the device manager shows 2 things - Bluetooth Bus Enumerator CSR USB Bluetooth Device I presume this is correct; but when i click open 'Bluetooth Devices' in Control Panel, the hardware tab shows nothing, b4 updating to CSR the Microsoft Bluetooth thing was visible here!!! Can anybody guide me as to where am i going wrong? this has been driving me nuts for so many days Last edited by lothario_42; 06-09-2006 at 16:42. |
06-11-2006, 07:21 | #43 (permalink) | |
Junior Member Join Date: Dec 2003 Location: USA
Member: 45831 Status: Offline Thanks Meter: 0 | Quote:
Download the driver for their BT2-USB dongle... they are 32bit... DriverVer=04/12/2006,5.1.0.1100 And use the LicensePatcher ZIP attached in the first post... | |
06-12-2006, 08:14 | #45 (permalink) | |
Member: 258668 Status: Offline Thanks Meter: 0 | tray icon Quote:
